Mudi V2 shows "No Internet" while connected
I'm using the beta because of the better UI and more features. I guess these issues are the same or at least realted:
I have only Telekom HU (a Deutsche Telekom subsidiary too) physical cards, so it is hard to figure out is the issue ISP related or not.
First I tested the stock OS. It was affected. Tried a few resets and different configurations, but no luck. Then I tested version 4.3.26. I never keep settings. After first boot there was still no internet (because of the missing APN). Then I added the APN manually for the configuration and the issue just gone and the modem also connected as well.
But sadly the latest 4.7.2 beta is affected too. So the issue is still here. Of course the connection works, but the screen always shows "No Internet".
I have the Same issue with the Beta @ Telekom Deutschland.
Connection is working…
Hello @ViBE @bahu111
If the stable v4.326 works fine but the beta v4.7 not, it might be a known issue.
Can you run AT command AT+QCFG="band" or AT+QNWPREFCFG="lte_band", post the command response here to check the band info?
with the beta 4.7.2:
+QNWPREFCFG: "lte_band",1:2:3:4:5:7:8:12:13:14:17:18:19:20:25:26:28:29:30:32:34:38:39:40:41:42:43:46:48:66:71
OK
I'm attaching to this conversation since I'm having the same issue. Mudi V2 surfs the internet without problems but on the OLED screen it shows no internet. Actually using the physical e-sim with an italian provider profile on and running 4.7.2 beta firmware. Sharing system logread.tar as reference if needed
logread.tar (110 KB)
OK
Hi, confirmed it's a bug. The OLED network status display in beta V4.7 has issues and doesn’t show the correct connection status. It will be fixed in the future update. Sorry for the problem.
Thanks for your answer!! ,:grin:
Thank you so much!
I confirm that I also have this issue on 4.7.2 - 0702beta1 * 2025-03-12 09:37:51 (UTC+00:00) that I installed to fix the eSIM missing feature.
Waiting for a solution then!
Best
I can confirm that the issue has been fixed in the latest 4.8.3 beta.
Yes, the Problem is fixed.
This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
