Short test of openwrt-ar750-3.104.bin
Estimated characteristics
  • Many appreciated functions
  • Pleasant menus for operation
Potential for improvement by security, same like on follow:
Potential for other improvements:
  • Add a section for “snapshots” on GL.iNet download center That will show latest firmware like openwrt-ar750s-3.200.img
  • contrary to “Release Note.txt” message “5. Added Tor function.” on GL.iNet download center , the firmware seems not to support Tor anymore.
I didnt check follow old issues on openwrt-ar750-3.104.bin again:
  • GL-AR750: (DFS), not supported
  • not possible to past initial admin passwort on installation screen to form by rightclick, its working on admin webinterface and advanved admin webinterface fine
  • as initial passwort are only short passworts accepted, after installation are possible to change to max lenght (p.e. WLAN max lenght 63 caracter) passwort on admin web interface
  • change password on admin webinterface, still not change admin password on advanced webinterface too
  • active ssh on wan port by default
  • active ssh by default in general
  • running Open VPN and WireGuard VPN services, even if only one of them or none of them is configured as to be used in the main menu
  • WPA2 Enterprise is missing on Admin menue
  • 750-3.100-1217, Drope down menue from time zone not alphabetical
Some other bugs and improvement proposals, could be found in the bug and iprovement tracking system that has been deleted for some time (and lost weeks of testing by this way):
Thanks for your share.
I am looking since days for a backup of the deleted buglist on:
Now I found one of of the security releated potential for improvements (Bug or Feature Request 144 ):
The status are not clear, because the bugtracer are deleted since some time.
The following issue has been ASSIGNED.
https://bugs.gl-inet.com/view.php?id=144
Reported By: Henry_Bruns
Assigned To: kyson-lok
Project: Routers
Issue ID: 144
Category: None
Severity: minor
Priority: normal
Status: feedback
Type: Feature Request
Date Submitted: 2019-03-04 19:21 UTC
Last Modified: 2019-08-01 07:43 UTC
Summary: Security, NTP, easy to get wrong date and as result
out of date certificates
Description:
Providing secured time source like:
The normal NTP by UDP can easy used to set a wrong time (pe. the right time +
one or more years). The result of this are, the most certificates will be
invalide. Certificate based things wil stopp working.
Secured time source will fix this. I am not a programmer, I dont no how
complicated to implement like this. It can be, NTP by TLS 1.2 time information
will be one good way (TLS 1.3 is without time information).
(0000705) kyson-lok (administrator) - 2019-08-01 07:43
https://bugs.gl-inet.com/view.php?id=144#c705
Why NTP easy to get wrong date?
Issue History
Date Modified Username Field Change
2019-03-04 19:21 Henry_Bruns New Issue
2019-08-01 07:43 kyson-lok Assigned To => kyson-lok
2019-08-01 07:43 kyson-lok Status new => feedback
2019-08-01 07:43 kyson-lok Note Added: 0000705
What do you mean this part?
This cannot be true. ssh is not on wan port.
  • Its possible to input the password on installation procedure by keyboard, a its not possible to input by “mouse rightklick” (that shoulb be about the same like Ctrl V) from Clipboard.
  • For last status of this bug, check the backup of the deleted bugtracer.
I just tried, brand new 3.104 firmware from testing folder for AR750, right click is working,
Chrome, Firefox and Edge
Now i tested a little bit more the firmware 3-1.04, with follow results:
Security issues:
  • after update from 3.1003 to 3-1.04, deactivatet ssh dropebear (because not used in sample envirement) activated by self again, without question
  • after update from 3.1003 to 3-1.04, deactivatet wireguard service (because open vpn and wireguard used in sample envirement) activated by self again, without question
  • after update from 3.1003 to 3-1.04, deactivatet wireguard server service (because not used in sample envirement) activated by self again, without question
Possible local law and CE issue:
  • wifi cahannel 12 and 13 deactivate after update from 3.1003 to 3-1.04, thats sounds like the country selection from installation procedure are changed and the router are now possible not conform to loca law of wifi channels, frequencys and power
  • it can be the DFS is not active, against law of some countrys
Other issues:
  • The Mainmenue lost the possibility to configure the wifi power in small stepps. Now are only about 4 or 5 stepps available.
  • Some of the wifi channels are no more available on main menue (are still available on advanced admin menue)
Thats shoud be enough work for fixing.
Ideas for testing:
  • support of actual chipper suites for vpn
  • deacticating of broken chipper suites for vpn
taking a conservative approach - disabling 2.4GHz 12, 13 and 5 GHz DFS is likely the best policy, I don’t consider this is a bug
OpenWRT can check based on Region to enable/disable features on LUCI - Wireless/AdvancedSettings/CountryCode
I don’t think this should be the case if you reserve the settings. I will check.
