Ine feature I would find useful is a status on the internet connection when failover or load balancing is being used. On the Internet page, put some sort of indicator as to which internet connection(s) is currently connected.
When making a Wireguard Client the configuration file has no public/private key.
I connect to my own Wireguard Server on my OPNSense firewall. If I use the Mac Client or the Windows client when I made a configuration file it has a key-pair. The GL.iNet configuration is just 100% blank.
I had to make a client configuration in the Mac OS WireGuard client and cut and paste it into GL.inet. It worked. Wasn’t that difficult but a manual entry config file with a private and public key ready to go would be awesome.
Being able to expand the device storage space by using a microSD card to extend the internal memory and features of the device, like network storage on the MT1300 fw4… Or am I just being daft?
quando esce la versione 4.5.0 stabile?
Hello, is possible to select a custom tailscale server? I have everything set up on headscale but how can I use this on the glinet router?
Can we get support for Mullvad Exit Nodes in Tailscale? I’m using the Slate AX but can’t get it to work at all, I believe this may be because the Tailscale version being used on the router (1.32.2-1) seems to be pretty far behind the official version (1.48.2)
Maybe even display an icon that looks like your device while you are at it as well! My Brume 2 does not have antennas. ![]()
I don’t have problems with the icon on AR750S Slate and AR750 Creta, I feel sorry for you.![]()
Sorry for the heads up about this but adding a field to type in the tailscale control server would be something very easy to implement, as of today I have to use headscale + goodcloud and is something ridiculous in my opinion
Please consider a function to monitor WAN link data usage, and provide a way to set/monitor/reset/block data usage to avoid data cap overages.
The feature has been detailed here:
+1 for this feature request!
Please why not add feature to obfuscate openVPN/wireguard somehow.
if there were a way to put cellular routers into “ip pass through” mode it would be awesome
see here
This is very interesting!
I have the Sonoff NSPANEL PRO and it has so many issues that I’m thinking to throw it away.
obfs4proxy: Yawning Angel / obfs4 · GitLab
Edit: people have actually attempted this (using it with a VPN) and I think there are some guides out there.
It needs to be installed in both server and client.
I think GL should have it’s own VPN servers, it’s going to be easier for us and also GL can make money, most of your products are for travelers who need VPN, so why not run the service too.
@alzhao
I would like a Flow page so we can see where devices are sending traffic too. This is a critical missing piece for this router.
Can DEV please use Netify (the new v4 has packets sent/recv) agent to gather SNI, IP, Port and save the data to a database on the SD/USB drive, then display it in a UI, similar to how Firewalla does it?
