MT3000 2.4GHz network Disappearing
My MT3000 is on firmware 4.1.2 release 4 .
It was working perfect on 4.1.2 release 2 with factory SSID’s.
After upgraded to 4.1.2 release 4 , I have done a reset and changed the SSID’s to match my previous router (AR750S) as all I am not looking forward to reassosciate all my IoT Devices to a new SSID.
Router Temp is hovering at about 68 celsius with no plugins enabled other tham SMB and DLNA.
Uptime : 1d 16h
Problems encountered:
  1. The 2.4GHz SSID name doesn’t come up always when trying to connect to wifi and also if it comes, I can not connect to it always.
  2. The 2.4GHZ SSID seems to kick out some devices and I am not sure why. I have attached here the logs that I can see form Luci ( both System and Kernel logs).
  3. If I manage to connect to the 2.4GHz SSID, the speeds are very slow ( didn’t manage to do a speed test sadly)
  4. Wifi channgel for the 2.4GHz SSID is set to 10 and I have scanned to make sure the spectrum is free in that area. I live in the country side so I don’t have interference.
  5. My AR750S is unplugged so I am very sure there is no problem like having 2 routers with the same SSID connected.
I am happy to perform some diagnosis with guidance as I purely loved thsi router when I was on it’s own. I will factory reset it and use it with the factory programmed SSID now to see how that works though it will not have so many devices on it like has now.
My total IoT devices number is abour 30 devices so it is not a huge clients pool.
Best Regards,
Misujr
System&KernelLogsMisujr_MT3000.zip (21.9 KB)
Ar750s unplugged meaning it’s not powered on ?
Just my own preference/opinion/suggestion
Make it a habit to use either channel 1, 6 or 11 for 2.4 wifi (use 20mhz width)
You can try different wifi mode (with or without ax, or with or without b) to see which is more compatible with your iot
Use only wpa2-psa for wifi security
IoT devices generally have poor Wi-Fi compatibility, so please check the Wi-Fi Mode to ensure it is the same as the ar750s settings. I suspect that this may have been caused by ax.
Also, please try to test with version 4.2 if it is easier for you. Because issues found will be fixed in the new version and not 4.1.2. Thanks.
I have tried channels 6 and 11 but the result seems to be the same.
I will try the to use a different wi-fi mode without ax now and see if that makes any difference.
My AR750s was having the same settings but indeed without the ax mode.
For security I only use WPA2-PSK as the ar750s was set the same.
Best Regards,
Misujr
I will try without the ax mode. Most of my IoT Devices are based on esp32 and programmed by me so I am in control of the firmware and settings but even if the esp32 is not always a great solution, I am sure there will be customers that face the same issue in the future so if I find a solution, that will be helpful for those customers also :-).
I have matched the settings of my ar750s with the expection of the ax mode but now I have switched the MT3000 to use b/g/n and hopefully this will solve the problem. I will monitor and update the status in 1-2 days.
I have updated now to v4.2 beta 2 and will test :slight_smile:
Thank you and @bOcy for the support.
Best Regards,
Misujr
You were using b/g/n/ax previously ?
To be honest my experience so far, 2.4g ax is much more backwards compatible than 5g ax
I have tried both b/g/n/ax and g/n/ax but the result was the same as in the IoT devices were having the same problems.
For me it is the first time using ax so I am learning just now about the compatibility issues :smiley: .
In 5GHz I only use my phones and a few laptops and I didn’t notice any problem though I am using a/n/ac/ax .
Well there’s also this difference between a750s and mt3000: former is Qualcomm chipset and latter mediatek chipset
I understand this but most customers will be less technical than us, the ones testing or the team that builds the firmware and the routers so their experience should be as smooth as possible and where issues can occur, it should be labeled for them. In my work life I am a product integrator and I have faced both development teams and customers so there is a balance to be made in the final product :slight_smile:
Can you provide the firmware and model number of the IoT device? We would like to install the same firmware into the development board to debug Wi-Fi compatibility.
Sure, I am using M5 atom lite as a platfrom with these sensors and I have programmed them with ESPHome to run on Home Assistant . I am using the latest version of Home Assistant and ESPHome but if needed, I can provide the exact version.
