Many log data after 4.4.5 (axt1800 & mt2500)
Sat Aug 26 21:23:00 2023 cron.err crond[3984]: USER root pid 2357 cmd . /lib/functions/modem.sh;check_ip
Sat Aug 26 21:23:00 2023 cron.err crond[3984]: USER root pid 2358 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Sat Aug 26 21:24:00 2023 cron.err crond[3984]: USER root pid 4468 cmd . /lib/functions/modem.sh;check_ip
Sat Aug 26 21:24:00 2023 cron.err crond[3984]: USER root pid 4469 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Sat Aug 26 21:25:00 2023 cron.err crond[3984]: USER root pid 6565 cmd . /lib/functions/modem.sh;check_ip
Sat Aug 26 21:25:00 2023 cron.err crond[3984]: USER root pid 6566 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Sat Aug 26 21:26:00 2023 cron.err crond[3984]: USER root pid 8594 cmd . /lib/functions/modem.sh;check_ip
Sat Aug 26 21:26:00 2023 cron.err crond[3984]: USER root pid 8595 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Sat Aug 26 21:27:00 2023 cron.err crond[3984]: USER root pid 10590 cmd . /lib/functions/modem.sh;check_ip
Sat Aug 26 21:27:00 2023 cron.err crond[3984]: USER root pid 10591 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Sat Aug 26 21:28:00 2023 cron.err crond[3984]: USER root pid 12678 cmd . /lib/functions/modem.sh;check_ip
Sat Aug 26 21:28:00 2023 cron.err crond[3984]: USER root pid 12679 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Sat Aug 26 21:29:00 2023 cron.err crond[3984]: USER root pid 14688 cmd . /lib/functions/modem.sh;check_ip
Sat Aug 26 21:29:00 2023 cron.err crond[3984]: USER root pid 14689 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Sat Aug 26 21:30:00 2023 cron.err crond[3984]: USER root pid 16776 cmd . /lib/functions/modem.sh;check_ip
Sat Aug 26 21:30:00 2023 cron.err crond[3984]: USER root pid 16777 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Sat Aug 26 21:31:00 2023 cron.err crond[3984]: USER root pid 18802 cmd . /lib/functions/modem.sh;check_ip
Sat Aug 26 21:31:00 2023 cron.err crond[3984]: USER root pid 18803 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Sat Aug 26 21:32:00 2023 cron.err crond[3984]: USER root pid 20811 cmd . /lib/functions/modem.sh;check_ip
Sat Aug 26 21:32:00 2023 cron.err crond[3984]: USER root pid 20812 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Sat Aug 26 21:33:00 2023 cron.err crond[3984]: USER root pid 22954 cmd . /lib/functions/modem.sh;check_ip
Sat Aug 26 21:33:00 2023 cron.err crond[3984]: USER root pid 22955 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Sat Aug 26 21:34:00 2023 cron.err crond[3984]: USER root pid 24974 cmd . /lib/functions/modem.sh;check_ip
Sat Aug 26 21:34:00 2023 cron.err crond[3984]: USER root pid 24975 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Sat Aug 26 21:35:00 2023 cron.err crond[3984]: USER root pid 26999 cmd . /lib/functions/modem.sh;check_ip
Sat Aug 26 21:35:00 2023 cron.err crond[3984]: USER root pid 27000 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Sat Aug 26 21:36:00 2023 cron.err crond[3984]: USER root pid 29085 cmd . /lib/functions/modem.sh;check_ip
Sat Aug 26 21:36:00 2023 cron.err crond[3984]: USER root pid 29086 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Sat Aug 26 21:37:00 2023 cron.err crond[3984]: USER root pid 31103 cmd . /lib/functions/modem.sh;check_ip
Sat Aug 26 21:37:00 2023 cron.err crond[3984]: USER root pid 31104 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Sat Aug 26 21:38:00 2023 cron.err crond[3984]: USER root pid 734 cmd . /lib/functions/modem.sh;check_ip
Sat Aug 26 21:38:00 2023 cron.err crond[3984]: USER root pid 735 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Sat Aug 26 21:39:00 2023 cron.err crond[3984]: USER root pid 2753 cmd . /lib/functions/modem.sh;check_ip
Sat Aug 26 21:39:00 2023 cron.err crond[3984]: USER root pid 2754 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Sat Aug 26 21:40:00 2023 cron.err crond[3984]: USER root pid 4786 cmd . /lib/functions/modem.sh;check_ip
Sat Aug 26 21:40:00 2023 cron.err crond[3984]: USER root pid 4787 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Sat Aug 26 21:41:00 2023 cron.err crond[3984]: USER root pid 6905 cmd . /lib/functions/modem.sh;check_ip
Sat Aug 26 21:41:00 2023 cron.err crond[3984]: USER root pid 6906 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Sat Aug 26 21:42:00 2023 cron.err crond[3984]: USER root pid 8946 cmd . /lib/functions/modem.sh;check_ip
Sat Aug 26 21:42:00 2023 cron.err crond[3984]: USER root pid 8947 cmd sleep 30;. /lib/functions/modem.sh;check_ip
is it normal?
