Meet Mudi 7 (GL-E5800) & Thanksgiving Giveaway
It's close to the Slate AX, and a bit stronger, I mean WireGuard speed.
I think it may not support this USB-C to RJ-45 peripheral.
You’re referring to IP68, right?
What about flashing to vanilla OpenWRT?
I honestly don't remember what it was originally with my Slate AX. but I guess we can probably use something like this with the side USB port? Amazon.com: SANDISK 512GB Extreme Fit USB-C Flash Drive - Up to 400MB/s Read speeds, USB 3.2 Gen 1, USB Type-C - Plug-and-Stay Storage - Black - SDCZ530-512G-G46 : Electronics
Yes, we did design these functions on the screen, which will be more convenient to use.
Congratulations to whoever won on the 23rd.
Will you be responding to Ubiquiti?
The Mudi 7 obliterates that travel router
Yes. The cost will be higher.
Vanilla OpenWRT may not be supported.
It supported for mobile storage, tethering, etc.
But not support various USBC-RJ45 network adapter, wireless network adapter, etc.
I believe the Mudi 7 is absolutely an all-rounder.
What can a piece of paper-thin battery do, with such short battery life? And the WiFi 5? It sacrificed everything just to keep it slim — Completely pointless.
that's fine; that's all I need!
it's goofy, honestly. adding this to my pile of reasons I tell people “friends don't let friends buy UBNT” :stuck_out_tongue: I know people really like their management software but I would much rather have the built in freedom to use LuCi, etc. as needed. Mudi 7 is just a wildly more powerful device.
Will Glinet hit back with a roast video?
In other words, highly unlikely, and this will be e-waste after support ends. I'm guessing the Mudi 7 won't have a MediaTek chipset.
I don't disagree with you, but if you're not going to implement vanilla OpenWRT support, please support the Mudi 7 for at least 5 years. GL.iNet must and can do better. I've supported you guys with the Beryl AX and Slate 7!
If the modem is Quectel, GL tend to marry it up with a Qualcomm Atheros CPU.
See Collie, Spitz, Puli, and the original Mudi.
The only exceptions to this is the Spitz AX and the Puli AX.
Now if it is a Qualcomm, it's probably an ipq5312.
Now the e5800 name suggests it is a BE5800 device, the only other device with this is the Netgear MR7400.
We’re not that bored! We just want to do our own thing well.
There will certainly be at least 5 years of the Mudi 7 firmware support. Even if the SDK can’t be updated with new features after 4 years, they will still be maintaining security updates, for example Spitz:
That’s awesome. I don’t think Chinese companies have a reputation in the West for long-term support. Maybe you can pass this to your other team members and CEO. I would hope GL.iNet would make a similar statement like how Apple, Google, and Samsung would update their products. Five years is great. The longer, the better. A firm statement would inspire confidence in your products.
Maybe in a future update of the Mudi, consider making a separate battery charger? I could see the Mudi being heavily used, and swapping batteries may be helpful. It’s probably an edge case. An even better idea? Add a USB-C port to the battery and let it be charged outside of the Mudi. Please still consider selling the battery separately.
Thank you!
Yep, if sell the batteries individually, I think a battery charging dock should be considered for sale.
