So I set up extroot with a 64gig card on my AR750.
extroot setup should be good:
root@GL-AR750:~# block info
/dev/mtdblock5: UUID="9e3223c6-92747156-b874c1c5-8a35dc7a" VERSION="4.0" MOUNT=" /rom" TYPE="squashfs"
/dev/mtdblock6: TYPE="jffs2"
/dev/sda1: UUID="3f7b9cbf-74e3-42b6-aeb6-5adf869dd91f" VERSION="1.0" MOUNT="/overlay" TYPE="ext4"
root@GL-AR750:~# df -kh
Filesystem Size Used Available Use% Mounted on
/dev/root 10.5M 10.5M 0 100% /rom
tmpfs 60.4M 956.0K 59.4M 2% /tmp
/dev/sda1 58.4G 53.2M 55.4G 0% /overlay
overlayfs:/overlay 58.4G 53.2M 55.4G 0% /
tmpfs 512.0K 0 512.0K 0% /dev
root@GL-AR750:~# cat /etc/config/fstab
config 'global'
option anon_swap '0'
option anon_mount '0'
option auto_swap '1'
option auto_mount '1'
option delay_root '5'
option check_fs '0'
config 'mount'
option target '/overlay'
option uuid '3f7b9cbf-74e3-42b6-aeb6-5adf869dd91f'
option enabled '0'
However, when I try to install packages, either through the webinterface or via opkg it fails with Read-only file system error.
Also can’t create files in home directory:
root@GL-AR750:~# touch test
touch: test: Read-only file system
Please advise.
Can you describe please how to do ?
On follow you find what I tryed to find about:
Nevermind, I fixed it myself. Here is the proper fstab that works for me. I thought rw was the default. Apparently you have to explicitly option rw.
/dev/mtdblock5: UUID=“9e3223c6-92747156-b874c1c5-8a35dc7a” VERSION=“4.0” MOUNT=“/rom” TYPE=“squashfs”
/dev/mtdblock6: MOUNT=“/overlay” TYPE=“jffs2”
/dev/sda1: UUID=“3f7b9cbf-74e3-42b6-aeb6-5adf869dd91f” VERSION=“1.0” MOUNT=“/mnt/sda1” TYPE=“ext4”
config global
option anon_swap ‘0’
option anon_mount ‘0’
option auto_swap ‘1’
option auto_mount ‘0’
option delay_root ‘5’
option check_fs ‘0’
config mount ‘rwm’
option device ‘/dev/mtdblock6’
option target ‘/rwm’
config mount ‘overlay’
option uuid ‘3f7b9cbf-74e3-42b6-aeb6-5adf869dd91f’
option target ‘/overlay’
option options ‘rw,relatime,barrier=1,data=ordered’
option enabled ‘1’
option is_rootfs ‘1’
You need to install several packages to create an ext4 filesystem on the overlay partition!
the new 3.xxx has all the files already. (our smart devs knew the 19.x size increase was going to be a headache for everyone.
once you get good with configuring extroot I like part1 exfat and part2 ext4 and set extroot to second partiion so microsd card first part is still legible in windows. dont try this out the gate, format the whole card like it ask in the openwrt guide.
I can not install gparted as it is required for do extroot. If I try it to mount it as overlay in luci, I can change the mount point, but zhe sd card is still mounted on /mnt/sda1
