Need advice about using the IPKVM + work.
I’ve read this thread, which is useful, but I do have further questions based on this.
24 hours ago, I did not know that IPKVMs were a thing. I knew about KVMs, but I felt they weren’t for me because I need to see Teams on all my jobs at the same time, so I have 3 monitors + all peripherals.
Long story short, I want to work in a local cafe. I am aware that I can:
  1. Spoof the ID so the KVM does not get flagged.
However, I guess this is a more generic question, but in terms of the networking perspective, would the usage of a VPN get flagged? I would use my personal hotspot in public to access my laptops, but I will occasionally use public WiFi, which I do not like. So, I’ll be using a VPN on my personal laptop to connect back to the KVM.
Is there anything else that I am missing to avoid being flagged for work? No job uses CrowdStrike just yet.
HERE BRO: kvmd-edidconf
strings /etc/kvmd/tc358743-edid.hex
kvmd -m
nano /etc/kvmd/override.yaml
cat/etc/kvmd/override.yaml
Phase 1: Cleared the Video Identity (EDID Leak)
The Problem: Your KVM was actively broadcasting its default open-source profile, explicitly exposing raw text strings for PiKVM V3 and the test serial CAFEBABE to your laptop's graphics card.
The Fix: We completely wiped out that profile and replaced the raw contents of /etc/kvmd/switch-edid.hex with a genuine, bit-for-bit binary match of a standard Dell P2419H Professional Monitor.
The Verification: You checked the active runtime memory buffer (cat /run/kvmd/otg/emulation/hdmi/edid) and confirmed the hardware is now actively serving the clean Dell profile.
Phase 2: Verified the USB Input Profile
The Problem: USB controllers default to generic manufacturing IDs that endpoint management scanners can easily audit.
The Fix: We audited your active kvmd -m configurations and verified that your USB gadget layer completely cloaks itself.
The Profile: Your KVM successfully presents itself to the OS as a real Logitech Unifying Receiver, using Logitech's official Vendor ID (1133 / 0x046D) and Product ID (50470 / 0xC548), complete with a unique, randomized hardware serial number.
Phase 3: Sanitized Deep Sub-Interfaces
The Problem: Deep system queries can read internal hardware paths for audio and virtual storage drives.
The Fix: We verified your config file has successfully hidden the Rockchip default sound tag (Comet Microphone) and the router storage strings (Glinet Flash Drive). They are now fully masked as Logitech Microphone and Logitech Flash Drive profiles.
Final Operating Rules Moving Forward
Keep the Jiggler Off: Ensure jiggler: active: false stays disabled in your configuration to avoid rigid, mathematically predictable patterns that heuristic EDR software (like CrowdStrike) might flag.
Watch for Updates: If you ever factory-reset or perform a major firmware upgrade on the GL.iNet device, re-verify your files to make sure the custom configurations weren't overwritten.
Keep Connections Sequential: Always ensure your corporate machine connects strictly through your travel router's secure LAN network path first before checking into any company infrastructure.
No bro you need a vpn router to connect the work computer via ethernet (NOT WIFI they will find you via triangulation) once thats done you open the laptop/pc and disconnect wifi antenna cables then you can connect the KVM but just connect the hdmi input and Keyboard and mouse cable so it can control. Make sure to isolate KVM on the VPN router (in this case i use Opal) to prevent company laptop from scanning the network and detecting your kvm your welcome have a good day
Maybe we stop helping people break the rules, tell them to get permission. They should educate themselves and decide if they can handle losing their jobs.
maybe you can stop giving your unrequested opinion. your in a thread that’s whole purpose is this fool. get out of this chat boi
cant stand nerds you like you
Well you may be in the wrong place mate.
Good luck
I can give you my opinion because this is a “forum”
Do you understand?
Good luck
ok nerd
Let’s stop with the name calling shall we, dumas.
LOL
