Hi everyone,
Following up on thread #71027 — I've dug into the full-screen video judder / freezes that shows up on V1.10.0 release4 (it was smooth on V1.9.1). I want to share what I found and a workaround, since it affects anyone stuck on V1.10.0 — including people on the built-in Quest Browser who can't modify anything.
Symptom. In full-screen mode the video periodically "freezes then jumps," building up over several minutes. Toggling out of and back into full-screen often buys some time. It's not a network problem — the stream is 1080p@60fps with near-zero packet loss and good jitter.
What I measured. Using chrome://webrtc-internals on the Quest, the inbound-video playout-buffer target sits at about 5 seconds during the juddering "before" state (43 freezes in ~10s). I confirmed that "before" reproduces on a factory-reset, unpatched V1.10.0, so it's not contamination.
The trigger. The deep buffer tracks the playout-delay RTP extension. The Quest is only offering a standard, spec'd extension (that's correct). Something in the negotiation engages it — and once it's negotiated, the browser applies a very deep playout delay to a stream that never actually uses the extension.
I've raised this directly with GL.iNet with the full evidence (webrtc-internals exports, an A/B pair, disassembly notes, reproduction recipe). I'm not trying to lay blame here — I know the team (shoutout to minmie for the stereo build) has been actively engaged. I'm just reporting what I observed. Where they land the permanent fix is entirely their call.
Workaround that works for me. A small client-side patch that stops the playout-delay extension from being negotiated drops the buffer from ~5 s to ~524 ms (2 freezes) — a ~10× reduction — with network/decode unchanged. Caveats, so nobody gets surprised:
- It requires editing the minified web bundle on the Comet Pro, so it breaks on firmware updates and has to be reapplied.
- I'm happy to share the exact patch / steps if anyone wants to try it.
Happy to answer questions or share the data. And if the judder is wrecking your setup too, let me know your firmware + mode — the more data points the better.
