Please help! I successfully connected to Page Plus Verizon, but wanted to try my Straight Talk Verizon because Straight Talk is twice the download speed on the phones! I was unable to connect with Straight Talk so I went back to Page Plus but now I can’t get it reconnected. Darn.
Working settings:
- Device: /dev/cdc-wdm0
- APN: VZWINTERNET
- Auth: None
- Proto: auto
However, now the only way I can get “some” connection by changing Proto to qcm. Results:
- Verizon button is green
- Upload shows a little activity. No download
- Bars are displayed momentarily then disappear
- No IP
To clear settings, I’ve:
- Rebooted
- Reset modem
- Updated firmware
- AT+QPRTPARA=3
Router has bars so it’s connected, but not registered for internet use. Card works in phone. Using adapter with paper inserted under lock
UPDATE:
- Activated & installed new sim card. No connection
- Flashed router with ROOter. No connection
I noticed that [Device: /dev/cdc-wdm0] was not an option in ROOter. I suspect that may be the problem. The only ports available are /dev/tty/USB0-5. I’ve tried default & both USB0 & 3 which didn’t work.
The router has a Qualcomm chip. I think it needs to be in QMI mode.
Is there an AT command to add /dev/cdc-wdm0 port?
