OS: v4.1.0
I faced with kernel panic on my new router. Only one package was enabled - AdGuard Home.
Can you suggest me what is the heck?
Thanks
Log Entry 1 (at position 0)
<4>[158146.762330] CPU: 1 PID: 26991 Comm: kworker/1:1 Not tainted 4.4.60 #0
<4>[158146.762681] Hardware name: Generic DT based system
<4>[158146.769112] Workqueue: events rproc_crash_handler_work
<4>[158146.779077] task: 8f6d5580 ti: 8f5cc000 task.ti: 8f5cc000
<4>[158146.779305] PC is at ath11k_core_ssr_notifier_cb+0xa4/0xb4 [ath11k]
<4>[158146.784675] LR is at ath11k_hal_dump_srng_stats+0x248/0x2c0 [ath11k]
<4>[158146.791157] pc : [<7f7d7064>] lr : [<7f7d9764>] psr: 60000013
<4>[158146.791157] sp : 8f5cde28 ip : 00000000 fp : 9d826428
<4>[158146.797501] r10: 8083a520 r9 : 9d826664 r8 : 00000000
<4>[158146.809121] r7 : 8075fde0 r6 : 9e5af610 r5 : 8075fde0 r4 : 9af5092c
<4>[158146.814505] r3 : 00000000 r2 : dc8ba63c r1 : 9eb4a324 r0 : 0000007d
<4>[158146.820844] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
<4>[158146.827442] Control: 10c0383d Table: 506ec06a DAC: 00000055
<0>[158146.835078] Process kworker/1:1 (pid: 26991, stack limit = 0x8f5cc210)
<0>[158146.840722] Stack: (0x8f5cde28 to 0x8f5ce000)
<0>[158146.847230] de20: 00000002 9af5192c 00000000 fffffffd 00000000 80044da0
<0>[158146.851751] de40: 8087d520 00000000 8075fde0 ffffffff 9d826428 80045094 00000000 8f5cde6c
<0>[158146.859998] de60: 00000000 9d826778 9d826604 00000001 9d826400 800450c8 00000000 803572ec
<0>[158146.868245] de80: 9d82662c 8044c40c 9d82662c 9d826664 9d826400 9d82662c 9d8265c0 8044df58
<0>[158146.876491] dea0: 00000001 80357180 8073f63c 8075eeec 9d8193c0 00000000 8afb816c 9d82662c
<0>[158146.884737] dec0: 9d826664 00000003 9d82662c 9d8265c0 9d826664 8083a520 9eb4cb40 8044e290
<0>[158146.892983] dee0: 8044e164 9d82662c 955df480 9eb4cb40 9eb50000 00000000 00000000 8083a520
<0>[158146.901230] df00: 9eb4cb40 8003ed30 9eb4cb40 9eb4cb40 00000008 955df480 955df498 9eb4cb40
<0>[158146.909477] df20: 00000008 9eb4cb54 8f5cc000 8083a520 9eb4cb40 8003f1b0 80836100 955df480
<0>[158146.917724] df40: 8003eec8 00000000 990f4680 955df480 8003eec8 00000000 00000000 00000000
<0>[158146.925970] df60: 00000000 8004428c 8f5cdd10 00000000 00000000 955df480 00000000 00000000
<0>[158146.934217] df80: 8f5cdf80 8f5cdf80 00000000 00000000 8f5cdf90 8f5cdf90 8f5cdfac 990f4680
<0>[158146.942462] dfa0: 8004419c 00000000 00000000 80009c28 00000000 00000000 00000000 00000000
<0>[158146.950709] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<0>[158146.958956] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
<4>[158146.967328] [<7f7d7064>] (ath11k_core_ssr_notifier_cb [ath11k]) from [<80044da0>] (notifier_call_chain+0x2c/0x70)
<4>[158146.975457] [<80044da0>] (notifier_call_chain) from [<80045094>] (__blocking_notifier_call_chain+0x48/0x64)
<4>[158146.985785] [<80045094>] (__blocking_notifier_call_chain) from [<800450c8>] (blocking_notifier_call_chain+0x18/0x20)
<4>[158146.995772] [<800450c8>] (blocking_notifier_call_chain) from [<8044c40c>] (rproc_stop+0x2c/0xc4)
<4>[158147.006270] [<8044c40c>] (rproc_stop) from [<8044df58>] (rproc_trigger_recovery+0x4c/0x258)
<4>[158147.015122] [<8044df58>] (rproc_trigger_recovery) from [<8044e290>] (rproc_crash_handler_work+0x12c/0x1bc)
<4>[158147.023632] [<8044e290>] (rproc_crash_handler_work) from [<8003ed30>] (process_one_work+0x220/0x3b8)
<4>[158147.033092] [<8003ed30>] (process_one_work) from [<8003f1b0>] (worker_thread+0x2e8/0x4d0)
<4>[158147.042463] [<8003f1b0>] (worker_thread) from [<8004428c>] (kthread+0xf0/0xf8)
<4>[158147.050623] [<8004428c>] (kthread) from [<80009c28>] (ret_from_fork+0x14/0x2c)
