Can someone interpret the crash log of my Slate AX ? Is it something related to Wi-fi things ?
Log Entry 1 (at position 0)
udp_diag tcp_diag raw_diag inet_diag tun qca_ssdk vfat fat ntfs nls_utf8 nls_iso8859_1 nls_cp437 mtdoops uas usb_storage gl_fan_driver xhci_plat_hcd xhci_pci xhci_hcd dwc3 dwc3_qcom dbm uhci_hcd ohci_platform ohci_hcd phy_msm_ssusb_qmp phy_msm_qusb ehci_platform sd_mod scsi_mod ehci_hcd gpio_button_hotplug gl_sdk4_tertf edgerouter_status usbcore nls_base usb_common mii gl_sdk4_hw_info
<4>[ 1593.233390] CPU: 1 PID: 132 Comm: kworker/1:2 Not tainted 4.4.60 #0
<4>[ 1593.233745] Hardware name: Generic DT based system
<4>[ 1593.239828] Workqueue: events rproc_crash_handler_work
<4>[ 1593.249794] task: 9d9e0d80 ti: 9d518000 task.ti: 9d518000
<4>[ 1593.249935] PC is at ath11k_core_ssr_notifier_cb+0xa4/0xb4 [ath11k]
<4>[ 1593.255305] LR is at ath11k_hal_dump_srng_stats+0x248/0x2c0 [ath11k]
<4>[ 1593.261352] pc : [<7f7e2064>] lr : [<7f7e4764>] psr: 60000013
<4>[ 1593.261352] sp : 9d519e28 ip : 00000000 fp : 9d80e428
<4>[ 1593.267956] r10: 8083a520 r9 : 9d80e664 r8 : 00000000
<4>[ 1593.279143] r7 : 8075fde0 r6 : 9e5af610 r5 : 8075fde0 r4 : 9b34092c
<4>[ 1593.284353] r3 : 00000000 r2 : dc8ba63c r1 : 9eb4a324 r0 : 0000007b
<4>[ 1593.290953] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
<4>[ 1593.297463] Control: 10c0383d Table: 597ac06a DAC: 00000055
<0>[ 1593.304666] Process kworker/1:2 (pid: 132, stack limit = 0x9d518210)
<0>[ 1593.310570] Stack: (0x9d519e28 to 0x9d51a000)
<0>[ 1593.316991] 9e20: 00000002 9b34192c 00000000 fffffffd 00000000 80044da0
<0>[ 1593.321254] 9e40: 8087d520 00000000 8075fde0 ffffffff 9d80e428 80045094 00000000 9d519e6c
<0>[ 1593.329412] 9e60: 00000000 9d80e778 9d80e604 00000001 9d80e400 800450c8 00000000 803572ec
<0>[ 1593.337573] 9e80: 9d80e62c 8044c40c 9d80e62c 9d80e664 9d80e400 9d80e62c 9d80e5c0 8044df58
<0>[ 1593.345732] 9ea0: 00000001 80357180 8073f63c 8075eeec 9dfff440 00000000 7a567267 9d80e62c
<0>[ 1593.353892] 9ec0: 9d80e664 00000003 9d80e62c 9d80e5c0 9d80e664 8083a520 9eb4cb40 8044e290
<0>[ 1593.362051] 9ee0: 8044e164 9d80e62c 9df0af00 9eb4cb40 9eb50000 00000000 00000000 8083a520
<0>[ 1593.370212] 9f00: 9eb4cb40 8003ed30 9eb4cb40 9eb4cb40 00000008 9df0af00 9df0af18 9eb4cb40
<0>[ 1593.378371] 9f20: 00000008 9eb4cb54 9d518000 8083a520 9eb4cb40 8003f1b0 80836100 9df0af00
<0>[ 1593.386530] 9f40: 8003eec8 00000000 9df0b740 9df0af00 8003eec8 00000000 00000000 00000000
<0>[ 1593.394689] 9f60: 00000000 8004428c 2a34a222 00000000 a28e2a60 9df0af00 00000000 00000000
<0>[ 1593.402849] 9f80: 9d519f80 9d519f80 00000000 00000000 9d519f90 9d519f90 9d519fac 9df0b740
<0>[ 1593.411009] 9fa0: 8004419c 00000000 00000000 80009c28 00000000 00000000 00000000 00000000
<0>[ 1593.419168] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<0>[ 1593.427329] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000 882209a2 c4577038
<4>[ 1593.435614] [<7f7e2064>] (ath11k_core_ssr_notifier_cb [ath11k]) from [<80044da0>] (notifier_call_chain+0x2c/0x70)
<4>[ 1593.443656] [<80044da0>] (notifier_call_chain) from [<80045094>] (__blocking_notifier_call_chain+0x48/0x64)
<4>[ 1593.453897] [<80045094>] (__blocking_notifier_call_chain) from [<800450c8>] (blocking_notifier_call_chain+0x18/0x20)
<4>[ 1593.463450] [<800450c8>] (blocking_notifier_call_chain) from [<8044c40c>] (rproc_stop+0x2c/0xc4)
