Beryl 7 (GL-MT3600BE) 4.9.0 — kernel BUG in cfg80211_scan_done after HWCtrlQ overflow / FW cmd timeout in repeater mode (hotel Wi-Fi)
### Setup
- Device: GL-MT3600BE (Beryl 7), firmware 4.9.0 (kernel 5.4.281, build Jul 2 2026)
- Mode: Repeater, 5 GHz uplink to hotel Wi-Fi (Ruckus AP, no captive portal detected)
- Uplink MLO disabled on the client (`ApcliMloDisable = 1`)
- Local Wi-Fi: MLO network enabled, all clients on it (BSS2, mld_grp_idx=1)
- Two WireGuard clients enabled
- No ethernet available, so repeater is the only uplink option
### Problem 1: Kernel crash and reboot after ~4h56m uptime
Every client on the router drops when this happens. The crash log shows the driver's hardware control queue overflowing on both the AP interfaces and the uplink, then a firmware command timeout, then the uplink going down, then a kernel BUG while finishing a scan:
7993@ERROR.HW,apclii0,HwCtrlEnqueueCmd() 691: ---> HWCtrlQ size (1088) overflow!!
7993@ERROR.HW,ra3,HwCtrlEnqueueCmd() 691: ---> HWCtrlQ size (1088) overflow!!
WiFi@ERROR.FW,UniCmdResultToRsp() 52: id=0x26,eid=0x0 cmd timeout
7993@ERROR.HIF,ra3,hwifi_mcu_tx() 1557: send cmd fail! ret -110
7993@ERROR.MLME,apclii0,MlmeEnqueueWithWdev() 5173: wdev(1) state: if down!
kernel BUG at backports-6.5/net/wireless/core.h:125!
Internal error: Oops - BUG: 0 \[#1\] SMP
CPU: 1 PID: 9294 Comm: RtmpCmdQTask_01 Tainted: P W 5.4.281 #0
pc : cfg80211_scan_done+0xcc/0xd0 \[cfg80211\]
lr : CFG80211OS_ScanEnd+0x94/0x150 \[mt_wifi\]
Call trace:
 CFG80211_ScanEnd+0x34/0xc8 \[mt_wifi\]
 CalStaTxLatency+0x468/0xe68 \[mt_wifi\]
 CMDHandler+0x184/0x360 \[mt_wifi\]
 RTPCICmdThread+0x110/0x2c8 \[mt_wifi\]
It looks like the driver completes a scan for apclii0 after the interface has already been torn down. The `cmd timeout` / `ret -110` matches what was reported in the 4.9.0 group-rekey thread, but here it ends in a kernel crash instead of a silent stall:
The crash log only contains the tail of the event, so I can't see what triggered the queue overflow (rekey, roam, etc.).
### Problem 2: Clients dropping on the MLO network between crashes
Within 10 minutes of the reboot, with the uplink connected and stable:
- `UniCmdSetRecSecPnInfo() 6006: wdev is null!` x17, all on ra2/rai2 (the MLO BSS)
- Repeated `PMF_MlmeSAQueryReq ... Send SA Query Request` to clients on ra2/rai2, consistent with clients reconnecting while the AP still holds their keys
- One client associated 5 times within 1 second on 2.4 GHz, then moved to 5 GHz
- WiFi@ERROR.MLO,parse_tid_to_link_map_ie(): error -1\ x4
This looks related to the MLO kernel panic thread:
### Questions
1. Is the cfg80211_scan_done BUG after HWCtrlQ overflow a known issue on 4.9.0? Is a fix planned for the re-released 4.9.1 or a beta I can test?
2. Is there a recommended configuration for hotel repeater use until then?
I have the full log export (crash.log, kernel.log, system.log) and can send it by private message. I'm happy to test beta firmware.
Sorry for the late reply, and thank you for the detailed report.
To help us investigate and reproduce the issues, could you please provide the following?
  1. Has the reboot happened multiple times, and does it usually occur after a similar period of uptime? Does it happen during active use, while idle, or when a device reconnects?
  2. If it is convenient, could you please provide Wireless settings, along with the hotel Wi-Fi’s security mode, channel, and channel width?
  3. Which device models are affected, and do all clients disconnect together or only specific devices?
  4. Could you please send the full log export you mentioned (crash.log, kernel.log, and system.log) via private message?
Thank you for your help with the investigation.
How to send private messages:
