GL-FUN
December 10, 2018, 5:21pm
Dear All
I have ERROR message when OpenVPN (SaferVPN) fails without a reason, untill reboot, it will not connect to OpenVPN…
RESOLVE: Cannot resolve host address: uk1.safervpn.net:1194 (Try again)
Could not determine IPv4/IPv6 protocol
SIGUSR1[soft,init_instance] received, process restarting
Restart pause, 20 second(s)
Please, help!
Does the Internet connection is available on the router without OpenVPN? You should have a try if it can resolve the url “uk1.safervpn.net ” firstly.
Please execute nslookup uk1.safervpn.net on the command line.
GL-FUN
December 11, 2018, 7:18am
3
hello kyson-lok - yes, internet connect works, and after reboot OpenVPN also starts without a problem. also, none out of 30 others vpn profiles work when it happens.
glitch
December 11, 2018, 8:59am
4
If you have internet without VPN then it’s your ovpn config file - contact your provider for help.
Also, check your user/pass combo.
https://support.safervpn.com/hc/en-us/articles/115004678905-Manual-OpenVPN-Setup-for-GL-iNet-router
GL-FUN
December 11, 2018, 10:16pm
5
glitch - I do not think this is the solution. here is why:
after reboot it works
it does not matter which profile I choose it gives the same error
no changes required to make it work again after reboot
any other thoughts?
alzhao
December 12, 2018, 6:40am
7
When it fails it will restart. Will it connect 20 seconds later?
GL-FUN
December 12, 2018, 7:08am
8
alzhao - when router reboots VPN connects as normal, however, without full router reboot VPN does not connect after 20 second - it is in the loop
alzhao
December 12, 2018, 7:38am
9
Is it possible that you can send me your profile via private message?
You can set a temporary password if possible. I don’t have safervpn account
GL-FUN
December 12, 2018, 8:02am
10
alzhao - configs are publically available with 30 days free trial offered
this is one of the config file:
client
dev tun
proto udp
cipher AES-256-CBC
remote-cert-tls server
remote uk1.safervpn.net 1194 # - Your server IP and OpenVPN Port
resolv-retry infinite
nobind
tun-mtu 1500
tun-mtu-extra 32
mssfix 1450
persist-key
persist-tun
auth-user-pass
comp-lzo
verb 3
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
glitch
December 12, 2018, 9:01am
11
Have Safer responded with help?
If you are just trialing, then chuck it and try another provider.
GL-FUN
December 12, 2018, 9:18am
12
glitch - What is the reason you believe it is SaferVPN if after the router reboot it works?
alzhao
December 14, 2018, 3:40am
13
I am using my AR750S v3.010 firmware and it connects. But I cannot connect to the Internet for some reason.
Didn’t try 300n-v2. If you don’t have 3.010 firmware please upgrade and try.
GL-FUN
December 14, 2018, 6:59am
14
Alzhao, it seems you are not taking into consideration two things: 1. After reboot all works; 2. There is no new hardware version for my router appear to exist
Kyson-lok - any advise?
alzhao
December 14, 2018, 8:01am
15
Firmware 3.010 for mt300n-V2 is here
https://dl.gl-inet.com/firmware/mt300n-v2/testing/
Upgrade without keep settings pls.
I did see that you said it worked about reboot. I didn’t try that.
Pls test v3.0 and we will help. 3.0 is under development so we focus more on 3.0.
GL-FUN
December 14, 2018, 8:33am
16
Alzhao - thank you! Unfortunately I am on the road constantly and can not afford testing. I will rather reboot to “fix” it and then upgrade when you release it.
glitch
December 14, 2018, 9:35am
17
If it works after a reboot, then the router must be fine.
So, the connection must be stalling because of a server time-out or something. Are you sure they don’t have bandwidth or connection time limits on their trial?
Safer VPN should be able to help but if it were me, I’d try another provider (surely that’s the reason for a trial?).
GL-FUN
December 14, 2018, 10:22pm
18
Glitch - I have paid service and it was fine for a year. It started recently and intermittently.
Are you using the v2.271 firmware?
GL-FUN
December 17, 2018, 8:53am
20
kyson-lok - yes, v2.271 firmware
GL-FUN
December 20, 2018, 2:25pm
21
A bit more troubleshooting:
when the OpenVPN fails as per above discussion, I found that when I reboot the upstream router the VPN comes back;
however, at times it doesn’t help.
I conclude: there is a problem with the way the upstream router handles OpenVPN protocol (will investigate), however, when it is persistent my MT300n-v2 gets in trouble and require reboot.