The follow bug are checked on actual firmware version openwrt-ar750-3.104.bin and still open:
https://bugs.gl-inet.com/view.php?id=143
Project: Routers
Issue ID: 143
Category: None
Severity: minor
Priority: normal
Status: feedback
Type: Bug Report
Date Submitted: 2019-03-03 23:41 UTC
Last Modified: 2019-03-08 09:36 UTC
Summary: 0000142: Drope down menue from time zone dont change
the time from GMT to par example GMT +1
Description:
In this sample, the time from router dont change from GMT to GMT +1
(0000313) kyson-lok (administrator) - 2019-03-08 09:36
https://bugs.gl-inet.com/view.php?id=143#c313
Which firmware are you using for? It should work.
Issue History
2019-03-03 23:41 Henry_Bruns New Issue
2019-03-08 09:36 kyson-lok Assigned To => kyson-lok
2019-03-08 09:36 kyson-lok Status new => feedback
2019-03-08 09:36 kyson-lok Note Added: 0000313
I just tried and it does not have this problem. You have to wait for the router to sync with time server to update time. This is not supposed to take effect immediately. Just wait a few seconds and update the web page.
The follow looks like still not fixed on openwrt-ar750-3.104.bin:
See the follow picture:
https://bugs.gl-inet.com/view.php?id=142
Assigned To: Jayd1n
Project: Routers
Issue ID: 142
Category: None
Severity: minor
Priority: normal
Status: assigned
Date Submitted: 2019-03-03 23:34 UTC
Last Modified: 2019-03-08 09:31 UTC
Summary: Drope down menue from time zone not alphabetical
Description:
  • go to http://192.168.8.1/index#/timezone
  • select Time Zone "ETC"
  • select "GMT"
  • you get the follow not "alphabetical" drop down menue:
    GMT +1
    GMT +10
    GMT +11
    GMT +12
    GMT +2
    GMT +3
    GMT +4
    GMT +5
    GMT +5
    GMT +6
    GMT +7
    GMT +8
    GMT +9
    GMT -1
    GMT -10
    GMT -11
    GMT -12
    GMT -13
    GMT -14
    GMT -2
    GMT -3
    GMT -4
    GMT -5
    GMT -5
    GMT -6
    GMT -7
    GMT -8
    GMT -9
(0000311) kyson-lok (administrator) - 2019-03-08 09:31
https://bugs.gl-inet.com/view.php?id=142#c311
Should fix it.
Issue History
2019-03-03 23:34 Henry_Bruns New Issue
2019-03-08 09:31 kyson-lok Assigned To => Jayd1n
2019-03-08 09:31 kyson-lok Status new => assigned
2019-03-08 09:31 kyson-lok Note Added: 0000311
Meh… let upstream handle this…
Summary
$ cat tzdata.lua
-- Licensed to the public under the Apache License 2.0.
module "luci.sys.zoneinfo.tzdata"
TZ = {
	{ 'Africa/Abidjan', 'GMT0' },
	{ 'Africa/Accra', 'GMT0' },
	{ 'Africa/Addis Ababa', 'EAT-3' },
	{ 'Africa/Algiers', 'CET-1' },
	{ 'Africa/Asmara', 'EAT-3' },
	{ 'Africa/Bamako', 'GMT0' },
	{ 'Africa/Bangui', 'WAT-1' },
	{ 'Africa/Banjul', 'GMT0' },
	{ 'Africa/Bissau', 'GMT0' },
	{ 'Africa/Blantyre', 'CAT-2' },
	{ 'Africa/Brazzaville', 'WAT-1' },
	{ 'Africa/Bujumbura', 'CAT-2' },
	{ 'Africa/Cairo', 'EET-2' },
	{ 'Africa/Casablanca', '<+01>-1' },
	{ 'Africa/Ceuta', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Africa/Conakry', 'GMT0' },
	{ 'Africa/Dakar', 'GMT0' },
	{ 'Africa/Dar es Salaam', 'EAT-3' },
	{ 'Africa/Djibouti', 'EAT-3' },
