My Blume 2 device is dead
I unplugged the Blume 2 from power in order to rearrange some LAN cables. No settings were changed before disconnecting the power. However, after reconnecting it, the Blume 2 did not recover.
The power LED turns on, but it cannot connect to the network, DHCP does not work, and the reset button is also unresponsive.
In other forum posts, I found a few people suggesting that the Blume 2 may have a defect related to power-circuit stability. Could my case be the same?
I have temporarily replaced it with a Mango device, but I need to resolve the issue with the Blume 2 or replace it with a similar device as soon as possible.
If this is something that can be resolved at the firmware level, what steps can I take? Thank you.
I attempted firmware flashing using U-Boot, but after uploading the firmware, the flashing process fails when it’s about to begin.
Follow this thread but replace the firmware with the latest firmware. Your device might require uboot to be updated too (the current uboot file/version is still the latest)
Do the upgrade in edge/chrome without any extensions running. See if that helps.
Both the firmware flashing and the U-Boot flashing fail.
Please contact our CS team via email at cs@gl-inet.com, cite this thread, and provide your purchase order.
They will be able to assist you in accordance with our policies.
