Kernel Panic / Wi-Fi Drop on GL-MT3600 (Beryl) - Firmware 4.9.1 (mt_wifi driver bug)
Hello everyone,
I've been experiencing constant Wi-Fi drops on my GL-MT3600BE (Beryl 7) running firmware 4.9.0 and 4.9.1. Devices would randomly disconnect because the router's radio was crashing.
After checking the logs, I found a clear Kernel Panic caused by the proprietary MediaTek mt_wifi driver. It seems to crash when the router attempts to manage power states (LPI) or switch channels while MLO is active.
Here is a snippet from my crash.log:
Internal error: synchronous external abort: 96000210 [#1] SMP ... MtAsicSetLpi+0x1534/0x1750 [mt_wifi] hif_io_read32+0x38/0x48 [mt_wifi] BcnCheck+0x274/0x5a8 [mt_wifi] ... 7993@ERROR.RA,rai2,UniCmdSetRecSecPnInfo() 6006: wdev is null!
The Workaround: I managed to completely stabilize the router by doing two things:
  1. Disabling MLO (Multi-Link Operation).
  2. Changing the 5GHz channel from "Auto" to a fixed, non-DFS channel (e.g., 157).
Once MLO is disabled and the channel is fixed, the Kernel Panics stop entirely.
Could the dev team please look into this mt_wifi driver bug and include a fix in the next firmware release? I can provide the full crash logs if needed. Thank you!
We tested this locally on an MT3600BE running firmware v4.9.1 with MLO enabled and the 5 GHz channel set to Auto. We also generated continuous Wi-Fi traffic and manually changed the 5 GHz channel several times while MLO was enabled, but so far we have not been able to reproduce the same kernel panic.
Could you please share the exact steps and Wi-Fi configuration that usually lead to the issue on your device? For example, what clients are connected when it occurs, whether an MLO client is connected, any Wi-Fi settings that differ from the defaults, and approximately how long or after what operation the crash normally occurs.
If the issue occurs again, please also send us the complete Crash Log and System Log via private message.
Thank you for your understanding and support.
Thank you for looking into this!
I believe I know why you couldn't reproduce the issue in your lab. You mentioned that you generated continuous Wi-Fi traffic. However, the kernel panic occurs specifically in the MtAsicSetLpi function (Low Power Idle). Because you had continuous traffic, the router likely never entered the LPI state.
Additionally, my Wi-Fi configuration had a very specific non-default setup that might be causing the wdev is null error:
My Exact Configuration:
  1. The MLO network was ENABLED.
  2. The dedicated 2.4 GHz Main Network was DISABLED (toggle turned off in the UI).
  3. The 5 GHz Main Network was ENABLED and set to "Auto" channel.
  4. I was running an AmneziaWG (WireGuard) client on the router.
Connected Clients: a couple of phones, an iPad, and maybe a couple of other low-power devices.
How the crash occurs: It does not happen under heavy load. It happens randomly when the network is mostly idle (allowing LPI to kick in) AND the router performs an automatic DFS channel switch in the background. My system.log shows IEEE 802.11 driver had channel switch just moments before the router reboots.
So, the crash formula seems to be: Disabled 2.4GHz radio + Enabled MLO + Idle clients (LPI active) + Background DFS channel hop.
I have just sent you my complete crash.log and system.log via private message as requested. Let me know if you need me to test any beta firmwares with a potential fix!
I recently purchased the Beryl 7 and I’m seeing very similar wdev is null / TXS_STS_* errors in the kernel logs on firmware 4.9.0.
So far I haven’t experienced any crashes or reboots, but I will keep an eye on it.
One other thing I noticed is relatively high memory usage. The router normally sits around 90–92% memory usage and I’ve seen it go as high as 94%.
My configuration is not exactly the same as yours, so I’m not sure whether the same conditions apply. I’ll continue monitoring and can provide logs if that would be useful.
Since I only recently purchased the Beryl 7, I’d also be interested to know whether a newer/beta firmware with a potential fix is available for testing.
Sorry for the delayed follow-up, and thank you for sharing the logs and detailed conditions under which the issue occurred.
We will continue trying to reproduce the kernel panic with the setup you described and investigate the driver errors. If we have any new findings, we’ll update you here.
Thank you for your patience and support.
Thank you for your feedback.
To help us better understand the driver errors and memory usage, could you please provide the following information?
  1. Please export the System Log and send it to us by private message.
  2. When memory usage reaches around 90–94%, could you please log in to the router via SSH and send us the output of
free -h
top -b -n 1
  1. Could you also let us know whether you have enabled any other features on the router?
  2. Could you also share your MLO Wi-Fi configuration, including whether MLO is enabled, the status of the 2.4 GHz and 5 GHz Main Networks, and the 5 GHz channel setting?
How to export logs:
How to send private messages:
How to SSH Log in to the Router:
I have been experiencing same crashes as the OP since I first purchased the Beryl 7.
Thank you for the feedback.
To better understand your situation, could you please provide some information?
  1. Could you please let us know your current setup, including the firmware version and which Wi-Fi features/settings are enabled, such as MLO, 2.4 GHz / 5 GHz settings, Auto Channel, etc.?
  2. Could you also describe what exactly happens when the issue occurs? For example, does only Wi-Fi disconnect, does the router reboot, or do you see a kernel panic / crash?
  3. If convenient, please export the logs from SYSTEM → Log after the issue occurs and send them to us via private message so we can take a closer look.
How to export logs:
Hi I am seeing the same thing on my side, seems to be derived from specific smart home devices. I've tried turning off MLO, Wifi7, a static DFS to no avail.
To help us better understand your situation, could you please provide the following information?
  1. When the issue occurs, do individual devices disconnect, do all Wi-Fi devices lose connectivity, or does the router restart?
  2. How often does this happen, and does the connection recover automatically or require a router restart?
  3. After the next occurrence, could you please note the approximate time, export the System Log from SYSTEM → Log, and send it to us by private message?
Thank you for your patience and help with troubleshooting.
