Security Features Roadmap
Just wondering if you have plans of implementing the following security features for your routers
  • vlans / network segmentation
  • intrusion detection system / intrusion prevention system (suricata?)
  • blocking malicious IP addresses
  • geo ip filtering / country blocking
  • vulnerability scanner (open ports etc.)
and other useful security features…
Thanks for the suggestions. We may be able to do some, but not all. Each function including complicated technologies, which may related to privacy etc.
I will have internal discussion about this.
Unless I misunderstand, blocking and filtering are now available with AdGuard under Filters, DNS blocklists (I use a BRUME). You can add the lists you want to accomplish your 3rd and 4th points.
Adguard filtering, is like basic and manual.
Online DNS filtering may have more complete database. Some services have advanced filtering which transfer your data to cloud for analysis. I am not sure how efficient is this. But there is privacy issue for sure.
The problem is, users do not care.
Adguard Home covers mostly domain/dns blocking.
in the list, which are likely to be implemented or makes the most sense to you. Thanks.
See there a list of other known security improvement potential of gl firmware Short test of openwrt-ar750-3.104.bin:
I addet a link to your security improvemt ideas on the other list.
