MT6000/Flint2 v4.8.3 stable release
I have changed the MT6000 DNS server to pihole:
Let me see if I can reproduce it:
Update:
There is s3.amazonaws.com, but only 3
Same issue like 4.8.2: global speed cap at ~1 Gbps: Here the situation.
i will wait to update mine
Same here :slightly_smiling_face:
With 4.8.3 after some testing:
Using my ISP STB everything start smooth but after some time (10 min) all TV channels starts to freeze and returning errors for multicast connection.
Teste with cable and WiFi.
Downgrading to 4.7.7 and everything works perfectly.
I my opinion 4.7.7 is very very stable
Yes I have rolled back to 4.7.7 too, on 4.8.3 my 5GHz 160MHz wifi drops out then gets stuck on scanning for free channel and I have to reboot the router.
I wish there was an easy way to disable the “Update your firmware” messages
Yup. 4.7.7 is very stable to me. All features works perfectly!!
Nope, it was a bug in the 4.7.7(maybe also in the 4.8.2 and I don’t know if it’s still there in the 4.8.3)
Ooh yees :smiley:
Sorry for the inconvenience.
The driver version of v4.8.3 is the same as v4.7.7. In theory, the underlying driver of v4.8.3 is the same.
In case of an issue, please:
  1. Check whether the network situation of other clients is normal?
  2. Please check it in the PC: ping 192.168.8.1, ping 8.8.8.8, ping www.google.com nslookup www.youtube.com, nslookup www.x.com
If no luck, please share your router with us via GoodCloud, we would like to remote check your router.
Please PM me your router MAC address and the Admin Panel password.
If you upgrade the Flint 2 to v4.8.3 now, will the issue still reproduce?
We would like to check how long it takes for DFS to avoid and search for channels after it encounters radar signal interference? Is it always stuck in the search?
Please export the issue syslog.
