WireGuard lists all the servers yet stops after abour 200. The USA are not listed as a server to choose from on the automatic install.
Any idea how to install the USA servers in Wireguard on the Glinet router ?
Easiest is to download the configs from Account | Mullvad and install them manually.
I believe someone else mentioned the issue with the enumeration of locations being cut off and that it’s been looked into. (Functionality with Mullvad VPN? - #6 by alzhao)
I also don’t think they are in squential order and they are grouped by server location, for instance my MallVad server list ends us241 and I had to hunt to find us249. I have 480 Mullvad wireguard servers installed and are grouped first by region then location.
The app is also easy to setup Mullvad WireGaurd in router.
3.212 beta3 and newer fixed the problem.
