OVPN Server - Configuration Connection
Has anyone come across this issue when trying to connect to your ovpn server ???
“VPN client failed to connect. This may be because of wrong configuration, unsupported parameters or terminated by the server. Please choose another VPN profile or abort the connectiony”
:exploding_head:
Yes. You are using a config file with some deprecated/unsupported parameters.
Check out the logs (by clicking on “View Log” in the VPN dashboard) and you will find the root cause.
You’re not using Nord VPN w/ OpenVPN, are you?
Off topic but related: see if your VPN provider supports WireGuard. The speed improvement over OpenVPN is so vast it’s not even a fair competition.