The Yaml file used to program the M5 Atom is :
esphome:
esp32:
  board: m5stack-atom
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "eXh5TvtGe1ybPAPZThCQUcGWycF4kIzyKp0epWHf4qM="
ota:
  password: "fceb4ac977dbfbe73a80eaf8bbd06678"
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_password
  # Enable fallback hotspot (captive portal) in case wifi connection fails
  ap:
    ssid: "Bedroom Fallback Hotspot"
    password: "aC0PYJyt1wXR"
captive_portal:
i2c:
  sda: 26
  scl: 32
  scan: true
sensor:
  - platform: sht3xd
    i2c_id: bus_a
    temperature:
      name: "Bedroom Temperature"
    humidity:
      name: "Bedroom Humidity"
    address: 0x44
    update_interval: 60s
Aside from these, I also use a Shelly Plus 1 Relay with firmware : 20221206-141227/0.12.0-gafc2404
Warm Regards,
Misujr
We tested ESPHome firmware with your yaml file and it connects to the MT3000 normally. Can you provide the firmware you compiled and tested? It is better to remove the peripherals and leave only the firmware for wifi configuration.
Here is the esp32 log:
[I][logger:258]: Log initialized
[C][ota:469]: There have been 0 suspected unsuccessful boot attempts.
[D][esp32.preferences:113]: Saving 1 preferences to flash...
[D][esp32.preferences:142]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[I][app:029]: Running through setup()...
[I][i2c.arduino:175]: Performing I2C bus recovery
[C][wifi:037]: Setting up WiFi...
[C][wifi:038]:   Local?MAC: E8:31:CD:08:4B:B8
[D][wifi:386]: Starting scan...
[D][wifi:401]: Found networks:
[I][wifi:445]: - 'GL-MT3000-241' (94:83:C4:28:32:43) �y�{�}��
[D][wifi:446]:     Channel: 5
[D][wifi:447]:     RSSI: -60 dB
[D][wifi:450]: - 's10-production' (E4:95:6E:47:8C:D4) �y�{�}��
[D][wifi:450]: - 'Hans' (94:83:C4:08:3B:90) �y�{�}��
[D][wifi:450]: - 'GL-AX1800-0a6-Guest' (94:83:C4:12:E0:A9) �y�{�}��
[D][wifi:450]: - 'GL-MT3000-17c' (94:83:C4:22:71:7E) �y�{�}��
[D][wifi:450]: - 'GL-AXT1800-d7e' (94:83:C4:18:7D:80) �y�{�}��
[D][wifi:450]: - '1X329-AXT1800-99c-Guest' (96:83:C4:18:59:9E) �y�{�}��
[D][wifi:450]: - 'KNBA5F00002F' (00:A0:03:97:00:8C) �y�{�}��
[D][wifi:450]: - 'GL-AXT1800-b9c' (94:83:C4:18:1B:9E) �y�{�}��
[D][wifi:450]: - '1X326-AXT1800-99c' (94:83:C4:18:59:9E) �y�{�}��
[D][wifi:450]: - 'GL-AX1800-cbc' (94:83:C4:16:EC:BE) �y�{�}��
[D][wifi:450]: - 'GL-AXT1800-d7a' (94:83:C4:18:7D:7C) �y�{�}��
[D][wifi:450]: - 'GL-B1300-dc6' (94:83:C4:06:DD:C6) �y�{�}��
[D][wifi:450]: - 'GL-A1300-898' (94:83:C4:1D:C8:9A) �y�{�}��
[D][wifi:450]: - 'GL-S1300-cb2' (E4:95:6E:47:8C:B4) �y�{�}��
[D][wifi:450]: - 'GL-AX1800-f42' (00:03:7F:12:66:47) �y�{�}��
[D][wifi:450]: - 'GL-AXT1800-da7-23' (94:83:C4:18:7D:A9) �y�{�}��
[D][wifi:450]: - 'test' (E4:95:6E:40:B6:2D) �y�{�}��
[D][wifi:450]: - 'GL-AXT1800-b73' (94:83:C4:22:2B:75) �y�{�}��
[D][wifi:450]: - 'GL-B1300-9aa' (E4:95:6E:45:19:AA) �y�{�}��
[D][wifi:450]: - 'GL-MT1300-21d' (94:83:C4:20:E2:1F) �y�{�}��
[D][wifi:450]: - 'GL-AXT1800-02f' (94:83:C4:1F:30:31) �y�{�}��
[D][wifi:450]: - '' (7C:A1:77:E6:8B:21) �y�{�}��
[D][wifi:450]: - 'GL-MT3000-1a4' (94:83:C4:22:71:A6) �y�{�}��
[D][wifi:450]: - 'GL-AR750S-fd2' (94:83:C4:0B:EF:D2) �y�{�}��
[D][wifi:450]: - 'GL-AR750-0c2' (94:83:C4:06:00:C2) �y�{�}��
[D][wifi:450]: - 'HUAWEI-2G/5GBand' (7C:A1:77:E6:8B:1C) �y�{�}��
[D][wifi:450]: - 'GL-AR750S-c9c' (94:83:C4:07:0C:9C) �y�{�}��
[D][wifi:450]: - 'GL-AX1800-cdb' (00:03:7F:BA:DB:B0) �y�{�}��
[D][wifi:450]: - 'GL-A1300-5da' (94:83:C4:1C:35:DA) �y�{�}��
[D][wifi:450]: - 'JZT-Work' (80:8F:1D:CF:36:22) �y�{�}��
[D][wifi:450]: - 'GL-AR750S-cf1' (94:83:C4:07:7C:F1) �y�{�}��
[D][wifi:450]: - 'GL-SFT1200-978' (94:83:C4:12:59:7A) �y�{�}��
[D][wifi:450]: - 'GL-A1300-838' (94:83:C4:1D:C8:3A) �y�{�}��
[D][wifi:450]: - '187A1-MT3000-230' (94:83:C4:22:72:32) �y�{�}��
[D][wifi:450]: - 'dddd' (94:83:C4:0D:F1:B4) �y�{�}��
[D][wifi:450]: - 'aaaa2gGUEST' (9A:83:C4:0D:F1:B4) �y�{�}��
[D][wifi:450]: - 'GL-INET-2G' (94:83:C4:04:B4:48) �y�{�}��
[D][wifi:450]: - 'GL-Clam-2.4' (94:83:C4:18:7E:2D) �y�{�}��
[D][wifi:450]: - 'KNBA5F000041' (00:A0:03:97:00:C2) �y�{�}��
[D][wifi:450]: - 'GL-MT3000-254' (94:83:C4:22:72:56) �y�{�}��
[D][wifi:450]: - 'GL-A1300-81c' (94:83:C4:1D:C8:1E) �y�{�}��
[D][wifi:450]: - 'GL-MT300N-test' (94:83:C4:10:93:98) �y�{�}��
[D][wifi:450]: - 'GL-A1300-860' (94:83:C4:1D:C8:62) �y�{�}��
[D][wifi:450]: - 'GL-A1300-860-Guest' (96:83:C4:1D:C8:62) �y�{�}��
[D][wifi:450]: - '802.1r-AR750S' (94:83:C4:15:E7:EA) �y�{�}��
[D][wifi:450]: - 'GL-AX1800-84a' (94:83:C4:14:18:4C) �y�{�}��
[D][wifi:450]: - 'GL-A1300-8cb' (94:83:C4:1D:28:CD) �y�{�}��
[D][wifi:450]: - 'GL-AR750S-7ea-Guest' (96:83:C4:15:E7:EA) �y�{�}��
[D][wifi:450]: - '178AX2-AR150-984' (96:83:C4:04:59:84) �y�{�}��
[D][wifi:450]: - 'GL-AR750S-62e-Guest' (96:83:C4:06:26:2E) �y�{�}��
[D][wifi:450]: - 'GL-X750-8c8-Guest' (96:83:C4:03:18:CA) �y�{�}��
[D][wifi:450]: - 'GL-AXT1800-d8b' (94:83:C4:1F:2D:8D) �y�{�}��
[D][wifi:450]: - 'GL-XE300-6e9' (94:83:C4:06:76:EB) �y�{�}��
[D][wifi:450]: - 'GL-MT3000-58f' (94:83:C4:24:45:91) �y�{�}��
[D][wifi:450]: - 'GL-INET-2G' (34:F7:16:AF:BC:11) �y�{�}��
[D][wifi:450]: - '' (36:F7:16:5F:BC:11) �y�{�}��
[D][wifi:450]: - 'GL-AXT1800-9a0' (94:83:C4:18:59:A2) �y�{�}��
[D][wifi:450]: - 'HKGLinet-2G' (94:83:C4:21:EA:61) �y�{�}��
[D][wifi:450]: - 'GL-SFT1200-c82' (94:83:C4:19:CC:84) �y�{�}��
[D][wifi:450]: - 'GL-MT3000-194' (94:83:C4:22:71:96) �y�{�}��
[D][wifi:450]: - 'GL-AX1800-fa4' (94:83:C4:24:4F:A6) �y�{�}��
[D][wifi:450]: - 'GL-AR750S@EAP-62e' (94:83:C4:06:26:2E) �y�{�}��
[D][wifi:450]: - 'GL-S200-6d3' (94:83:C4:23:86:D3) �y�{�}��
[D][wifi:450]: - 'GL-X750-8c8' (94:83:C4:03:18:CA) �y�{�}��
[D][wifi:450]: - 'GL-A1300-8b3' (94:83:C4:1D:28:B5) �y�{�}��
[D][wifi:450]: - 'RMS-668F' (6C:B1:58:CF:66:8F) �y�{�}��
[D][wifi:450]: - 'GL-A1300-8b3-Guest' (96:83:C4:1D:28:B5) �y�{�}��
[D][wifi:450]: - 'A-SLAM' (A8:5A:E0:A4:0C:F4) �y�{�}��
[D][wifi:450]: - 'GL-MT3000-178' (94:83:C4:22:71:7A) �y�{�}��
[D][wifi:450]: - 'GL-AXT1800-d9f' (94:83:C4:18:7D:A1) �y�{�}��
[D][wifi:450]: - 'Youku-2BAD' (54:36:9B:0F:2B:AE) �y�{�}��
[D][wifi:450]: - '' (9A:97:CC:7B:26:3C) �y�{�}��
[D][wifi:450]: - 'RMS-D85D' (EC:60:73:31:D8:5D) �y�{�}��
[D][wifi:450]: - '' (F6:2A:7D:22:08:81) �y�{�}��
[D][wifi:450]: - 'ChinaNet-E9pM' (A0:4C:0C:23:15:02) �y�{�}��
[D][wifi:450]: - 'ChinaNet-2Xjn' (58:C6:7E:B2:A9:94) �y�{�}��
[I][wifi:257]: WiFi Connecting to 'GL-MT3000-241'...
[I][wifi:518]: WiFi Connected!
[C][wifi:362]:   Local MAC: E8:31:CD:08:4B:B8
[C][wifi:363]:   SSID: 'GL-MT3000-241'
[C][wifi:364]:   IP Address: 192.168.8.227
[C][wifi:366]:   BSSID: 94:83:C4:28:32:43
[C][wifi:367]:   Hostname: 'bedroom'
[C][wifi:369]:   Signal strength: -55 dB �y�{�}��
[C][wifi:373]:   Channel: 5
[C][wifi:374]:   Subnet: 255.255.255.0
[C][wifi:375]:   Gateway: 192.168.8.1
[C][wifi:376]:   DNS1: 192.168.8.1
[C][wifi:377]:   DNS2: 0.0.0.0
[D][wifi:527]: Disabling AP...
[C][ota:093]: Over-The-Air Updates:
[C][ota:094]:   Address: bedroom.local:3232
[C][ota:097]:   Using Password.
[C][api:025]: Setting up Home Assistant API server...
[I][app:062]: setup() finished successfully!
[I][app:102]: ESPHome version 2022.11.3 compiled on Jan  4 2023, 11:56:21
[C][wifi:504]: WiFi:
[C][wifi:369]:   Signal strength: -56 dB �y�{�}��
[C][logger:293]: Logger:
[C][logger:294]:   Level: DEBUG
[C][logger:295]:   Log Baud Rate: 115200
[C][logger:296]:   Hardware UART: UART0
[C][i2c.arduino:052]: I2C Bus:
[C][i2c.arduino:053]:   SDA Pin: GPIO26
[C][i2c.arduino:054]:   SCL Pin: GPIO32
[C][i2c.arduino:055]:   Frequency: 50000 Hz
[C][i2c.arduino:058]:   Recovery: bus successfully recovered
[I][i2c.arduino:068]: Results from i2c bus scan:
[I][i2c.arduino:070]: Found no i2c devices!
[C][captive_portal:088]: Captive Portal:
[C][mdns:103]: mDNS:
[C][mdns:104]:   Hostname: bedroom
[C][api:138]: API Server:
[C][api:139]:   Address: bedroom.local:6053
[C][api:141]:   Using noise encryption: YES
Thanks,
kelly
Hi Kelly,
bedroom-factory.bin.zip (617.8 KB)
Please unzip the file ( it was zipped on a Mac so if it makes any issues, try to unzip on a mac) and then use it for the ESP32 device. I will PM you the SSID and password for the Wifi AP .