<4>[ 1593.474209] [<8044c40c>] (rproc_stop) from [<8044df58>] (rproc_trigger_recovery+0x4c/0x258)
<4>[ 1593.482974] [<8044df58>] (rproc_trigger_recovery) from [<8044e290>] (rproc_crash_handler_work+0x12c/0x1bc)
<4>[ 1593.491051] [<8044e290>] (rproc_crash_handler_work) from [<8003ed30>] (process_one_work+0x220/0x3b8)
<4>[ 1593.500771] [<8003ed30>] (process_one_work) from [<8003f1b0>] (worker_thread+0x2e8/0x4d0)
<4>[ 1593.510055] [<8003f1b0>] (worker_thread) from [<8004428c>] (kthread+0xf0/0xf8)
<4>[ 1593.518127] [<8004428c>] (kthread) from [<80009c28>] (ret_from_fork+0x14/0x2c)
<0>[ 1593.525246] Code: eb2a18eb e3500000 0affffe9 ea000000 (e7f001f2)
<4>[ 1593.532453] ---[ end trace b59179ae4020ee4e ]---
<0>[ 1593.542986] Kernel panic - not syncing: Fatal exception
<2>[ 1593.543297] CPU2: stopping
<4>[ 1593.548240] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D 4.4.60 #0
<4>[ 1593.551021] Hardware name: Generic DT based system
<4>[ 1593.558232] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[ 1593.562922] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[ 1593.570818] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[ 1593.577850] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[ 1593.585401] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[ 1593.592777] Exception stack(0x9e48df88 to 0x9e48dfd0)
<4>[ 1593.600327] df80: 00000001 00000000 00000000 8000b400 9e48c000 808364a0
<4>[ 1593.605367] dfa0: 806d2e38 00000000 00000000 8082f30c 9e48dfe0 808364a8 60000013 9e48dfd8
<4>[ 1593.613524] dfc0: 80019394 80019398 60000013 ffffffff
<4>[ 1593.621682] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[ 1593.626723] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[ 1593.634189] [<80063664>] (cpu_startup_entry) from [<4100946c>] (0x4100946c)
<2>[ 1593.642255] CPU3: stopping
<4>[ 1593.649107] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 4.4.60 #0
<4>[ 1593.651888] Hardware name: Generic DT based system
<4>[ 1593.659095] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[ 1593.663787] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[ 1593.671686] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[ 1593.678717] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[ 1593.686269] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[ 1593.693644] Exception stack(0x9e48ff88 to 0x9e48ffd0)
<4>[ 1593.701194] ff80: 00000001 00000000 00000000 8000b400 9e48e000 808364a0
<4>[ 1593.706235] ffa0: 806d2e38 00000000 00000000 8082f30c 9e48ffe0 808364a8 60000013 9e48ffd8
<4>[ 1593.714392] ffc0: 80019394 80019398 60000013 ffffffff
<4>[ 1593.722549] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[ 1593.727589] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[ 1593.735055] [<80063664>] (cpu_startup_entry) from [<4100946c>] (0x4100946c)
<2>[ 1593.743122] CPU0: stopping
<4>[ 1593.749975] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G D 4.4.60 #0
<4>[ 1593.752757] Hardware name: Generic DT based system
<4>[ 1593.759964] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[ 1593.764657] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[ 1593.772553] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[ 1593.779585] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[ 1593.787137] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[ 1593.794513] Exception stack(0x80835f50 to 0x80835f98)
