New firmware version 4.8 being released for beta testing
@bruce i totally agree the reason. But on the first time register goodcloud.xyz should remember the owner and if you make it enable by default then the last registered account will see it and can configure it from scratch in case of factory default as device will try to register using device id and serial number. This will be like an addon for the users.
But let say if this device is resell then the new owner will try to register it on his account. This request should be treated as transfer of ownership which will be managed by both previous owner and new owner.
Just a thought though.
If it is resold, you need to log out of GoodCloud on the GL GUI first.
Otherwise, after receiving this router, a new user will not be able to register with a new GoodCloud account even if reset firmware or uboot flash firmware.
This is to protect the router owner information from being read by the thieves.
We cannot prevent your router from being stolen, but we can protect user information to the greatest extent.
The router is managed by the organization, and the user is a member of the organization. This belongs to the 2B version of the GoodCloud. And this feature is supported.
Can this please be re-added?
So for non-organization routers can we add browser support to GLKVM so that we can use atleast this option to manage a device via. Lan in case of a factory reset or even new routers.
This is also a use case for glkvm product.
Although Auto detect mode was removed in v4.8, the policy mode of v4.8 (custom "To") should be able to cover your needs.
How about the VPN rules do you want to configure?
Sorry, please clarify your needs and use scenario.
Now GLKVM supported the browser access via LAN IP or domain in local
My request is tonaccess remote lan where glkvmis connected
As I wrote in my previous comments, the AdGuardHome running on my router needs to connect to an upstream DNS server, which can only be reached via VPN. My LAN clients can reach it through the VPN, but adguardhome running on the router itself not.
Can’t seem to find this answer: was there a reason that carrier profiles were ditched in the 4.8 update? I’ve got a GL-X3000. docs4.x/docs/interface_guide/internet_cellular_v4.7.md at master · gl-inet/docs4.x · GitHub
There are cloud platform/APP for glkvm and other methods (tailscale) to access it remotely.
There is no need to access glkvm through the router GoodCloud platform.
This is a different product line and the software will not be shared.
If you mean APN profile, it's still there, but it's changed location:
May be im unable to express what exactly im looking for.
Let me try one last time.
Lets say i did factory reset on a remote router where i have goodcloud enabled, after factory reset i need to enable it manually connect via. Lan. I understood
Now to manage any factory reset routers can i use glkvm which is in the same lan ? Is it possible ?
The glkvm itself cannot access the GL GUI.
You may think to SSH to router in glkvm's terminal, but if the router is firmware of v4.8.0 or above, and the router is not initialized, the SSH 22 port is inaccessible.
Moreover, if the router is not initialized, the LAN's glkvm cannot be connected to the Internet. Therefore, only people on LAN and complete initializing the router.
Maybe not possible.
I mean the “carrier profiles" as mentioned in the 4.7 docs that I linked, wherein I could save/load different APN settings. The docs you linked do not mention an “APN profile”. I'm looking for the reason where this feature went:
Carrier profile
You can save different profiles for the same or different carriers.
I see.
On the v4.8 firmware, we did remove the APN profile saved list, but as long as you fill in the APN profile(s) and apply it, this APN will be recorded/save in the background of the router, the router will automatically apply the corresponding Profile for SIM, until you manually reset firmware.
That is to say, when using SIM A, manually enter Profile A and apply in the first time; switch to SIM B, manually enter Profile B and apply in the first time; when you switch to SIM A, the router will automatically apply Profile A to SIM A by recognizing the ICCID of SIM and reading the previously saved Profile A in the background, without manually entering it again. And the same as SIM B.
Except I don’t see a way to save PIN for the SIM at all, which means everytime the router reboots I need to re-enter the PIN which is annoying.
If the SIM card has a PIN lock, the first time it's inserted into the router, the GL GUI will prompt you to enter the PIN code, as shown in the image below:
Enter the correct PIN code and unlock it.
The router will remember this SIM card's PIN code, so you won't need to re-enter it if router reboot.
Additionally, if you remove this SIM card and insert it again later, the router will automatically recognize the SIM card's ICCID and unlock the PIN.
Unless you manually reset firmware to make the router return to factory settings.
That’s not correct. Every time I reboot it asks for the PIN again and won’t connect without it.
I did not reproduce this issue in my X3000.
Please share your router with us via GoodCloud, I would like to remote check this issue on the router.
Please PM me your router MAC address and the Admin Panel password, SIM PIN code.
Add a feature in GL-iNet GUI where the user can export all their settings, except their credentials, then they can send it to you and you can load this file in your device, then this will be much easier to reproduce the problems.
