Not yet, they're running in parallel.
hello @muckel I vote for your request ![]()
i haven't checked this new firmware yet.
But from mullvad i know, you take the configs and everything shares the same private key.
would the new vpn feature allow multiple vpn interface/connections with this same key or does the new feature request new keys? (Mullvad has max 5 i believe).
Wouldn't better to share the same key?
On vanilla openwrt with luci-proto-wireguard it works the same way although it looks a little ambiguous but it works.
Yes I believe you are understanding correctly. I copied the config files to pastebin if you would like to look.
Router A is a typical home setup WiFi Access point with a LAN subnet of 192.168.0.0/24
Router B is setup as a WiFi client and firewall zone is set to WAN -- typically called NAT or firewalled from the LAN which is on 192.168.1.0/23 subnet
I am not sure how similar Gl-inet firmware is compared to Openwrt, As far as I know they are not compatible
Hello, I understand that what you want is our Repeater function:
Usage plan:
- "Router B" uses the Repeater function to connect the WIFI of "Router A".
2、Select the Router mode in the Network Mode of "Router B" and apply it.
3、Set the Router IP Address of "Router B" in the LAN.
This can achieve the effect you said, and the device of "Router B" can access the Internet through NAT.
Does this scheme solve your problem? Do you have any other needs?
Same problem tryin installing speedtest, seems packages dependencies are not availables.
I can confirm I’m having trouble as well with SQM
@Lun , would it be possible to add a feature to reset the mobile/cellular data counter to zero every month (or every given date of a month), for those of us having a monthly cell plan?
Thanks for this, I guess the only thing I am waiting for now is for when GL-inet update to 24.x series and especially a kernel bump up to 6.x.
I will keep a eye on this site I will defiantly try your firmware one day
Looks like you may have your wish. 4.8.0 is showing in Beta tab for GL-X3000 now.
This problem has been recorded and will be fixed as soon as possible.
Hello, X3000 beta version is available for download and installation.
waiting for mt2500.. ![]()
Please send the beta for the Brume 2 when it's available.
Thank you for the update, SQM is King! ![]()
@tamu432 @kaz050457
Hello, I will follow the beta progress of MT2500 firmware, and I will inform you immediately if there is any news.
Hello, I just did an update on my GL-A1300 , now it asks to reset the password and throws an error, eternal spinning wheel. Can I download the old software and install it through a USB port. because I can't log into it any more.
Regards
Dave
Just upgrade my FLint2 to beta. If you click on Nord VPN, nothing opens.
You have to go to Wireguard Client to activate a server.
Also, while my devices are in the VPN tunnel, it shows that the tunnel is inactive.
Also app need an upgrade when its official ![]()
Just upgraded my MT3000 to V4.8 beta. I just love the new GUI inside the VPN Dashboard. I got some issues with secured web access (https). A warning of "operation timed out" keeps popping up, and I have to reload the web page constantly. I replaced the key and certificate files ("uhttpd.key" and "uhttpd.crt" in directory /etc/) with my own. The issue is still there. However, there is no issue on LuCI side.
Update: The issue went away after I replaced files "nginx.cer" and "nginx.key" in the directory "/etc/nginx" with my own.
I have same issue, what I must do to correct it please?