<4>[ 1593.802062] 5f40: 00000001 00000000 00000000 8000b400
<4>[ 1593.807103] 5f60: 80834000 808364a0 806d2e38 00000000 00000000 8082f30c 80835fa8 808364a8
<4>[ 1593.815262] 5f80: 00000000 80835fa0 80019394 80019398 60000013 ffffffff
<4>[ 1593.823420] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[ 1593.829847] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[ 1593.837488] [<80063664>] (cpu_startup_entry) from [<807f7d28>] (start_kernel+0x430/0x43c)
<0>[ 1593.845563] The reading for sensor 4 is 0x0020423d
<0>[ 1593.853797] The reading for sensor 5 is 0x00205244
<0>[ 1593.858532] Couldn't get reading for sensor 7
<0>[ 1593.863258] The reading for sensor 8 is 0x0020823d
<0>[ 1593.867686] The reading for sensor 13 is 0x0022d244
<0>[ 1593.872373] The reading for sensor 14 is 0x0020e23a
<0>[ 1593.877148] The reading for sensor 15 is 0x0020f241
2)
jdub
December 3, 2022, 3:39am
2
I don’t think so, but it’s hard to say. I don’t ever find these logs to be very useful - I always feel like they were written by the engineers who designed the chips or kernels.
Which gives me a little pause about what people think about the logs I write
Oops, second crash log after 2 days uptime… it’s really annoying…
Log Entry 2 (at position 1)
<4>[215892.049290] CPU: 1 PID: 132 Comm: kworker/1:2 Not tainted 4.4.60 #0
<4>[215892.049645] Hardware name: Generic DT based system
<4>[215892.056076] Workqueue: events rproc_crash_handler_work
<4>[215892.065867] task: 9d9e1200 ti: 9d520000 task.ti: 9d520000
<4>[215892.066095] PC is at ath11k_core_ssr_notifier_cb+0xa4/0xb4 [ath11k]
<4>[215892.071464] LR is at ath11k_hal_dump_srng_stats+0x248/0x2c0 [ath11k]
<4>[215892.077946] pc : [<7f7e2064>] lr : [<7f7e4764>] psr: 60000013
<4>[215892.077946] sp : 9d521e28 ip : 00000000 fp : 9d816428
<4>[215892.084292] r10: 8083a520 r9 : 9d816664 r8 : 00000000
<4>[215892.095911] r7 : 8075fde0 r6 : 9e5af610 r5 : 8075fde0 r4 : 9b30092c
<4>[215892.101294] r3 : 00000000 r2 : dc8ba63c r1 : 9eb4a324 r0 : 0000007d
<4>[215892.107634] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
<4>[215892.114231] Control: 10c0383d Table: 57db806a DAC: 00000055
<0>[215892.121868] Process kworker/1:2 (pid: 132, stack limit = 0x9d520210)
<0>[215892.127510] Stack: (0x9d521e28 to 0x9d522000)
<0>[215892.134020] 1e20: 00000002 9b30192c 00000000 fffffffd 00000000 80044da0
<0>[215892.138368] 1e40: 8087d520 00000000 8075fde0 ffffffff 9d816428 80045094 00000000 9d521e6c
<0>[215892.146615] 1e60: 00000000 9d816778 9d816604 00000001 9d816400 800450c8 00000000 803572ec
<0>[215892.154861] 1e80: 9d81662c 8044c40c 9d81662c 9d816664 9d816400 9d81662c 9d8165c0 8044df58
<0>[215892.163107] 1ea0: 00000001 80357180 8073f63c 8075eeec 9d807440 00000000 4d8917c3 9d81662c
<0>[215892.171354] 1ec0: 9d816664 00000003 9d81662c 9d8165c0 9d816664 8083a520 9eb4cb40 8044e290
<0>[215892.179601] 1ee0: 8044e164 9d81662c 9df0af80 9eb4cb40 9eb50000 00000000 00000000 8083a520
<0>[215892.187847] 1f00: 9eb4cb40 8003ed30 9eb4cb40 9eb4cb40 00000008 9df0af80 9df0af98 9eb4cb40
<0>[215892.196093] 1f20: 00000008 9eb4cb54 9d520000 8083a520 9eb4cb40 8003f1b0 80836100 9df0af80
<0>[215892.204339] 1f40: 8003eec8 00000000 9df0b780 9df0af80 8003eec8 00000000 00000000 00000000
<0>[215892.212585] 1f60: 00000000 8004428c 00000000 00000000 00000000 9df0af80 00000000 00000000
