S2s wireguard issues
I tried a s2s with a B1300 (192.168.8.1) server and a MT300N V2 (192.168.10.1) client with allowed ips ‘192.168.8.0’.
Tunnel goes up and devices of client lan can explore devices of server lan but no Internet on client side.
I added the line ‘list subnet 192.168.10.1/24’ in wireguard server configuration in the line of client.
Devices of server lan can explore devices of client lan only if in client router allowed ips is ‘0.0.0.0/0’ but internet goes on client side through server side.
I’d like to reserve s2s only for traffic lan2lan.
Any idea?
Thanks
Thanks
Solved configuring wireguard on client router by Luci and assigning WG interface to lan zone under firewall settings.
This sounds stupid, but would you care to send me the restore file of your current config? I have /had the same problem but ultimately just gave up on it. (Hoping it’s maybe AR750/s or MT300A or MT300N2)
I tested the scenario and I gave the client router to my friend for his s2s connection office/home so I can’t send configuration to you.
Can I help you in another way?
