New firmware version 4.7 being released for beta testing
Probably it's AdGuard updating the filters every 24h.
If you have too many filters, the processing will be very high.
possible, but i thought you can see that in the syslog.
But it was indeed set on 24H, and changed it now t 7 days, see if it works.
Thxs.
Running beta with OP24 (due to issues with WDS on non OP24 builds) - I really wish you fixed this so the Flint 2 & Slate AX worked with WDS with the standard (non-OP24) firmware builds since you seem to support that faster / better. Here however are a few crash logs for you for the OP24 builds:
Oops#1 Part1
<7>[ 23.457673] [add_dev_config 287]add node success. iface:wan, dev:eth1, ifindex:3
<6>[ 24.647964] br-lan: port 7(wlan1) entered blocking state
<6>[ 24.653341] br-lan: port 7(wlan1) entered forwarding state
<6>[ 27.764309] br-lan: port 6(wlan0) entered blocking state
<6>[ 27.769641] br-lan: port 6(wlan0) entered forwarding state
<6>[ 50.072997] br-lan: port 8(wlan1.sta1) entered blocking state
<6>[ 50.078794] br-lan: port 8(wlan1.sta1) entered disabled state
<6>[ 50.084687] mt798x-wmac 18000000.wifi wlan1.sta1: entered allmulticast mode
<6>[ 50.091993] mt798x-wmac 18000000.wifi wlan1.sta1: entered promiscuous mode
<6>[ 50.099164] br-lan: port 8(wlan1.sta1) entered blocking state
<6>[ 50.104927] br-lan: port 8(wlan1.sta1) entered forwarding state
<6>[ 50.111559] mt798x-wmac 18000000.wifi wlan1.sta1: left allmulticast mode
<6>[ 50.118295] mt798x-wmac 18000000.wifi wlan1.sta1: left promiscuous mode
<6>[ 50.125267] br-lan: port 8(wlan1.sta1) entered disabled state
<6>[ 50.192575] br-lan: port 8(wlan1.sta1) entered blocking state
<6>[ 50.198362] br-lan: port 8(wlan1.sta1) entered disabled state
<6>[ 50.204203] mt798x-wmac 18000000.wifi wlan1.sta1: entered allmulticast mode
<6>[ 50.211400] mt798x-wmac 18000000.wifi wlan1.sta1: entered promiscuous mode
<6>[ 50.218345] br-lan: port 8(wlan1.sta1) entered blocking state
<6>[ 50.224089] br-lan: port 8(wlan1.sta1) entered forwarding state
<1>[36256.961229] Unable to handle kernel paging request at virtual address ffffffa3d5ab0010
<1>[36256.969161] Mem abort info:
<1>[36256.971940] ESR = 0x0000000096000005
<1>[36256.975680] EC = 0x25: DABT (current EL), IL = 32 bits
<1>[36256.981050] SET = 0, FnV = 0
<1>[36256.984108] EA = 0, S1PTW = 0
<1>[36256.987243] FSC = 0x05: level 1 translation fault
<1>[36256.992129] Data abort info:
<1>[36256.995078] ISV = 0, ISS = 0x00000005, ISS2 = 0x00000000
<1>[36257.000629] CM = 0, WnR = 0, TnD = 0, TagAccess = 0
<1>[36257.005716] GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
<1>[36257.011027] swapper pgtable: 4k pages, 39-bit VAs, pgdp=0000000048da0000
<1>[36257.017736] [ffffffa3d5ab0010] pgd=0000000000000000, p4d=0000000000000000, pud=0000000000000000
<0>[36257.026478] Internal error: Oops: 0000000096000005 [#1] SMP
