I just received a Mt300n-v2 Travel Router and got it updated to the latest GL.iNet firmware. Very neat little device. I do have some questions and concerns though.
From what I’m reading here on the forums and on the net, it looks like the MediaTek MT7628 used in the Mt300n-v2 Travel Router does not allow for any wireless configuration from within the OpenWRT Luci interface. I would really like to utilize the full functionality of OpenWRT with Luci and all of the software packages, but still be able to configure with the GL.iNet Web GUI where appropriate. My questions are these:
Is there ever going to be any way to configure wireless via Luci in an upcoming firmware update for this router or is this just a permanent limitation? It is unfortunate this is not noted on the product information page if this is indeed a permanent limitation.
If an external wireless adapter or two is added, would I gain this missing functionality (wireless configuration via Luci)? If so, will going with a dongle or two totally mess up the GL.iNet GUI simple setup routines?. I was potentially thinking of adding a second radio with an external antenna / 5ghz support.
In regard to the FAQ: "Yes, our routers support Wi-Fi dongles with 3070 or 8187 chipset…"
Is the 3070 referencing the MediaTek 3070 wireless chipset? – I assume yes.
Is the 8187 referencing the MediaTek 8187 wireless chipset? – I assume yes.
Will these added dongles still be unsupported in Luci wireless config? -
Lastly, if this issue is not resolvable and Luci absolutely cannot be used for wireless config to allow for full OpenWRT software compatibility, can you please recommend what GL.iNet products are fully supported for OpenWRT Luci wireless config? I really like the GL.iNet GUI, but I do not want a limited OpenWRT Luci interface.
Thank you!
Frank