Thank you for testing the connection with ESP32. My problem comes after a while when the device is connected to the SSID. Let me please try to redescribe the issue :
I can connect the ESP32 to the router after programming while the esp32 is still plugged in my laptop. After this when I disconnect the ESP32 from the laptop and plug it a different power supply to use it, even in the same room, it take a few resets of the esp32 ( using the reset button of the board) to get it to connect to the router ( MT3000) . Once it is connected it will stay mostly connected, but it has random periods of time when the ESP32 disconnects and reconnects or remains disconnected and it exposes it’s fallback AP. In my case this happened over night and I woke up as the heating was off :sweat_smile: . After I have updated MT3000 to 4.2 beta 2 and set the 2.4GHz network to b/g/n, channel 11, 20MHz it became more stable and I have slowly put more and more sensors and devices on it. Today I am moving the heating on it also to see how it behaves. For now it has part of my esp32 sensors and some 小米 cameras.
Warm Regards,
Misujr
Hi Misujr,
We’ve successfully burned your firmware and connected to the MT3000 wifi. We will try to mount it for a few days to see if it becomes unstable. If you have any progress on the test, please also update us.
Thanks,
kelly
5g wifi is always disabled? Or is it same ssid?
5G wifi is enabled and the SSID is different :sweat_smile:
2.4GHz SSID is : GL-AR750S-xx
5GHz SSID is : GL-AR750S-xx-5G
( I have renamed the MT3000 SSID’s to match the ones I had on my old AR750S to make the trasition easy for my IoT devices.)
We tested the firmware you supplied, but because there is no upper device (HA) to communicate with esp32, esp32 automatically restarts.
[I][app:102]: ESPHome version 2022.12.3 compiled on Dec 28 2022, 11:27:20
[C][wifi:363]:   SSID: 'GL-AR750S-35a'
[C][wifi:369]:   Signal strength: -58 dB ▂▄▆█
[C][wifi:373]:   Channel: 9
[C][sht3xd:029]: SHT3xD:
[C][sht3xd:030]:   Address: 0x44
[E][sht3xd:032]: Communication with SHT3xD failed!
[C][sht3xd:034]:   Update Interval: 60.0s
[C][sht3xd:036]:   Temperature 'Bedroom Temperature'
[C][sht3xd:036]:     Device Class: 'temperature'
[C][sht3xd:036]:     State Class: 'measurement'
[C][sht3xd:036]:     Unit of Measurement: '°C'
[C][sht3xd:036]:     Accuracy Decimals: 1
[C][sht3xd:037]:   Humidity 'Bedroom Humidity'
[C][sht3xd:037]:     Device Class: 'humidity'
[C][sht3xd:037]:     State Class: 'measurement'
[C][sht3xd:037]:     Unit of Measurement: '%'
[C][sht3xd:037]:     Accuracy Decimals: 1
[I][ota:113]: Boot seems successful, resetting boot loop counter.
[E][api:127]: No client connected to API. Rebooting...
[I][app:127]: Forcing a reboot...
[W][wifi_esp32:494]: Event: Disconnected ssid='GL-AR750S-35a' bssid=94:83:C4:28:32:43 reason='Association Leave'
ets Jun  8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0030,len:1184
load:0x40078000,len:13132
load:0x40080400,len:3036
entry 0x400805e4
Can you remove the reboot logic? Maybe your device going offline also related to this reboot?
Hi Kelly,
The reboot logic is part of the ESPHome suite as far as I can tell and there is no obvious way for me to remove it. The entire code/logic the is in the firmware and then compiled by ESPHome in a firmware for the ESP32 is in the yaml file I have posted above . If you think this is issue that I face is worth while your time, you can run HA on almost any SBC like a RaspberryPI, Orange PI or even as a docker container on a machine that runs on the same network with the ESP32. It a quick install in the ESPhome integration is native as they made by the same organisation.
As an update to this thread :
I have been using now for 24h MT3000 with all my devices and all works well with IoT devices and everthing else.
I am now running fw 4.2.0 beta 2 and the 2.4GHz SSID is set to WPA2-PSK , 11b/g/n, 20Mhz, channel 10.
I will mark this post as a solution but I will update in case anything goes wrong.
BR,
Misujr
