MT-3000 versus AC-1300 OpenWRT, Firmware and EAP
Hi, I'm a school student in the UK choosing between the Beryl AX (MT3000) and Slate Plus (AC1300) to connect to university Eduroam networks, that non-negotiably require EAP. I do not have either router yet.
I need stable EAP access (with some kind of years-long future path) by ~July 2025.
I would prefer the Beryl AX due to its price to performance.
The following points will address the MT3000:
I've found that the Open-source OpenWRT firmware (4.6.x?) seems to support EAP?
I would like to use vanilla OpenWRT (relevant in question 2.)
  1. Is EAP working for the 4.6.6 "OpenWRT Native" Release Candidate firmware?
    GL.iNet download center
    Beryl AX at hotel / repeater mode not working - #4 by alzhao
  2. If I use SYSUPGRADE to use vanilla OpenWRT, will this use the "Native" driver/firmware in (1.) and make EAP work? Or are the two steps separate (I have to install the open firmware then sysupgrade)?
  3. I also hope vanilla OpenWRT will continue supporting the MT3000.
  4. Will the "Native" firmware continue to be maintained far into the future?
  5. Are there plans to make the "Native" firmware the default for future firmware versions?
  6. Otherwise, are there plans to get EAP working in the "non-Native" firmware?
If the future of EAP on the MT3000 is uncertain, is it safer to buy the less-performant AC1300 instead?
Simple, just use the op24 firmware for Beryl AX
https://dl.gl-inet.com/router/mt3000/open
It supports EAP.
We also tried Eduroam and it works OK. Check out here
Brilliant, thank you. Do you have plans to continue EAP support into 2025?
Yes. Once the firmware support EAP, it will be there until end of life.
Thank you! :slight_smile:
I've got the MT-3000 working well with eduroam in repeater mode using 4.6.6-op24 firmware. I had an issue with constant dropouts from the eduroam wifi (but not to the MT-3000) which I solved by disabling the 'Interface Service Track' on repeater mode under the Multi-Wan menu. Does anyone know if the latest native firmware will support EAP eduroam repeater mode?
I guess that you should stay in the op24 firmware.