<7>[36257.032035] Modules linked in: pppoe ppp_async option wireguard usb_wwan rndis_host qmi_wwan pppox ppp_generic nft_fib_inet nf_flow_table_inet mt7915e(O) mt76_connac_lib(O) mt76(O) mac80211(O) libchacha20poly1305 ipt_REJECT huawei_cdc_ncm chacha_neon cfg80211(O) cdc_ncm cdc_ether xt_time xt_tcpudp xt_tcpmss xt_statistic xt_state xt_recent xt_quota xt_pkttype xt_owner xt_nat xt_multiport xt_mark xt_mac xt_limit xt_length xt_hl xt_helper xt_ecn xt_dscp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_cgroup xt_addrtype xt_TPROXY xt_TCPMSS xt_REDIRECT xt_MASQUERADE xt_LOG xt_HL xt_DSCP xt_CT xt_CLASSIFY usbserial usbnet ts_fsm ts_bm slhc poly1305_neon nft_tproxy nft_socket nft_reject_ipv6 nft_reject_ipv4 nft_reject_inet nft_reject nft_redir nft_quota nft_numgen nft_nat nft_masq nft_log nft_limit nft_hash nft_flow_offload nft_fib_ipv6 nft_fib_ipv4 nft_fib nft_ct nft_compat nft_chain_nat nf_tproxy_ipv6 nf_tproxy_ipv4 nf_tables nf_socket_ipv6 nf_socket_ipv4 nf_reject_ipv4 nf_nat_tftp nf_nat_snmp_basic
<7>[36257.032217] nf_nat_pptp nf_nat_irc nf_nat_h323 nf_nat_amanda nf_log_syslog nf_flow_table nf_conntrack_tftp nf_conntrack_snmp nf_conntrack_sane nf_conntrack_pptp nf_conntrack_netlink nf_conntrack_netbios_ns nf_conntrack_irc nf_conntrack_h323 nf_conntrack_broadcast ts_kmp nf_conntrack_amanda nf_conncount mdio_netlink(O) libcurve25519_generic libcrc32c libchacha iptable_nat iptable_mangle iptable_filter ipt_ECN ipheth ip_tables compat(O) cdc_wdm cdc_acm br_netfilter asn1_decoder arptable_filter arpt_mangle arp_tables crypto_safexcel fuse sch_tbf sch_ingress sch_htb sch_hfsc em_u32 cls_u32 cls_route cls_matchall cls_fw cls_flow cls_basic act_skbedit act_mirred act_gact xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ipmac ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6table_nat nf_nat nf_conntrack
<7>[36257.121711] nf_defrag_ipv6 nf_defrag_ipv4 ip6t_NPT ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 ifb ip6_udp_tunnel udp_tunnel udp_diag tcp_diag raw_diag inet_diag tun ntfs nls_utf8 nls_iso8859_1 nls_cp437 sha512_arm64 sha1_ce sha1_generic seqiv md5 geniv des_generic libdes authencesn authenc uas usb_storage leds_gpio xhci_plat_hcd xhci_pci xhci_mtk_hcd xhci_hcd uhci_hcd ohci_platform ohci_hcd fsl_mph_dr_of ehci_platform ehci_fsl kmwan(O) ehci_hcd gpio_button_hotplug(O) gl_sdk4_tertf(O) gl_sdk4_black_white_list(O) vfat fat exfat usbcore usb_common aquantia mii gl_sdk4_hw_info(O)
<7>[36257.265775] CPU: 2 PID: 24715 Comm: sleep Tainted: G O 6.6.63 #0
<7>[36257.273154] Hardware name: GL.iNet GL-MT6000 (DT)
<7>[36257.277841] pstate: 80400005 (Nzcv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
<7>[36257.284784] pc : __handle_mm_fault+0xbc/0xa20
<7>[36257.289136] lr : __handle_mm_fault+0x34/0xa20
<7>[36257.293477] sp : ffffffc08a7c3cc0
<7>[36257.296774] x29: ffffffc08a7c3cc0 x28: ffffff80002e2700 x27: ffffff801005c500
<7>[36257.303890] x26: 0000000000000004 x25: 0000000000000040 x24: ffffff80002e2700
<7>[36257.311007] x23: ffffff80192f5e80 x22: ffffffc08a7c3eb0 x21: 0000000000001354
<7>[36257.318123] x20: ffffffc080d34000 x19: 0000000000000002 x18: ffffffc08a7c3d80
<7>[36257.325239] x17: 0000000000000000 x16: ffffffc080b491b8 x15: 0000007fb54f6fff
<7>[36257.332355] x14: 0000000000000000 x13: 1ffffff0018f2fc1 x12: ffffffc08a7c3d80
<7>[36257.339470] x11: ffffff800c797e00 x10: ffffff800c797e08 x9 : ffffffc080231ef0
<7>[36257.346586] x8 : ffffffc08a7c3d70 x7 : 0000000000000000 x6 : 0000000000000000
<7>[36257.353702] x5 : ffffff8009a63000 x4 : 0000000000100cca x3 : 000000000000003a
<7>[36257.360818] x2 : 000000000043a000 x1 : ffffffa3d5ab0010 x0 : ffffffa3d5ab0000
<7>[36257.367935] Call trace:
<7>[36257.370366] __handle_mm_fault+0xbc/0xa20
<7>[36257.374365] handle_mm_fault+0x130/0x2d0
<7>[36257.378273] do_page_fault+0x154/0x498