	{ 'Africa/Douala', 'WAT-1' },
	{ 'Africa/El Aaiun', '<+01>-1' },
	{ 'Africa/Freetown', 'GMT0' },
	{ 'Africa/Gaborone', 'CAT-2' },
	{ 'Africa/Harare', 'CAT-2' },
	{ 'Africa/Johannesburg', 'SAST-2' },
	{ 'Africa/Juba', 'EAT-3' },
	{ 'Africa/Kampala', 'EAT-3' },
	{ 'Africa/Khartoum', 'CAT-2' },
	{ 'Africa/Kigali', 'CAT-2' },
	{ 'Africa/Kinshasa', 'WAT-1' },
	{ 'Africa/Lagos', 'WAT-1' },
	{ 'Africa/Libreville', 'WAT-1' },
	{ 'Africa/Lome', 'GMT0' },
	{ 'Africa/Luanda', 'WAT-1' },
	{ 'Africa/Lubumbashi', 'CAT-2' },
	{ 'Africa/Lusaka', 'CAT-2' },
	{ 'Africa/Malabo', 'WAT-1' },
	{ 'Africa/Maputo', 'CAT-2' },
	{ 'Africa/Maseru', 'SAST-2' },
	{ 'Africa/Mbabane', 'SAST-2' },
	{ 'Africa/Mogadishu', 'EAT-3' },
	{ 'Africa/Monrovia', 'GMT0' },
	{ 'Africa/Nairobi', 'EAT-3' },
	{ 'Africa/Ndjamena', 'WAT-1' },
	{ 'Africa/Niamey', 'WAT-1' },
	{ 'Africa/Nouakchott', 'GMT0' },
	{ 'Africa/Ouagadougou', 'GMT0' },
	{ 'Africa/Porto-Novo', 'WAT-1' },
	{ 'Africa/Sao Tome', 'GMT0' },
	{ 'Africa/Tripoli', 'EET-2' },
	{ 'Africa/Tunis', 'CET-1' },
	{ 'Africa/Windhoek', 'CAT-2' },
	{ 'America/Adak', 'HST10HDT,M3.2.0,M11.1.0' },
	{ 'America/Anchorage', 'AKST9AKDT,M3.2.0,M11.1.0' },
	{ 'America/Anguilla', 'AST4' },
	{ 'America/Antigua', 'AST4' },
	{ 'America/Araguaina', '<-03>3' },
	{ 'America/Argentina/Buenos Aires', '<-03>3' },
	{ 'America/Argentina/Catamarca', '<-03>3' },
	{ 'America/Argentina/Cordoba', '<-03>3' },
	{ 'America/Argentina/Jujuy', '<-03>3' },
	{ 'America/Argentina/La Rioja', '<-03>3' },
	{ 'America/Argentina/Mendoza', '<-03>3' },
	{ 'America/Argentina/Rio Gallegos', '<-03>3' },
	{ 'America/Argentina/Salta', '<-03>3' },
	{ 'America/Argentina/San Juan', '<-03>3' },
	{ 'America/Argentina/San Luis', '<-03>3' },
	{ 'America/Argentina/Tucuman', '<-03>3' },
	{ 'America/Argentina/Ushuaia', '<-03>3' },
	{ 'America/Aruba', 'AST4' },
	{ 'America/Asuncion', '<-04>4<-03>,M10.1.0/0,M3.4.0/0' },
	{ 'America/Atikokan', 'EST5' },
	{ 'America/Bahia', '<-03>3' },
	{ 'America/Bahia Banderas', 'CST6CDT,M4.1.0,M10.5.0' },
	{ 'America/Barbados', 'AST4' },
	{ 'America/Belem', '<-03>3' },
	{ 'America/Belize', 'CST6' },
	{ 'America/Blanc-Sablon', 'AST4' },
	{ 'America/Boa Vista', '<-04>4' },
	{ 'America/Bogota', '<-05>5' },
	{ 'America/Boise', 'MST7MDT,M3.2.0,M11.1.0' },
	{ 'America/Cambridge Bay', 'MST7MDT,M3.2.0,M11.1.0' },
	{ 'America/Campo Grande', '<-04>4' },
	{ 'America/Cancun', 'EST5' },
	{ 'America/Caracas', '<-04>4' },
	{ 'America/Cayenne', '<-03>3' },
	{ 'America/Cayman', 'EST5' },
	{ 'America/Chicago', 'CST6CDT,M3.2.0,M11.1.0' },
	{ 'America/Chihuahua', 'MST7MDT,M4.1.0,M10.5.0' },
	{ 'America/Costa Rica', 'CST6' },
	{ 'America/Creston', 'MST7' },
	{ 'America/Cuiaba', '<-04>4' },
	{ 'America/Curacao', 'AST4' },
	{ 'America/Danmarkshavn', 'GMT0' },
	{ 'America/Dawson', 'MST7' },
	{ 'America/Dawson Creek', 'MST7' },
	{ 'America/Denver', 'MST7MDT,M3.2.0,M11.1.0' },
	{ 'America/Detroit', 'EST5EDT,M3.2.0,M11.1.0' },
	{ 'America/Dominica', 'AST4' },
	{ 'America/Edmonton', 'MST7MDT,M3.2.0,M11.1.0' },
	{ 'America/Eirunepe', '<-05>5' },
	{ 'America/El Salvador', 'CST6' },