I think it may be due to Multi-WAN mwan3.
I have same issue
on brume 2 (mt2500)
Sun Aug 27 13:09:00 2023 cron.err crond[4002]: USER root pid 8258 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Sun Aug 27 13:10:00 2023 cron.err crond[4002]: USER root pid 10246 cmd . /lib/functions/modem.sh;check_ip
Sun Aug 27 13:10:00 2023 cron.err crond[4002]: USER root pid 10247 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Sun Aug 27 13:11:00 2023 cron.err crond[4002]: USER root pid 12248 cmd . /lib/functions/modem.sh;check_ip
Sun Aug 27 13:11:00 2023 cron.err crond[4002]: USER root pid 12249 cmd sleep 30;. /lib/functions/modem.sh;check_ip
by the way, how to find the crontab of this lines ?
CRontab is located in OpenWRT UI. Go to advance settings and log into UI, ounce there click the Systems Tab and go to schedule tasks. (More then likely there is nothing there) like wcs2228 suggested you will need to play with the settings of the Multi-WAN (mwan3) in the GL.iNet UI.
Scheduled Tasks is empty , MultiWan is Disabled
Did try you save settings log out log back in and reboot
mine has the same errors does it every 30 Sec
Multi-WAN is still enabled. For each WAN connection, only the interval/number of tries settings can be changed in the “gear” icon on the right side. I think the mwan3 service would have to be turned off from starting up to disable it, but I do not know if that would break something else.
It appears that the log messages are “normal” with Firmware 4.4.5 because I did not upgrade my GL-MT2500 and do not get the log messages. Personally, I would just leave them alone and ignore the messages.
The prompt message “Sun Aug 27 13:10:00 2023 cron.err crond[4002]: USER root pid 10246 cmd ./lib/functions/modem.sh;check_ip” itself is not an error, but a problem with the loglevel setting of cron (it It should be an INFO level information), we have fixed this problem in the current firmware, but we need to upgrade it without saving the configuration, or reset after the upgrade; of course, it can also be fixed by manually entering the following command in the device background:
uci set system.@system[0].cronloglevel=“10”
/etc/init.d/gl_timer restart
Hi @SimBot
My AXT1800 responds to this command:
root@router:~# /etc/init.d/gl_timer restart
validation failed
From “root@router” it looks like your firmware is not glinet’s standard firmware
@luxibao
I’ve just edited the host name.
Please show me this page of luci for your device.And use the command to check the device configuration. cat /etc/config/system
@SimBot
Hi!
I rebooted my router after the command: uci set system.@system[0].cronloglevel="10".
After the reboot, there is no mention of cron.err crond in the logs anymore.
Just want to let you know that the command /etc/init.d/gl_timer restart doesn’t work.
Thank you!