<0>[215892.220833] 1f80: 9d521f80 9d521f80 00000000 00000000 9d521f90 9d521f90 9d521fac 9df0b780
<0>[215892.229079] 1fa0: 8004419c 00000000 00000000 80009c28 00000000 00000000 00000000 00000000
<0>[215892.237325] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<0>[215892.245571] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
<4>[215892.253947] [<7f7e2064>] (ath11k_core_ssr_notifier_cb [ath11k]) from [<80044da0>] (notifier_call_chain+0x2c/0x70)
<4>[215892.262073] [<80044da0>] (notifier_call_chain) from [<80045094>] (__blocking_notifier_call_chain+0x48/0x64)
<4>[215892.272400] [<80045094>] (__blocking_notifier_call_chain) from [<800450c8>] (blocking_notifier_call_chain+0x18/0x20)
<4>[215892.282388] [<800450c8>] (blocking_notifier_call_chain) from [<8044c40c>] (rproc_stop+0x2c/0xc4)
<4>[215892.292886] [<8044c40c>] (rproc_stop) from [<8044df58>] (rproc_trigger_recovery+0x4c/0x258)
<4>[215892.301739] [<8044df58>] (rproc_trigger_recovery) from [<8044e290>] (rproc_crash_handler_work+0x12c/0x1bc)
<4>[215892.310248] [<8044e290>] (rproc_crash_handler_work) from [<8003ed30>] (process_one_work+0x220/0x3b8)
<4>[215892.319708] [<8003ed30>] (process_one_work) from [<8003f1b0>] (worker_thread+0x2e8/0x4d0)
<4>[215892.329080] [<8003f1b0>] (worker_thread) from [<8004428c>] (kthread+0xf0/0xf8)
<4>[215892.337239] [<8004428c>] (kthread) from [<80009c28>] (ret_from_fork+0x14/0x2c)
<0>[215892.344443] Code: eb2a18eb e3500000 0affffe9 ea000000 (e7f001f2)
<4>[215892.351736] ---[ end trace c713f444b7e5608d ]---
<0>[215892.362297] Kernel panic - not syncing: Fatal exception
<2>[215892.362756] CPU0: stopping
<4>[215892.368133] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G D 4.4.60 #0
<4>[215892.370654] Hardware name: Generic DT based system
<4>[215892.377952] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[215892.382727] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[215892.390711] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[215892.397828] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[215892.405468] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[215892.412930] Exception stack(0x80835f50 to 0x80835f98)
<4>[215892.420566] 5f40: 00000001 00000000 00000000 8000b400
<4>[215892.425694] 5f60: 80834000 808364a0 806d2e38 00000000 00000000 8082f30c 80835fa8 808364a8
<4>[215892.433939] 5f80: 80835f48 80835fa0 80019394 80019398 60000013 ffffffff
<4>[215892.442185] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[215892.449047] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[215892.456427] [<80063664>] (cpu_startup_entry) from [<807f7d28>] (start_kernel+0x430/0x43c)
<2>[215892.464581] CPU3: stopping
<4>[215892.472905] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 4.4.60 #0
<4>[215892.475602] Hardware name: Generic DT based system
<4>[215892.482895] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[215892.487673] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[215892.495658] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[215892.502776] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[215892.510415] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[215892.517876] Exception stack(0x9e48ff88 to 0x9e48ffd0)
<4>[215892.525513] ff80: 00000001 00000000 00000000 8000b400 9e48e000 808364a0
<4>[215892.530641] ffa0: 806d2e38 00000000 00000000 8082f30c 9e48ffe0 808364a8 60000013 9e48ffd8
<4>[215892.538886] ffc0: 80019394 80019398 60000013 ffffffff
