I have a little SFT-1200 that I use for as a wireless connection to multiple small LANs at different locations.
The issue is from what I understand, the LAN side is limited to /24. And I need open up the LAN side to access devices that range from 10.52.18.1 thru 10.52.20.255
After a little online searching regarding this issue, I’ve seen screenshots that show the subnet mask can be modified, but the attached screenshot shows what I see. Basically, it states that the LAN is limited to /24 and I cannot modify the subnet at all.
Right now when I move between .18, .19 and .20 networks I have to log into the Opal and change the LAN IP to the local subnet.
Am I truly limited to 255 devices on the LAN side, or am I missing a setting somewhere?
Here is a link to this issue, but I do not have the capability to edit the mask on the guest network either…?
[Modifying subnet mask on Opal (GL-SFT1200)]
Thanks.
