Just started with GL XE300 FW 4.0 0317 r3
All basic functions appear to be working fine.
I shut it down and inserted a known good Micro SD Card
I do not see Network Storage Option in Applications..??
Any suggestions appreciated...
Many Thanks
Many Thanks
You can try to install it manually if you have enough space free: How to install nas functions manually
If this isn't the case, you need to extroot before.
Also, in what filesystem is your microSD formatted (exFAT, FAT32...)? If the microSD filesystem is not accepted by the router, it won't show up.
Hi admon
Thanks... System say's 96MB Free
I will look at the link, all new to me
New Sandisk, formatted FAT32
Ok, this microSD card should work out of the box.
It appears they have removed the Network Sharing Functionality
Yes, this feature is removed in 4,x firmware: GL.iNet download center
This model of router has limited features on 4.x firmware. Consider downgrading to 3.x firmware to get file sharing feature.
It is not essential, just a nice to have... At least I know my options... Thanks
You're welcome