	{ 'America/Fort Nelson', 'MST7' },
	{ 'America/Fortaleza', '<-03>3' },
	{ 'America/Glace Bay', 'AST4ADT,M3.2.0,M11.1.0' },
	{ 'America/Goose Bay', 'AST4ADT,M3.2.0,M11.1.0' },
	{ 'America/Grand Turk', 'EST5EDT,M3.2.0,M11.1.0' },
	{ 'America/Grenada', 'AST4' },
	{ 'America/Guadeloupe', 'AST4' },
	{ 'America/Guatemala', 'CST6' },
	{ 'America/Guayaquil', '<-05>5' },
	{ 'America/Guyana', '<-04>4' },
	{ 'America/Halifax', 'AST4ADT,M3.2.0,M11.1.0' },
	{ 'America/Havana', 'CST5CDT,M3.2.0/0,M11.1.0/1' },
	{ 'America/Hermosillo', 'MST7' },
	{ 'America/Indiana/Indianapolis', 'EST5EDT,M3.2.0,M11.1.0' },
	{ 'America/Indiana/Knox', 'CST6CDT,M3.2.0,M11.1.0' },
	{ 'America/Indiana/Marengo', 'EST5EDT,M3.2.0,M11.1.0' },
	{ 'America/Indiana/Petersburg', 'EST5EDT,M3.2.0,M11.1.0' },
	{ 'America/Indiana/Tell City', 'CST6CDT,M3.2.0,M11.1.0' },
	{ 'America/Indiana/Vevay', 'EST5EDT,M3.2.0,M11.1.0' },
	{ 'America/Indiana/Vincennes', 'EST5EDT,M3.2.0,M11.1.0' },
	{ 'America/Indiana/Winamac', 'EST5EDT,M3.2.0,M11.1.0' },
	{ 'America/Inuvik', 'MST7MDT,M3.2.0,M11.1.0' },
	{ 'America/Iqaluit', 'EST5EDT,M3.2.0,M11.1.0' },
	{ 'America/Jamaica', 'EST5' },
	{ 'America/Juneau', 'AKST9AKDT,M3.2.0,M11.1.0' },
	{ 'America/Kentucky/Louisville', 'EST5EDT,M3.2.0,M11.1.0' },
	{ 'America/Kentucky/Monticello', 'EST5EDT,M3.2.0,M11.1.0' },
	{ 'America/Kralendijk', 'AST4' },
	{ 'America/La Paz', '<-04>4' },
	{ 'America/Lima', '<-05>5' },
	{ 'America/Los Angeles', 'PST8PDT,M3.2.0,M11.1.0' },
	{ 'America/Lower Princes', 'AST4' },
	{ 'America/Maceio', '<-03>3' },
	{ 'America/Managua', 'CST6' },
	{ 'America/Manaus', '<-04>4' },
	{ 'America/Marigot', 'AST4' },
	{ 'America/Martinique', 'AST4' },
	{ 'America/Matamoros', 'CST6CDT,M3.2.0,M11.1.0' },
	{ 'America/Mazatlan', 'MST7MDT,M4.1.0,M10.5.0' },
	{ 'America/Menominee', 'CST6CDT,M3.2.0,M11.1.0' },
	{ 'America/Merida', 'CST6CDT,M4.1.0,M10.5.0' },
	{ 'America/Metlakatla', 'AKST9AKDT,M3.2.0,M11.1.0' },
	{ 'America/Mexico City', 'CST6CDT,M4.1.0,M10.5.0' },
	{ 'America/Miquelon', '<-03>3<-02>,M3.2.0,M11.1.0' },
	{ 'America/Moncton', 'AST4ADT,M3.2.0,M11.1.0' },
	{ 'America/Monterrey', 'CST6CDT,M4.1.0,M10.5.0' },
	{ 'America/Montevideo', '<-03>3' },
	{ 'America/Montserrat', 'AST4' },
	{ 'America/Nassau', 'EST5EDT,M3.2.0,M11.1.0' },
	{ 'America/New York', 'EST5EDT,M3.2.0,M11.1.0' },
	{ 'America/Nipigon', 'EST5EDT,M3.2.0,M11.1.0' },
	{ 'America/Nome', 'AKST9AKDT,M3.2.0,M11.1.0' },
	{ 'America/Noronha', '<-02>2' },
	{ 'America/North Dakota/Beulah', 'CST6CDT,M3.2.0,M11.1.0' },
	{ 'America/North Dakota/Center', 'CST6CDT,M3.2.0,M11.1.0' },
	{ 'America/North Dakota/New Salem', 'CST6CDT,M3.2.0,M11.1.0' },
	{ 'America/Nuuk', '<-03>3<-02>,M3.5.0/-2,M10.5.0/-1' },
	{ 'America/Ojinaga', 'MST7MDT,M3.2.0,M11.1.0' },
	{ 'America/Panama', 'EST5' },
	{ 'America/Pangnirtung', 'EST5EDT,M3.2.0,M11.1.0' },
	{ 'America/Paramaribo', '<-03>3' },
	{ 'America/Phoenix', 'MST7' },
	{ 'America/Port of Spain', 'AST4' },
	{ 'America/Port-au-Prince', 'EST5EDT,M3.2.0,M11.1.0' },
	{ 'America/Porto Velho', '<-04>4' },
	{ 'America/Puerto Rico', 'AST4' },
