I just bought a GL.iNet Comet device to use with my MacBook, but I’ve run into a few issues. I hope some of these can be improved in the future:
My Setup & Problem
Since MacBooks don’t support turning off the internal display easily, I’ve tried two approaches:
Mirror Display Mode
- Works initially, but sometimes the Mac forgets the mirror setting.
- The Comet becomes an extended display instead.
- No windows appear on it, and I can’t interact properly.
- I tried using keyboard shortcuts (e.g. Cmd + Space for Spotlight, navigating menus to re-enable mirroring), but:
- Keyboard seems unresponsive
- Mouse gets trapped on the invisible primary (MacBook) screen
Closed MacBook Lid (Clamshell Mode)
- This works but causes heat issues on the MacBook.
- The display resolution chosen is slightly off from the Mac’s native one.
- Usable, but not as smooth an experience as mirroring.
Feature Suggestions
- Fix Input Lock on Extended Mode
- Make sure keyboard and mouse still function even when screen is extended.
- At least allow “blind” key navigation (e.g., switch display modes with keyboard).
- Add Predefined EDID Profiles
- Include optimized EDID for recent MacBook models to ensure better compatibility.
- On-screen Keyboard (Mac Layout)
- Add an on-screen keyboard for emergency interaction.
Advanced (Nice-to-Have) Idea:
- Use OCR/AI to automatically navigate macOS menus to enable mirroring:
- Detect System Settings → Displays → Mirror Display
- Trigger via on-screen UI or automated process
Let me know if anyone has workarounds or if GL.iNet has plans to improve Mac compatibility!
Thanks ![]()