BusyBox v1.33.2 (2023-08-11 11:07:43 UTC) built-in shell (ash)
  _______                     ________        __
 |       |.-----.-----.-----.|  |  |  |.----.|  |_
 |   -   ||  _  |  -__|     ||  |  |  ||   _||   _|
 |_______||   __|_____|__|__||________||__|  |____|
          |__| W I R E L E S S   F R E E D O M
 OpenWrt 21.02-SNAPSHOT, r15812+879-46b6ee7ffc
root@GL-MT2500:~# uci set system.@system[0].cronloglevel=“10”
root@GL-MT2500:~# /etc/init.d/gl_timer restart
validation failed
root@GL-MT2500:~#
its Standard Firmware
“etc/init.d/gl_timer restart
validation failed”
Hi! Please try again.
uci commit system
uci show system
I am having the same issue with the new MT-6000. Is this fixed with the latest firmware and do I need to follow the same procedure?
ModelGL.iNet GL-MT6000 4.5.6
Architecture ARMv8 Processor rev 4
OpenWrt Version OpenWrt 23.05-SNAPSHOT r23001+721-38c150612c
Kernel Version 5.15.139
ue Jan 23 19:19:00 2024 cron.err crond[4212]: USER root pid 8876 cmd . /lib/functions/modem.sh;check_ip
Tue Jan 23 19:19:00 2024 cron.err crond[4212]: USER root pid 8877 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Tue Jan 23 19:20:00 2024 cron.err crond[4212]: USER root pid 9102 cmd . /lib/functions/modem.sh;check_ip
Tue Jan 23 19:20:00 2024 cron.err crond[4212]: USER root pid 9103 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Tue Jan 23 19:20:00 2024 cron.err crond[4212]: USER root pid 9104 cmd . /lib/functions/modem.sh;modem_net_monitor
Tue Jan 23 19:21:00 2024 cron.err crond[4212]: USER root pid 9331 cmd . /lib/functions/modem.sh;check_ip
Tue Jan 23 19:21:00 2024 cron.err crond[4212]: USER root pid 9332 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Tue Jan 23 19:22:00 2024 cron.err crond[4212]: USER root pid 9557 cmd . /lib/functions/modem.sh;check_ip
Tue Jan 23 19:22:00 2024 cron.err crond[4212]: USER root pid 9558 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Tue Jan 23 19:22:00 2024 cron.err crond[4212]: USER root pid 9559 cmd . /lib/functions/modem.sh;modem_net_monitor
Tue Jan 23 19:23:00 2024 cron.err crond[4212]: USER root pid 9784 cmd . /lib/functions/modem.sh;check_ip
Tue Jan 23 19:23:00 2024 cron.err crond[4212]: USER root pid 9785 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Tue Jan 23 19:24:00 2024 cron.err crond[4212]: USER root pid 10078 cmd . /lib/functions/modem.sh;check_ip
Tue Jan 23 19:24:00 2024 cron.err crond[4212]: USER root pid 10079 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Tue Jan 23 19:24:00 2024 cron.err crond[4212]: USER root pid 10080 cmd . /lib/functions/modem.sh;modem_net_monitor
Tue Jan 23 19:25:00 2024 cron.err crond[4212]: USER root pid 10277 cmd . /lib/functions/modem.sh;check_ip
Tue Jan 23 19:25:00 2024 cron.err crond[4212]: USER root pid 10278 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Did you try this?
 OpenWrt 23.05-SNAPSHOT, r23001+721-38c150612c
root@GL-MT6000:~# uci set system.@system[0].cronloglevel="10"
root@GL-MT6000:~# uci commit system
root@GL-MT6000:~# uci show system
system.@system[0]=system
system.@system[0].hostname='GL-MT6000'
system.@system[0].timezone='EET-2EEST,M3.5.0/3,M10.5.0/4'
system.@system[0].ttylogin='1'
system.@system[0].log_size='64'
system.@system[0].urandom_seed='0'
system.@system[0].compat_version='1.0'
system.@system[0].cronloglevel='10'
system.@system[0].zonename='Europe/Bucharest'
system.@system[0].log_proto='udp'
system.@system[0].conloglevel='8'
system.ntp=timeserver
system.ntp.server='0.openwrt.pool.ntp.org' '1.openwrt.pool.ntp.org' '2.openwrt.p                                ool.ntp.org' '3.openwrt.pool.ntp.org'
root@GL-MT6000:~# /etc/init.d/gl_timer restart
root@GL-MT6000:~#
So please wait a day or two and check if the log noise stopped.
