This does not affect the clean firmware which doesn’t have GLI UI.
By "this" do you mean the CSRF issue or are all the changes/improvements in 2.25 related to the GLI UI only and people using your Image Builder would not benefit from redownloading IB and rebuilding the firmware?
Upgraded and traveling. WIFI SSID didn’t show up in the network list so I had to connect via Ethernet and do a factory reset. Just in case you are experiencing the same issues as me. All is well at this point…
I experienced the same issues today and downgraded to 2.24. It appears that when I disconnect and power off the router with 2.25 it doesn’t retain the config or the wireless connectivity when it powers back up. I also disabled auto-update on the firmware.
when you say “2.25 doesn’t retain the config of the wireless connectivity” do you mean the connection is disable after reboot? Does the repeater SSID still saved?
The firmware tries to search and connect to saved SSIDs. If it failed it will disable the repeater.
I simply cannot connect to the SSID I have configured for the router (LED is also disabled). It does not show up. I have to plug into the Ethernet int to manage and reset.
So I had a little time and did some testing. This may be the intended behavior so let me know. But if the WIFI internet connection isn’t available the router doesn’t broadcast it’s local wireless SSID. So I need to connect to it via Ethernet to change/configure the upstream WAN connection. When it connects successfully it starts to broadcast. Does that make sense?
I would have expected it to broadcast the local SSID so I can change the WAN WIFI without having to pull out a cable and connect locally.
I would have expected it to broadcast the local SSID (even if the upstream WAN/WIFI) is not available so I can change the WAN WIFI without having to pull out a cable and connect locally.</span>
@wakesk8tr, NO. When used as WISP (repeater) mode, if it cannot connect to the host wifi, it should just disable it and broad its own wifi signal. This is called “repeater manager” in our firmware. If your router don’t have this function, you may need to revert the firmware to factory status from the UI and try again. This may happen if you upgrade from a very old firmware and reserved settings.