	{ 'America/Punta Arenas', '<-03>3' },
	{ 'America/Rainy River', 'CST6CDT,M3.2.0,M11.1.0' },
	{ 'America/Rankin Inlet', 'CST6CDT,M3.2.0,M11.1.0' },
	{ 'America/Recife', '<-03>3' },
	{ 'America/Regina', 'CST6' },
	{ 'America/Resolute', 'CST6CDT,M3.2.0,M11.1.0' },
	{ 'America/Rio Branco', '<-05>5' },
	{ 'America/Santarem', '<-03>3' },
	{ 'America/Santiago', '<-04>4<-03>,M9.1.6/24,M4.1.6/24' },
	{ 'America/Santo Domingo', 'AST4' },
	{ 'America/Sao Paulo', '<-03>3' },
	{ 'America/Scoresbysund', '<-01>1<+00>,M3.5.0/0,M10.5.0/1' },
	{ 'America/Sitka', 'AKST9AKDT,M3.2.0,M11.1.0' },
	{ 'America/St Barthelemy', 'AST4' },
	{ 'America/St Johns', 'NST3:30NDT,M3.2.0,M11.1.0' },
	{ 'America/St Kitts', 'AST4' },
	{ 'America/St Lucia', 'AST4' },
	{ 'America/St Thomas', 'AST4' },
	{ 'America/St Vincent', 'AST4' },
	{ 'America/Swift Current', 'CST6' },
	{ 'America/Tegucigalpa', 'CST6' },
	{ 'America/Thule', 'AST4ADT,M3.2.0,M11.1.0' },
	{ 'America/Thunder Bay', 'EST5EDT,M3.2.0,M11.1.0' },
	{ 'America/Tijuana', 'PST8PDT,M3.2.0,M11.1.0' },
	{ 'America/Toronto', 'EST5EDT,M3.2.0,M11.1.0' },
	{ 'America/Tortola', 'AST4' },
	{ 'America/Vancouver', 'PST8PDT,M3.2.0,M11.1.0' },
	{ 'America/Whitehorse', 'MST7' },
	{ 'America/Winnipeg', 'CST6CDT,M3.2.0,M11.1.0' },
	{ 'America/Yakutat', 'AKST9AKDT,M3.2.0,M11.1.0' },
	{ 'America/Yellowknife', 'MST7MDT,M3.2.0,M11.1.0' },
	{ 'Antarctica/Casey', '<+08>-8' },
	{ 'Antarctica/Davis', '<+07>-7' },
	{ 'Antarctica/DumontDUrville', '<+10>-10' },
	{ 'Antarctica/Macquarie', '<+11>-11' },
	{ 'Antarctica/Mawson', '<+05>-5' },
	{ 'Antarctica/McMurdo', 'NZST-12NZDT,M9.5.0,M4.1.0/3' },
	{ 'Antarctica/Palmer', '<-03>3' },
	{ 'Antarctica/Rothera', '<-03>3' },
	{ 'Antarctica/Syowa', '<+03>-3' },
	{ 'Antarctica/Troll', '<+00>0<+02>-2,M3.5.0/1,M10.5.0/3' },
	{ 'Antarctica/Vostok', '<+06>-6' },
	{ 'Arctic/Longyearbyen', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Asia/Aden', '<+03>-3' },
	{ 'Asia/Almaty', '<+06>-6' },
	{ 'Asia/Amman', 'EET-2EEST,M3.5.4/24,M10.5.5/1' },
	{ 'Asia/Anadyr', '<+12>-12' },
	{ 'Asia/Aqtau', '<+05>-5' },
	{ 'Asia/Aqtobe', '<+05>-5' },
	{ 'Asia/Ashgabat', '<+05>-5' },
	{ 'Asia/Atyrau', '<+05>-5' },
	{ 'Asia/Baghdad', '<+03>-3' },
	{ 'Asia/Bahrain', '<+03>-3' },
	{ 'Asia/Baku', '<+04>-4' },
	{ 'Asia/Bangkok', '<+07>-7' },
	{ 'Asia/Barnaul', '<+07>-7' },
	{ 'Asia/Beirut', 'EET-2EEST,M3.5.0/0,M10.5.0/0' },
	{ 'Asia/Bishkek', '<+06>-6' },
	{ 'Asia/Brunei', '<+08>-8' },
	{ 'Asia/Chita', '<+09>-9' },
	{ 'Asia/Choibalsan', '<+08>-8' },
	{ 'Asia/Colombo', '<+0530>-5:30' },
	{ 'Asia/Damascus', 'EET-2EEST,M3.5.5/0,M10.5.5/0' },
	{ 'Asia/Dhaka', '<+06>-6' },
	{ 'Asia/Dili', '<+09>-9' },
	{ 'Asia/Dubai', '<+04>-4' },
	{ 'Asia/Dushanbe', '<+05>-5' },
	{ 'Asia/Famagusta', 'EET-2EEST,M3.5.0/3,M10.5.0/4' },
	{ 'Asia/Gaza', 'EET-2EEST,M3.5.5/0,M10.5.6/1' },
	{ 'Asia/Hebron', 'EET-2EEST,M3.5.5/0,M10.5.6/1' },
	{ 'Asia/Ho Chi Minh', '<+07>-7' },
	{ 'Asia/Hong Kong', 'HKT-8' },
	{ 'Asia/Hovd', '<+07>-7' },
	{ 'Asia/Irkutsk', '<+08>-8' },
	{ 'Asia/Jakarta', 'WIB-7' },
