I’ve been looking about for the PoE (power over ethernet) options for the Convexa B-1300. But there doesn’t seem to be much information about it. Any information would help.
I already have four B-1300 devices. I would like to power a few of these devices with PoE.
I can see from a number of posts that:
- PoE version is only sold to businesses
- Gl iNet might sell a retrofitable PoE module that I could solder onto to my Convexa units retrofit-poe
I can see from the technical specifications that the unit is listed as consuming less than 7W.
I am thinking of using a PoE injector/splitter to power the convexa (without needing the PoE module)? Say a splitter like this. I assume this is fine.
Is standard PoE fine for the B1300? Rather than needing PoE+? As tech specs list the unit as only needing <= 7W? (In case I buy a switch with PoE support)
Cheers
