Good morning.
I am using a GL-MT300N.V2 (Mango) model that doesn’t recognize the hard drive I plugged in the USB port that the router has.
The first time I run the file sharing plugins it works fine but then, when I turn on the router later, the path of the file that was sharing before does not appear. Every time I try to login through my computer or any other device, just show an empty file with no permission.
Here I upload some images just to show you what kind of problem I have.
Is not. I use a HDD, at first I thought it was an energy problem as you said, but once a time the router works perfectly and recognize de driver, then when I turn off I unplugged the driver, upload some files, plugged in and then turn on the router but then the router didn’t recognize it.
I tried that, I also use an old HDD who was powered by an 12V cable, different from the USB cable and didn’t work. But I noticed something, it seems that every HDD who has a 3.0 USB output reboot the router, and when the router tries to initialize the main config, it tries to read the data form the HDD because it sounds how the disk of the driver tries to run but failing.
I did that plenty times before, sometimes the router read the driver but other times not.
Also when the router read it and I share some file from it, the clients show up that they didn’t have the right permissions.