<4>[215892.547129] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[215892.552256] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[215892.559809] [<80063664>] (cpu_startup_entry) from [<4100946c>] (0x4100946c)
<2>[215892.567963] CPU2: stopping
<4>[215892.575249] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D 4.4.60 #0
<4>[215892.577771] Hardware name: Generic DT based system
<4>[215892.585065] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[215892.589844] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[215892.597828] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[215892.604946] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[215892.612585] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[215892.620047] Exception stack(0x9e48df88 to 0x9e48dfd0)
<4>[215892.627683] df80: 00000001 00000000 00000000 8000b400 9e48c000 808364a0
<4>[215892.632812] dfa0: 806d2e38 00000000 00000000 8082f30c 9e48dfe0 808364a8 9e445ec9 9e48dfd8
<4>[215892.641056] dfc0: 80019394 80019398 60000013 ffffffff
<4>[215892.649299] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[215892.654425] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[215892.661978] [<80063664>] (cpu_startup_entry) from [<4100946c>] (0x4100946c)
<0>[215892.670139] The reading for sensor 4 is 0x0020421b
<0>[215892.677422] The reading for sensor 5 is 0x00205229
<0>[215892.682023] The reading for sensor 7 is 0x00207215
<0>[215892.686884] The reading for sensor 8 is 0x00208218
<0>[215892.691793] Couldn't get reading for sensor 13
<0>[215892.696605] The reading for sensor 14 is 0x0020e215
<0>[215892.701121] The reading for sensor 15 is 0x0020f21b
Before I applied the patch, it crashed the second time, now I just apply the Wi-Fi patch you mentioned and let me keep watching and see what will happen.
dma
August 28, 2024, 1:40am
6
I just got the same issue on my AXT1800 running 4.6.2 (released 2024-07-09). Interestingly, the ath11k_core_ssr_notifier_cb symbol doesn't appear to be in the stock Linux kernel. It seems to be added by this patch as an SSR ("subsystem restart?") crash handler. The actual cause of the crash would probably require understanding Atheros chips (and the ath11k driver) better than I am able to.
In any case, these are my log entries:
Oops#1 Part1
<4>[187746.245303] CPU: 1 PID: 121 Comm: kworker/1:1 Not tainted 4.4.60 #0
<4>[187746.245658] Hardware name: Generic DT based system
<4>[187746.252087] Workqueue: events rproc_crash_handler_work
<4>[187746.261879] task: 9dec5e80 ti: 9d922000 task.ti: 9d922000
<4>[187746.262106] PC is at ath11k_core_ssr_notifier_cb+0xa4/0xb4 [ath11k]
<4>[187746.267476] LR is at ath11k_hal_dump_srng_stats+0x248/0x2c0 [ath11k]
<4>[187746.273958] pc : [<7f7e0064>] lr : [<7f7e2764>] psr: 60000013
<4>[187746.273958] sp : 9d923e28 ip : 00000000 fp : 9d816428
<4>[187746.280303] r10: 8083a520 r9 : 9d816664 r8 : 00000000
<4>[187746.291924] r7 : 8075fee0 r6 : 9e5af610 r5 : 8075fee0 r4 : 9afe092c
<4>[187746.297308] r3 : 00000000 r2 : dc8ba63c r1 : 9eb4a324 r0 : 0000007d
<4>[187746.303646] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
<4>[187746.310243] Control: 10c0383d Table: 57a8806a DAC: 00000055
<0>[187746.317879] Process kworker/1:1 (pid: 121, stack limit = 0x9d922210)
<0>[187746.323523] Stack: (0x9d923e28 to 0x9d924000)
