Actually when using kernel 5.4 and 64bit system on AXT1800, Openvpn is up to 600Mbps, same as Wireguard.
But as 64bit system has various problems, eventually not used for release.
Sad! Any chance we could make a test build in the infra builder and mess with it? (Maybe patch it?)
Is this a modem you’re planning to release?
I’d absolutely love to use OpenVPN with the full 600mbps speed! Really hope that a future modem will support it
It is just kernel upgrade and hardware acceleration for AES.
As most users use Wireguard which reach up to 600mbps already, the demand for openvpn is not that high.
Unless you actually want to use it in production ![]()
Wireguard is great for basic stuff, but once you start adding any more complicated routing, or have to manage hundreds of devices it becomes unworkable quickly.
Possible to get banip type of software to ban countries like Russia, China, Romania, etc. ?
I’d like to block those connections completely. ![]()
Also, a monthly WAN bandwidth tracker would be nice.
a way to send device name to nextDNS?
DNS-over-HTTPS or DNS-over-TLS?
I’m using nextDNS parent control feature, but for now, I can only block websites in general since I can’t send the device name along with the queries.
thanks
It looks like the feature is in recent routers for NextDNS.
This is on the GL-A1300 Slate Plus (also on the GL-MT2500 Brume 2):
V2ray client would be highly appreciated! Could this be supported natively so it could work with a kill switch and glinet gui and not via luci?
A native speed test would be nice. ![]()
DNS Rebinding Attack Protection
Add whitelist,
Reason:
I’m a developer, and I’m working with nip.io to allow me to work with subdomain on my machine, if I turn on the DNS rebinding attach protection, it doesn’t work obviously.
Thanks
This option is disabled in firmware 4.x by default.
right, that’s what I do right now, but it would be nice not to disable completely, but to have just a set of domains that could bypass that feature (whitelist)
You’ll need to install NextDNS & luci-app-nextdns through plugins. After that just set it up in LuCi
strangely I don’t neither plug-ins when search, even after I hit update button on the top right. ![]()
Thanks though
I believe you’ll need to be running firmware V4 ![]()
@Blobbie01 ah thanks! I don’t think the gl-inet team are not there yet for this for the Velica routers. I’ll have to wait. Thanks for you replies though.
It would be nice to be able to automatically download txt/lst from the url (VPN Policy Base on the Target Domain or IP)
With the ability to automatically update at a certain point in time!
Option: Allow the user to turn the guest network on/off with one of the switches of the Slate AX.
Reasoning: As a travel router, it’s super handy to have your guest-network SSID match your home SSID & credentials. Everything you & family carry will then Just Work. But this means you can’t power up your travel router when home, or the identical SSID will cause odd problems. Solution: An option to allow one of the toggle switches to turn the guest-network on or off.
