2 things I’m trying to get working.
1st:
- chromecast is connected to main gl inet wifi
- guest is on guest wifi
- guest should be able to cast to device on main network aka mDNS across vlans
2nd:
- same as 1, but chromecast is connected to host network
- gl inet device is repeating (or Ethernet connected) to host router
Is this possible? I want to be able to temporarily allow guests to use the Chromecast without having to connect everyone to the main network
For 1, I tried adding a firewall rule to allow everything across main/guest networks but no luck, like
For 2, I wouldn’t know how to start. Allow WAN to LAN on mDNS? I think I covered that with some rules
I’ve also turned on avahi reflector:
[server]
#host-name=foo
#domain-name=local
use-ipv4=yes
use-ipv6=yes
check-response-ttl=no
use-iff-running=no
[publish]
publish-addresses=yes
publish-hinfo=yes
publish-workstation=no
publish-domain=yes
#publish-dns-servers=192.168.1.1
#publish-resolv-conf-dns-servers=yes
[reflector]
enable-reflector=yes
reflect-ipv=no
[rlimits]
#rlimit-as=
rlimit-core=0
rlimit-data=4194304
rlimit-fsize=0
rlimit-nofile=30
rlimit-stack=4194304
rlimit-nproc=3
But still no idea how I can get Chromecast devices show up on my gl-inet devices when the chromecast is connected to the upstream network.
The best solution would be something I can quickly turn on/off