<0>[187746.330031] 3e20: 00006c01 9afe192c 00000000 fffffffd 00000000 80044da0
<0>[187746.334379] 3e40: 8087d520 00000000 8075fee0 ffffffff 9d816428 80045094 00000000 9d923e6c
<0>[187746.342626] 3e60: 00000000 9d816778 9d816604 00000001 9d816400 800450c8 00000000 803572ec
<0>[187746.350873] 3e80: 9d81662c 8044c40c 9d81662c 9d816664 9d816400 9d81662c 9d8165c0 8044df58
<0>[187746.359119] 3ea0: 00000001 80357180 8073f73c 8075efec 9d8074c0 00000000 0cf9b88a 9d81662c
<0>[187746.367365] 3ec0: 9d816664 00000003 9d81662c 9d8165c0 9d816664 8083a520 9eb4cb40 8044e290
<0>[187746.375612] 3ee0: 8044e164 9d81662c 9df42800 9eb4cb40 9eb50000 00000000 00000000 8083a520
<0>[187746.383858] 3f00: 9eb4cb40 8003ed30 9eb4cb40 9eb4cb40 00000008 9df42800 9df42818 9eb4cb40
<0>[187746.392105] 3f20: 00000008 9eb4cb54 9d922000 8083a520 9eb4cb40 8003f1b0 80836100 9df42800
<0>[187746.400351] 3f40: 8003eec8 00000000 9df43380 9df42800 8003eec8 00000000 00000000 00000000
<0>[187746.408598] 3f60: 00000000 8004428c 00000000 00000000 00000000 9df42800 00000000 00000000
<0>[187746.416845] 3f80: 9d923f80 9d923f80 00000000 00000000 9d923f90 9d923f90 9d923fac 9df43380
<0>[187746.425091] 3fa0: 8004419c 00000000 00000000 80009c28 00000000 00000000 00000000 00000000
<0>[187746.433337] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<0>[187746.441583] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
<4>[187746.449954] [<7f7e0064>] (ath11k_core_ssr_notifier_cb [ath11k]) from [<80044da0>] (notifier_call_chain+0x2c/0x70)
<4>[187746.458086] [<80044da0>] (notifier_call_chain) from [<80045094>] (__blocking_notifier_call_chain+0x48/0x64)
<4>[187746.468413] [<80045094>] (__blocking_notifier_call_chain) from [<800450c8>] (blocking_notifier_call_chain+0x18/0x20)
<4>[187746.478399] [<800450c8>] (blocking_notifier_call_chain) from [<8044c40c>] (rproc_stop+0x2c/0xc4)
<4>[187746.488898] [<8044c40c>] (rproc_stop) from [<8044df58>] (rproc_trigger_recovery+0x4c/0x258)
<4>[187746.497751] [<8044df58>] (rproc_trigger_recovery) from [<8044e290>] (rproc_crash_handler_work+0x12c/0x1bc)
<4>[187746.506261] [<8044e290>] (rproc_crash_handler_work) from [<8003ed30>] (process_one_work+0x220/0x3b8)
<4>[187746.515720] [<8003ed30>] (process_one_work) from [<8003f1b0>] (worker_thread+0x2e8/0x4d0)
<4>[187746.525092] [<8003f1b0>] (worker_thread) from [<8004428c>] (kthread+0xf0/0xf8)
<4>[187746.533249] [<8004428c>] (kthread) from [<80009c28>] (ret_from_fork+0x14/0x2c)
<0>[187746.540455] Code: eb2a20eb e3500000 0affffe9 ea000000 (e7f001f2)
<4>[187746.547749] ---[ end trace 4ab4153cde33f9c8 ]---
and:
Panic#2 Part1
ip6t_NPT ip6t_MASQUERADE nf_nat_masquerade_ipv6 nf_nat nf_conntrack nf_log_ipv6 nf_log_common ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 bonding ifb ip6_udp_tunnel udp_tunnel qca_nss_drv qca_nss_dp udp_diag tcp_diag raw_diag inet_diag tun qca_ssdk vfat fat ntfs nls_utf8 nls_iso8859_1 nls_cp437 mtdoops uas usb_storage gl_fan_driver xhci_plat_hcd xhci_pci xhci_hcd dwc3 dwc3_qcom dbm uhci_hcd ohci_platform ohci_hcd phy_msm_ssusb_qmp phy_msm_qusb ehci_platform sd_mod scsi_mod kmwan ehci_hcd gpio_button_hotplug gl_sdk4_tertf gl_sdk4_black_white_list usbcore nls_base usb_common mii gl_sdk4_hw_info
<0>[187746.558282] Kernel panic - not syncing: Fatal exception
<2>[187746.558768] CPU2: stopping
<4>[187746.564144] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D 4.4.60 #0
<4>[187746.566666] Hardware name: Generic DT based system