<7>[36257.382009] do_translation_fault+0x88/0xa8
<7>[36257.386175] do_mem_abort+0x48/0xa0
<7>[36257.389653] el0_ia+0x44/0xb0
<7>[36257.392607] el0t_64_sync_handler+0xc4/0x128
<7>[36257.396861] el0t_64_sync+0x150/0x158
<0>[36257.400511] Code: b2596000 8b130c01 f9003be1 b4000781 (f8737802)
<4>[36257.406585] ---[ end trace 0000000000000000 ]---
Panic#2 Part1
<3>[36257.415242] pstore: backend (ramoops) writing error (-28)
<0>[36257.420627] Kernel panic - not syncing: Oops: Fatal exception
<2>[36257.426353] SMP: stopping secondary CPUs
<0>[36257.430262] Kernel Offset: disabled
<0>[36257.433734] CPU features: 0x0,00000000,00000000,1000400b
<0>[36257.439029] Memory Limit: none
I did what you said and tried option 2 and 3 and it did not resolve the wifi speed issues. Even when I am standing right next to the router I am still capped at 120mb...
Are we sure the client can manage a higher speed?
What is the Brand / Model of the client device?
Yes it is a flint 2 I only bought it a month ago. The client is MacBook M2 and Google pixel 9 pro fold
4.7.0-op24 is using Open Source WiFi driver.
4.7.4 is using closed source driver.
And you are seeing problem on both. That's quite weird.
@bruce, any idea?
Strange. I use 4.7.0-op24 since a few weeks and I get up to 1 Gbits/sec 6 meters from the router through 3 brick walls.
When your 120 mb means 120 Mbytes/sec that is equivalent to 960 MBits/sec.
I’ve noticed hardware acceleration is enabled on the gl-iNett gui but not enabled on the openWRT gui, should it carry over to the openWRT firmware so both are enabled?
Please let me know how to reproduce this log print, we did not reproduce about running 3 days and not find these in the syslog.
Not sure, sorry, please let me know the name of the plugins you need, we will compile and supplement these.
Please let me know the test firmware version.
Please SSH to the router, and execute this command:
cat /proc/kmsg& logread -f&
Re-connect WiFi for the clients, and export the syslog and PM it to me.
I have sent you a PM. Another note is, when i upgrade to 4.7.0 OP24, one of my 5GHz networks stop allowing the pixel to connect to it it just fails. I just changed the wifi mode to 11n/ac/ax from 11ac/ax and that resolved that issue.
I’m trying to installeer this beta on my Beryl AX, because I’m facing issues with adguard on 4.7.0. But via browser and GLInet app the update doesn’t come trough. I get no error on my screen, just when i reconnect to the router it still is on 4.7.0 release 3. I;m updating from my iPhone and iPad. I am on holiday, so i don’t have an pc with me. but i did the local update before without any issues.
We don't actually need to merge this patch, we just fixed the hash when build the image every time.
@bruce after doing more tests on the 4.7.0op24 firmware version I am getting fast speeds on my Mac and pixel on 5GHz. On 2.4GHz the speeds are really slow only.
What did you change to have the speed back to normal?
2.4GHz networks is always slower than 5GHz
What do you mean by "really slow"? 5Kbps? 1Mbps? 100Mbps? 250Mbps?
All I did was reboot the router it then started working getting 600-700mbps 5GhZ and 50-100mbs on 2.5Ghz
Is there ETA for a new GL Flint 2 beta build for OpenWrt 24 ? The last one was almost 1 month ago
Is there any USB3 device connected to the router?
Also next to it
If yes, remove it and test again.