	{ 'Asia/Jayapura', 'WIT-9' },
	{ 'Asia/Jerusalem', 'IST-2IDT,M3.4.4/26,M10.5.0' },
	{ 'Asia/Kabul', '<+0430>-4:30' },
	{ 'Asia/Kamchatka', '<+12>-12' },
	{ 'Asia/Karachi', 'PKT-5' },
	{ 'Asia/Kathmandu', '<+0545>-5:45' },
	{ 'Asia/Khandyga', '<+09>-9' },
	{ 'Asia/Kolkata', 'IST-5:30' },
	{ 'Asia/Krasnoyarsk', '<+07>-7' },
	{ 'Asia/Kuala Lumpur', '<+08>-8' },
	{ 'Asia/Kuching', '<+08>-8' },
	{ 'Asia/Kuwait', '<+03>-3' },
	{ 'Asia/Macau', 'CST-8' },
	{ 'Asia/Magadan', '<+11>-11' },
	{ 'Asia/Makassar', 'WITA-8' },
	{ 'Asia/Manila', 'PST-8' },
	{ 'Asia/Muscat', '<+04>-4' },
	{ 'Asia/Nicosia', 'EET-2EEST,M3.5.0/3,M10.5.0/4' },
	{ 'Asia/Novokuznetsk', '<+07>-7' },
	{ 'Asia/Novosibirsk', '<+07>-7' },
	{ 'Asia/Omsk', '<+06>-6' },
	{ 'Asia/Oral', '<+05>-5' },
	{ 'Asia/Phnom Penh', '<+07>-7' },
	{ 'Asia/Pontianak', 'WIB-7' },
	{ 'Asia/Pyongyang', 'KST-9' },
	{ 'Asia/Qatar', '<+03>-3' },
	{ 'Asia/Qostanay', '<+06>-6' },
	{ 'Asia/Qyzylorda', '<+05>-5' },
	{ 'Asia/Riyadh', '<+03>-3' },
	{ 'Asia/Sakhalin', '<+11>-11' },
	{ 'Asia/Samarkand', '<+05>-5' },
	{ 'Asia/Seoul', 'KST-9' },
	{ 'Asia/Shanghai', 'CST-8' },
	{ 'Asia/Singapore', '<+08>-8' },
	{ 'Asia/Srednekolymsk', '<+11>-11' },
	{ 'Asia/Taipei', 'CST-8' },
	{ 'Asia/Tashkent', '<+05>-5' },
	{ 'Asia/Tbilisi', '<+04>-4' },
	{ 'Asia/Tehran', '<+0330>-3:30<+0430>,J79/24,J263/24' },
	{ 'Asia/Thimphu', '<+06>-6' },
	{ 'Asia/Tokyo', 'JST-9' },
	{ 'Asia/Tomsk', '<+07>-7' },
	{ 'Asia/Ulaanbaatar', '<+08>-8' },
	{ 'Asia/Urumqi', '<+06>-6' },
	{ 'Asia/Ust-Nera', '<+10>-10' },
	{ 'Asia/Vientiane', '<+07>-7' },
	{ 'Asia/Vladivostok', '<+10>-10' },
	{ 'Asia/Yakutsk', '<+09>-9' },
	{ 'Asia/Yangon', '<+0630>-6:30' },
	{ 'Asia/Yekaterinburg', '<+05>-5' },
	{ 'Asia/Yerevan', '<+04>-4' },
	{ 'Atlantic/Azores', '<-01>1<+00>,M3.5.0/0,M10.5.0/1' },
	{ 'Atlantic/Bermuda', 'AST4ADT,M3.2.0,M11.1.0' },
	{ 'Atlantic/Canary', 'WET0WEST,M3.5.0/1,M10.5.0' },
	{ 'Atlantic/Cape Verde', '<-01>1' },
	{ 'Atlantic/Faroe', 'WET0WEST,M3.5.0/1,M10.5.0' },
	{ 'Atlantic/Madeira', 'WET0WEST,M3.5.0/1,M10.5.0' },
	{ 'Atlantic/Reykjavik', 'GMT0' },
	{ 'Atlantic/South Georgia', '<-02>2' },
	{ 'Atlantic/St Helena', 'GMT0' },
	{ 'Atlantic/Stanley', '<-03>3' },
	{ 'Australia/Adelaide', 'ACST-9:30ACDT,M10.1.0,M4.1.0/3' },
	{ 'Australia/Brisbane', 'AEST-10' },
	{ 'Australia/Broken Hill', 'ACST-9:30ACDT,M10.1.0,M4.1.0/3' },
	{ 'Australia/Currie', 'AEST-10AEDT,M10.1.0,M4.1.0/3' },
	{ 'Australia/Darwin', 'ACST-9:30' },
	{ 'Australia/Eucla', '<+0845>-8:45' },
	{ 'Australia/Hobart', 'AEST-10AEDT,M10.1.0,M4.1.0/3' },
	{ 'Australia/Lindeman', 'AEST-10' },
	{ 'Australia/Lord Howe', '<+1030>-10:30<+11>-11,M10.1.0,M4.1.0' },
	{ 'Australia/Melbourne', 'AEST-10AEDT,M10.1.0,M4.1.0/3' },
	{ 'Australia/Perth', 'AWST-8' },
	{ 'Australia/Sydney', 'AEST-10AEDT,M10.1.0,M4.1.0/3' },
	{ 'Etc/GMT', 'GMT0' },
	{ 'Etc/GMT+1', '<-01>1' },
	{ 'Etc/GMT+10', '<-10>10' },
	{ 'Etc/GMT+11', '<-11>11' },
	{ 'Etc/GMT+12', '<-12>12' },
	{ 'Etc/GMT+2', '<-02>2' },
	{ 'Etc/GMT+3', '<-03>3' },
	{ 'Etc/GMT+4', '<-04>4' },
	{ 'Etc/GMT+5', '<-05>5' },
	{ 'Etc/GMT+6', '<-06>6' },
