MT3000 Beryl AX freezes on WireGuard start/stop — requires restart to resume connection
Hi everyone,
I'm running into a frustrating issue with my GL.iNet GL-MT3000 (Beryl AX) and was hoping someone here might have a workaround or know if this is a known bug.
The Problem: Whenever I start or stop the WireGuard VPN client via the Admin Panel, the entire router freezes. The Wi-Fi network remains broadcasted, but internet access drops entirely. The Admin Panel becomes completely unresponsive, and I lose the ability to SSH into the device. To resume the connection and recover the router, it has to be manually restarted (power cycled).
Device Details:
  • Model: GL-MT3000 (Beryl AX)
  • Firmware Version: v4.11.0
  • Power Supply: Original OEM power adapter
Steps to Reproduce:
  1. Boot up the router and establish a standard internet connection.
  2. Navigate to the Admin Panel > VPN > WireGuard Client.
  3. Click "Start" on an existing WireGuard profile (or click "Abort" if one is already running).
  4. The UI hangs on the loading state, and the router locks up completely within seconds.
What I've Already Tried:
  • Performing a clean factory reset (without keeping settings).
  • Deleting and re-importing the WireGuard configuration files directly (instead of copying/pasting text).
  • Changing the MTU size in the WireGuard config.
  • Attempting to check the System Logs (unfortunately, because the router locks up instantly, the logs don't seem to write the exact crash event before freezing).
Has anyone else experienced this hard lockup with the WireGuard client on the Beryl AX? Are there any specific firewall rules, memory management tweaks, or firmware versions that resolve this?
Or, is it good idea to return this?
Thank you for the detailed report.
We tested starting and stopping the WireGuard client on an MT3000 running firmware v4.11.0, but we were unable to reproduce the freeze locally.
Could you please send us the following via private message so we can try to reproduce the issue with the same configuration and investigate further? Please do not post either file publicly, as they may contain private network or VPN information.
  1. A configuration backup exported from LuCI: System > Backup / Flash Firmware > Generate archive.
  1. A persistent system log collected during one reproduction attempt. Connect to the router through SSH and run:
    uci set system.@system[0].log_file='/root/syslog.log'
    uci commit system
    /etc/init.d/log restart
    logger -t wg-debug 'persistent logging enabled'
    Then start or stop the WireGuard client to reproduce the freeze. After power-cycling the router and reconnecting, download /root/syslog.log via SCP—for example, with WinSCP—and send it to us by private message.
    After collecting the file, disable the temporary persistent logging to avoid continued writes to flash:
    uci -q delete system.@system[0].log_file
    uci commit system
    rm -f /root/syslog.log
To send a private message, click the Technical Support avatar and then click Message. If your account cannot start a private message, please let us know and we will initiate it.
Once we receive the backup and log, we will investigate further.
Sent the details.
Thank you for sending the log and for providing a detailed description of your setup.
Unfortunately, the log ends before the WireGuard/Tailscale failure and does not contain the relevant VPN or firewall events, so it does not provide enough information to identify the exact cause. However, based on your description—particularly that the issue occurs when WireGuard and Tailscale are enabled together—it may be related to the firewall rule loading issue discussed here:
We have a fix for that known issue planned for the next firmware release. In the meantime, if possible, you can downgrade the MT3000 to firmware v4.9.0 to see if this help or not, available from the official firmware download page.
