following the guide I find the connection established. but I can’t communicate between the 2 networks. with the first mt300n-v2 I created the node connecting it with the Wan port to my home router with the second mt300n-v2 I used a data SIM and I connected to the LAN port but I can’t see the home network and not even that of my router with data SIM. what error do you make?
it works, thanks for the support. I have only one question, now to access I must be connected to the LAN port of the two devices. now how can I access my home network directly so as to keep the device attached to the router with only the Wan cable?
Do you need direct access to your home network from the Internet?
Why don’t you just open a port on your home router?
You can also turn on the 300N-V2’s remote access and access your home network through the router.
no, I would like to use my MT300N-VN as if it were a PC connected to my home network and then with only one cable on the Wan port. it’s possible? so that from my home network I can access the remote network
right, my device is connected to my adsl router via Wan but if I try to access the network of my second device via VPN from the PC connected to my adsl router it does not work.
You need to configure the adls router and add a static routing table
Assuming your adls LAN interface is br-lan, you may need to add routing rules like the following