	{ 'Etc/GMT+7', '<-07>7' },
	{ 'Etc/GMT+8', '<-08>8' },
	{ 'Etc/GMT+9', '<-09>9' },
	{ 'Etc/GMT-1', '<+01>-1' },
	{ 'Etc/GMT-10', '<+10>-10' },
	{ 'Etc/GMT-11', '<+11>-11' },
	{ 'Etc/GMT-12', '<+12>-12' },
	{ 'Etc/GMT-13', '<+13>-13' },
	{ 'Etc/GMT-14', '<+14>-14' },
	{ 'Etc/GMT-2', '<+02>-2' },
	{ 'Etc/GMT-3', '<+03>-3' },
	{ 'Etc/GMT-4', '<+04>-4' },
	{ 'Etc/GMT-5', '<+05>-5' },
	{ 'Etc/GMT-6', '<+06>-6' },
	{ 'Etc/GMT-7', '<+07>-7' },
	{ 'Etc/GMT-8', '<+08>-8' },
	{ 'Etc/GMT-9', '<+09>-9' },
	{ 'Europe/Amsterdam', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Andorra', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Astrakhan', '<+04>-4' },
	{ 'Europe/Athens', 'EET-2EEST,M3.5.0/3,M10.5.0/4' },
	{ 'Europe/Belgrade', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Berlin', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Bratislava', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Brussels', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Bucharest', 'EET-2EEST,M3.5.0/3,M10.5.0/4' },
	{ 'Europe/Budapest', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Busingen', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Chisinau', 'EET-2EEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Copenhagen', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Dublin', 'IST-1GMT0,M10.5.0,M3.5.0/1' },
	{ 'Europe/Gibraltar', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Guernsey', 'GMT0BST,M3.5.0/1,M10.5.0' },
	{ 'Europe/Helsinki', 'EET-2EEST,M3.5.0/3,M10.5.0/4' },
	{ 'Europe/Isle of Man', 'GMT0BST,M3.5.0/1,M10.5.0' },
	{ 'Europe/Istanbul', '<+03>-3' },
	{ 'Europe/Jersey', 'GMT0BST,M3.5.0/1,M10.5.0' },
	{ 'Europe/Kaliningrad', 'EET-2' },
	{ 'Europe/Kiev', 'EET-2EEST,M3.5.0/3,M10.5.0/4' },
	{ 'Europe/Kirov', '<+03>-3' },
	{ 'Europe/Lisbon', 'WET0WEST,M3.5.0/1,M10.5.0' },
	{ 'Europe/Ljubljana', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/London', 'GMT0BST,M3.5.0/1,M10.5.0' },
	{ 'Europe/Luxembourg', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Madrid', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Malta', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Mariehamn', 'EET-2EEST,M3.5.0/3,M10.5.0/4' },
	{ 'Europe/Minsk', '<+03>-3' },
	{ 'Europe/Monaco', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Moscow', 'MSK-3' },
	{ 'Europe/Oslo', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Paris', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Podgorica', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Prague', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Riga', 'EET-2EEST,M3.5.0/3,M10.5.0/4' },
	{ 'Europe/Rome', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Samara', '<+04>-4' },
	{ 'Europe/San Marino', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Sarajevo', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Saratov', '<+04>-4' },
	{ 'Europe/Simferopol', 'MSK-3' },
	{ 'Europe/Skopje', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Sofia', 'EET-2EEST,M3.5.0/3,M10.5.0/4' },
