I see where I can modify the LAN IP of the Opal (GL-SFT1200) router but I’ve tried changing the subnet mask by entering “192.168.0.1/16” to enter a mask of 255.255.0.0 and the “/16” isn’t accepted. I don’t see a “subnet” or “subnet mask” box in the web interface as shown here:
The above picture came from:
Does anyone know where I can find the options for modifying the subnet mask? Thanks,
I appreciate the quick reply but where you have a “netmask” field below the default gateway textbox, I don’t have a field to enter 255.255.0.0 or /16. The gateway is at a customer site at the moment but I should be able to swing by tomorrow to take a screenshot.
I’m pretty sure when I clicked on “Guest Network” there was a radio button and “Enable” was set to “off” so I just left it disabled (it’s not needed).
I have SSH access to everything on the network, including the Opal, but I don’t have a way to look at the web GUI remotely.
