Is eSIM currently supported on Mudi or any other router?
It should be quite soon.
It works on Mudi V2 with firmware update. So just need a eSIM card which is not expensive. But you need to buy eSIM profiles.
Exciting, can't wait to test as soon as it's ready.
any recommended way to buy these?
We will sell eSIM and eSIM profile.
You can also buy eSIM profile from somewhere else.
Can you give me link to aliexpress or keywords what to search for?
Your esim "physical card" can be used in other devices the same way as for example esim.me or 5ber?
Now I'm using esim.me with MudiV2 and works very well - in Europe, USA and SE Asia.
Yes it should work everywhere. After you write eSIM profile, it should work as normal SIM.
But what we develop on MudiV2 is UI to manage the eSim profiles.
Will be dual SIM?
The vSim one will be dual SIM. You can select which one to use. But only one can be used.
(Note, not promising 100%)
This is great news! I took a look at the page and would like to sign up but it seems that it’s limited to businesses? Any idea of when individuals are able to sign up to purchase/test? Thanks!
Please check here,this is a basic page, and will be optimized in the future, and will add how to use the video. The card is expected to be delivered to the US/Europe warehouse next week, you can buy it first, and then refer to our video for using. @admon @seal @RevelRob
we will release the MUDI-V2 with vsim function, the encrypted authentication information(like ICCID) to interact with the carrier is written to the module, so you don't need to plug in any sim card and the device can connect to the Internet when MUDI-V2 is turned on. The MUDI-V2 product that supports vsim supports you to switch to a physical card(refer to picture below), but does not support our current esim physical card. Standrad MUDI-V2 and all the gl.inet standard cellular router will support esim physical card in the further, but like Alzhao said, vsim need to change special modem, so MUDI-V2+vsim just support vsim and normal standard physical sim card, do support esim physical card.
But vSIM will be probably supported only by few network operators - and what modem will be needed in MUDIv2 - can you privide exact model?
It is SIMCOM/SIM6600.
Thank you, now it‘s available.
Do you know when this will be available globally? Specifically Canada? Thanks!
Is it this one the one with eSim availability?and normal sim?:
EM060K-G 4G Global / US+EU+UK+AU plug
Because the other one is sold out already
Is it this one with the esim or virtual sim?
Bcs the ofhed one is solx out already
Hi RevelRob, We will lanuch in UK and Canada and Global in next two weeks.
Hi Bleck, E750V2+EM060K-G and E750V2+EM05 support esim.
The vsim with E750V2 will use new module, it is simcom/sim6600, it doesn't support esim.