<4>[187746.573961] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[187746.578740] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[187746.586724] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[187746.593841] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[187746.601480] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[187746.608942] Exception stack(0x9e48df88 to 0x9e48dfd0)
<4>[187746.616578] df80: 00000001 00000000 00000000 8000b400 9e48c000 808364a0
<4>[187746.621705] dfa0: 806d2f48 00000000 00000000 8082f30c 9e48dfe0 808364a8 60000013 9e48dfd8
<4>[187746.629949] dfc0: 80019394 80019398 60000013 ffffffff
<4>[187746.638194] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[187746.643322] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[187746.650874] [<80063664>] (cpu_startup_entry) from [<4100946c>] (0x4100946c)
<2>[187746.659028] CPU3: stopping
<4>[187746.666312] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 4.4.60 #0
<4>[187746.668835] Hardware name: Generic DT based system
<4>[187746.676129] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[187746.680907] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[187746.688893] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[187746.696010] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[187746.703649] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[187746.711110] Exception stack(0x9e48ff88 to 0x9e48ffd0)
<4>[187746.718747] ff80: 00000001 00000000 00000000 8000b400 9e48e000 808364a0
<4>[187746.723875] ffa0: 806d2f48 00000000 00000000 8082f30c 9e48ffe0 808364a8 60000013 9e48ffd8
<4>[187746.732120] ffc0: 80019394 80019398 60000013 ffffffff
<4>[187746.740363] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[187746.745490] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[187746.753042] [<80063664>] (cpu_startup_entry) from [<4100946c>] (0x4100946c)
<2>[187746.761198] CPU0: stopping
<4>[187746.768483] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G D 4.4.60 #0
<4>[187746.771005] Hardware name: Generic DT based system
<4>[187746.778299] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[187746.783078] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[187746.791063] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[187746.798181] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[187746.805820] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[187746.813282] Exception stack(0x80835f50 to 0x80835f98)
<4>[187746.820917] 5f40: 00000001 00000000 00000000 8000b400
<4>[187746.826046] 5f60: 80834000 808364a0 806d2f48 00000000 00000000 8082f30c 80835fa8 808364a8
<4>[187746.834292] 5f80: 80835f48 80835fa0 80019394 80019398 60000013 ffffffff
<4>[187746.842537] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[187746.849396] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[187746.856779] [<80063664>] (cpu_startup_entry) from [<807f7d28>] (start_kernel+0x430/0x43c)
<0>[187746.864937] The reading for sensor 4 is 0x002042a8
<0>[187746.873260] The reading for sensor 5 is 0x002052ab
<0>[187746.878034] The reading for sensor 7 is 0x002072a4
<0>[187746.882895] The reading for sensor 8 is 0x0020829a
<0>[187746.887758] The reading for sensor 13 is 0x0022d2ab
<0>[187746.892666] Couldn't get reading for sensor 14
<0>[187746.897827] The reading for sensor 15 is 0x0020f2a8
