Aureal
October 28, 2025, 1:23pm
Hello all,
I have a problem with MT6000 samba share and my Samsung smartphone, as described in this thread: Network Storage on Beryl AX
I can see samba share with my Windows PC but my Samsung smartphone give me a login error (only anonymous access works).
It's a Samsung problem or a MT6000 issue?
Thanks a lot!
The Samsung My Files app doesn’t support some of the newer Samba security measures implemented in the latest MT6000 firmware.
Therefore, we will need to execute the commands mentioned in the thread you referenced to revert this security measure.
Aureal
October 29, 2025, 6:50am
5
hello dear, thanks a lot for the info!
can you please tell me how “revert” the ssh command to the default, for the future?
Just SSH to the router and run commands below to revert
sed -i 's/smb encrypt = auto/smb encrypt = required/g' /etc/samba/smb.conf.template4
reboot
system
Closed
November 28, 2025, 4:32pm
8
