MT3000 easytether speed 60% slower than USB tethering
I am experiencing slower speeds with my easytether setup on my new MT3000 router. Following is my setup:
  • Pixel 7 Pro with EasyTether Pro app.
  • MT3000 router
Speed Test Results (Download Speeds):
  • Pixel
    • 300 Mbps
  • USB Tethering Router mode; iPhone 15 Pro Max connected to the router
    • 300 Mbps
  • EasyTether mode; iPhone 15 Pro Max connected to the router
    • 60-100 Mbps
Will highly appreciate any pointers to root case and fix this issue.
Thanks!
Wild guess, but it seems that Easytether is the root cause.
It’s a 3rd party software, right? Will be hard to debug.
Yes, it’s a 3p app. I also suspect that it’s an issue with either the app or it’s driver.
Does it work via Wi-Fi or USB as well?
It works via USB. Followed GL-MT3000 EasyTether Driver instructions.
Sorry, can’t help with that. Maybe other people have more experience about it.
Thanks for taking time to help! I will try swapping the phone with Galaxy S23 ultra just to be sure that it’s not a device issue.
