Hello, I am new here and Flint 2 is my first router from GL.iNet. I set it up behind my ISP router via LAN within the same network. Everything seems to work (even the Wireguard server using port forwarding from the first router). The problem is that I'm getting a "No Internet Connection! Find a network to reconnect" message, and some things don't connect, like plugins with the alert "Failed to update repository list, please check your network and try again."
Everything else (Wi-Fi, Dynamic DNS, AdGuard) works fine. I tried the latest stable, beta, and snapshot versions with the same results. Any thoughts?
BTW am I getting 200MB/s with a SSD attached via Samba in case anyone is interested.
Thank you alzhao.
The problem with connecting via WAN is that I want to avoid double NAT issues. The ISP router doesn't allow bridge mode or even static routing. Do you know any solutions to fix the connection issues in LAN mode?
Regards
Good morning, I received the same router yesterday and configured it the same way. I want it to function as an access point (to provide WiFi coverage in that area of the house on the same network I already have) and connect a NAS to one of the 2.5 Gb ports. Additionally, I use it to create a VPN with TailScale.
Everything works perfectly. Even when I go to LUCI, I can confirm that it has internet access without any problem. However, the GL.inet GUI shows the message "No Internet Connection! Find a network to reconnect." It's a visual annoyance since it works and has internet access.
I just want to remove that message, since it's not true.
Thnak you in advance
LAN: 192.168.10.0/24
4 phones, 3 computers, 9 IoT devices, 1 Nvidia Shield, 2 printers, 3 access points, 6 WiFi security cameras, 3 smart speakers, and I think that's all.
Sounds like a bug.
Is your Flint 2 working in Access Point mode or Router mode?
If it is in Router mode, you can disable Enable Interface Status Track or modify Track IP in Multi-WAN.
You indicated 2 options: "you can disable Enable Interface Status Track or modify Track IP in Multi-WAN." I understand that the one I used is "modify Track IP in Multi-WAN," and I don't know how to change the other one; I can't find where to do it.
Hello again,
I tried the same things with no luck, at the end I used WAN instead LAN and that was the only way to avoid the message. I'm using a different subnet and it seems that works fine everything I need.
Javier, with LAN connection, Can you install plugins? That was the only issue besides the error message.
Can I know why you don't let the MT6000 work in Access Point mode?
I have both 2.5 Gb ports on LAN since I need to use one 2.5 Gb port to connect a NAS and the other for the 2.5 Gb backbone connection. Having another routed LAN doesn't add any value (it only complicates the network). Everything works fine from LUCI; I think the issue is that from your GL.Inet GUI, the gateway and DNS are not defined for the LAN. That's the only thing I added in LUCI.