<0>[158147.057828] Code: eb2a44eb e3500000 0affffe9 ea000000 (e7f001f2)
<4>[158147.065122] ---[ end trace 55afaaca627a88b1 ]---
<0>[158147.077774] Kernel panic - not syncing: Fatal exception
<2>[158147.077797] CPU2: stopping
<4>[158147.082137] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D 4.4.60 #0
<4>[158147.084658] Hardware name: Generic DT based system
<4>[158147.091955] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[158147.096732] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[158147.104715] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[158147.111832] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[158147.119470] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[158147.126933] Exception stack(0x9e48df88 to 0x9e48dfd0)
<4>[158147.134569] df80: 00000001 00000000 00000000 8000b400 9e48c000 808364a0
<4>[158147.139697] dfa0: 806d2e38 00000000 00000000 8082f30c 9e48dfe0 808364a8 60000013 9e48dfd8
<4>[158147.147942] dfc0: 80019394 80019398 60000013 ffffffff
<4>[158147.156185] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[158147.161313] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[158147.168865] [<80063664>] (cpu_startup_entry) from [<4100946c>] (0x4100946c)
<2>[158147.177020] CPU0: stopping
<4>[158147.184303] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G D 4.4.60 #0
<4>[158147.186827] Hardware name: Generic DT based system
<4>[158147.194121] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[158147.198899] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[158147.206885] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[158147.214002] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[158147.221641] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[158147.229103] Exception stack(0x80835f50 to 0x80835f98)
<4>[158147.236738] 5f40: 00000001 00000000 00000000 8000b400
<4>[158147.241868] 5f60: 80834000 808364a0 806d2e38 00000000 00000000 8082f30c 80835fa8 808364a8
<4>[158147.250113] 5f80: 60000013 80835fa0 80019394 80019398 60000013 ffffffff
<4>[158147.258358] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[158147.265217] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[158147.272601] [<80063664>] (cpu_startup_entry) from [<807f7d28>] (start_kernel+0x430/0x43c)
<2>[158147.280753] CPU3: stopping
<4>[158147.289079] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 4.4.60 #0
<4>[158147.291775] Hardware name: Generic DT based system
<4>[158147.299068] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[158147.303847] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[158147.311832] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[158147.318950] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[158147.326589] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[158147.334050] Exception stack(0x9e48ff88 to 0x9e48ffd0)
<4>[158147.341687] ff80: 00000001 00000000 00000000 8000b400 9e48e000 808364a0
<4>[158147.346815] ffa0: 806d2e38 00000000 00000000 8082f30c 9e48ffe0 808364a8 9e48ff80 9e48ffd8
<4>[158147.355059] ffc0: 80019394 80019398 60000013 ffffffff
<4>[158147.363304] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[158147.368430] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[158147.375983] [<80063664>] (cpu_startup_entry) from [<4100946c>] (0x4100946c)
<0>[158147.384142] The reading for sensor 4 is 0x0020427d
<0>[158147.391474] Couldn't get reading for sensor 5
<0>[158147.396026] The reading for sensor 7 is 0x00207276
<0>[158147.400588] Couldn't get reading for sensor 8
<0>[158147.405314] The reading for sensor 13 is 0x0022d27d
<0>[158147.409829] The reading for sensor 14 is 0x0020e279
<0>[158147.414998] Couldn't get reading for sensor 15
