bonjour. j'ai une question l'utilisation de la sim vendu sur votre boutique est elle obligatoire ? Ou une autre esim peut fonctionner dans vos routeurs ? par exemple esim.me ?
Hello. I have a question, is the use of the sim sold on your store mandatory? Or can another esim work in your routers? For example esim.me?
If you want to use our esim, you can purchase it from our store, I will ask the engineers to develop a beta firmware to support your device base the standard firmware.
Tomorrow or the day after tomorrow, the express information shows that the overseas warehouse has signed for receipt, but the overseas warehouse said that it has not received it. Our colleagues are investigating and coordinating, and the delivery should start soon.
Thanks for the quick reply, too bad there isnt an android app, that would be a great product.
I think it is supported cause i saw other physical esim adapters for mobile phones, and it works so im assuming it works the same way. Probably works similar way to saving contacts on a regular sim.
