Router’s original interface no longer available - 2
The first version of this topic can be found here:
After trying to repeat the procedure decribed in the old thread to fix the same issue with a second router, I had to open this (new) thread, because there does not seem to be any firmware anymore on the page at
GL.iNet download center (which is now automatically fowarded to a URL that includes the subdirectory "stable")
A search for firmware AR750 leads to other pages, the URLs I cannot mention in this post (limited to 2 URLs), but most of those pages also end up linking back the aforementioned page, and the end result is that I cannot download the firmware.
So the question is now, "where can I download the latest firmware for AR750?"
Thanks again in advance for relevant advice.
Which one version firmware did you want? I try to download it and share to you via other URL.
Accidentally deleted my reply. :frowning: Let's try that again (next post)
Thanks for the offer, @bruce - here is the information I have:
Router with the oldrer firmware (and the interface issue):
|Hostname|GL-AR750|
|Model|GL.iNet GL-AR750|
|Architecture|Qualcomm Atheros QCA9533 ver 2 rev 0|
|Firmware Version|OpenWrt 19.07.10 r11427-9ce6aa9d8d / LuCI openwrt-19.07 branch git-22.099.58928-786ebc9|
|Kernel Version|4.14.275|
Router with the updated firmware (working fine):
|Hostname|GL-AR750|
|Target Platform|ath79/nand|
|Firmware Version|OpenWrt 22.03.4 r20123-38ccc47687 / LuCI openwrt-22.03 branch git-23.093.57104-ce20b4a|
|Kernel Version|5.10.176|
So I guess I'll need version 22.03.4 unless there is a newer one...
Thanks in advance!
Since these are the openwrt and kernel info, Sorry I cannot learn about what GL firmware version.
If you require to get one of the GL firmware, please let me know the GL version on the GL GUI > SYSTEM > Upgrade
Hi again,
I cannot do that check with the router without the GL CI, but the previously updated router shows the following information:
 Current Firmware
    Version 4.3.18
    Firmware Type release1
    Compile Time 2024-08-23 14:53:25(UTC+08:00)
So I imagine I should install Version 4.3.18 on the other router, as well, unless you can provide a newer version that I would then install on both routers...
Thanks again.
@gulkun did you tried to reset it? Hold "reset" button for ten or more seconds. It must help
Hi @wmel, yes. When I use the reset button the router reboots and moves righ to LuCI, and all the network settings have been reset to their default settings.
@gulkun so there is only way to Uboot
@wmel @bruce
UBoot needs to have the firmwae, and bruce was going to make it available here via a new link... :slight_smile:
You can download the AR750 latest firmware here:
It is downloaded from GL firmware download center:
Thanks for the software!
I'll try to install it in the router and then report back here.
Update: I flashed the router and got it to work like the other router, that is, with both the GL interface and the LuCI.
I could not have guessed that the no longer working URL
https://dl.gl-inet.com/router/ar750/
had been replaced by
https://dl.gl-inet.com/router/ar750/stable
Anyway, I have now made backup copies of the binary file on USB memory, as a backup...
Thanks again to @bruce and the other helpful forum members.
A follow-up: after receiving a security update for the router (Creta), I checked to see if I could download an updated binary file from the archive.
What I expected to see in the archive was at least this
plus possibly a new version of the binary file that would incorporate the security update.
But I did not see any files at
this time... is there a different URL I need to know?
Thanks!
Further information: on the page at
there is the following reference:
GL-AR750 4.3.25 Native OpenWrt 22.03.4 Maintenance March 27th, 2023 March 27th, 2025
So where do we find the versions between 4.3.18 (which I recently downloaded from the page shown in the image) and version 4.3.25 ? (0^0)
Click the location of the red box to download the .bin file, this is the firmware.
Bruce_2025-05-08_12-20-39
There is no firmware version released between stable versions 4.3.18 and 4.3.25, for internal tests or beta version numbers. Latest stable firmware is 4.3.25.
Seeing your screenshot I realised that my browser was playing tricks on me
I used a different browser, which showed all files. Downloaded the update OK.
Thanks!