	{ 'Europe/Stockholm', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Tallinn', 'EET-2EEST,M3.5.0/3,M10.5.0/4' },
	{ 'Europe/Tirane', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Ulyanovsk', '<+04>-4' },
	{ 'Europe/Uzhgorod', 'EET-2EEST,M3.5.0/3,M10.5.0/4' },
	{ 'Europe/Vaduz', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Vatican', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Vienna', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Vilnius', 'EET-2EEST,M3.5.0/3,M10.5.0/4' },
	{ 'Europe/Volgograd', '<+04>-4' },
	{ 'Europe/Warsaw', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Zagreb', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Europe/Zaporozhye', 'EET-2EEST,M3.5.0/3,M10.5.0/4' },
	{ 'Europe/Zurich', 'CET-1CEST,M3.5.0,M10.5.0/3' },
	{ 'Indian/Antananarivo', 'EAT-3' },
	{ 'Indian/Chagos', '<+06>-6' },
	{ 'Indian/Christmas', '<+07>-7' },
	{ 'Indian/Cocos', '<+0630>-6:30' },
	{ 'Indian/Comoro', 'EAT-3' },
	{ 'Indian/Kerguelen', '<+05>-5' },
	{ 'Indian/Mahe', '<+04>-4' },
	{ 'Indian/Maldives', '<+05>-5' },
	{ 'Indian/Mauritius', '<+04>-4' },
	{ 'Indian/Mayotte', 'EAT-3' },
	{ 'Indian/Reunion', '<+04>-4' },
	{ 'Pacific/Apia', '<+13>-13<+14>,M9.5.0/3,M4.1.0/4' },
	{ 'Pacific/Auckland', 'NZST-12NZDT,M9.5.0,M4.1.0/3' },
	{ 'Pacific/Bougainville', '<+11>-11' },
	{ 'Pacific/Chatham', '<+1245>-12:45<+1345>,M9.5.0/2:45,M4.1.0/3:45' },
	{ 'Pacific/Chuuk', '<+10>-10' },
	{ 'Pacific/Easter', '<-06>6<-05>,M9.1.6/22,M4.1.6/22' },
	{ 'Pacific/Efate', '<+11>-11' },
	{ 'Pacific/Enderbury', '<+13>-13' },
	{ 'Pacific/Fakaofo', '<+13>-13' },
	{ 'Pacific/Fiji', '<+12>-12<+13>,M11.2.0,M1.2.3/99' },
	{ 'Pacific/Funafuti', '<+12>-12' },
	{ 'Pacific/Galapagos', '<-06>6' },
	{ 'Pacific/Gambier', '<-09>9' },
	{ 'Pacific/Guadalcanal', '<+11>-11' },
	{ 'Pacific/Guam', 'ChST-10' },
	{ 'Pacific/Honolulu', 'HST10' },
	{ 'Pacific/Kiritimati', '<+14>-14' },
	{ 'Pacific/Kosrae', '<+11>-11' },
	{ 'Pacific/Kwajalein', '<+12>-12' },
	{ 'Pacific/Majuro', '<+12>-12' },
	{ 'Pacific/Marquesas', '<-0930>9:30' },
	{ 'Pacific/Midway', 'SST11' },
	{ 'Pacific/Nauru', '<+12>-12' },
	{ 'Pacific/Niue', '<-11>11' },
	{ 'Pacific/Norfolk', '<+11>-11<+12>,M10.1.0,M4.1.0/3' },
	{ 'Pacific/Noumea', '<+11>-11' },
	{ 'Pacific/Pago Pago', 'SST11' },
	{ 'Pacific/Palau', '<+09>-9' },
	{ 'Pacific/Pitcairn', '<-08>8' },
	{ 'Pacific/Pohnpei', '<+11>-11' },
	{ 'Pacific/Port Moresby', '<+10>-10' },
	{ 'Pacific/Rarotonga', '<-10>10' },
	{ 'Pacific/Saipan', 'ChST-10' },
	{ 'Pacific/Tahiti', '<-10>10' },
	{ 'Pacific/Tarawa', '<+12>-12' },
	{ 'Pacific/Tongatapu', '<+13>-13' },
	{ 'Pacific/Wake', '<+12>-12' },
	{ 'Pacific/Wallis', '<+12>-12' },
THX for fix this.
one thing more, from an old and still open bug (i dont find a copy of this and the bug number from deleted bugtracker on this time). They are wrong translation on navigation menue on Admin menue. The english word “Wireless” ist translated as “Kabellos” in German. Thats possible to understand, a its wrong. The right translation in German is “Drahtlos”.
For more inormation, check the backup of deleted bugtracker: https://bugs.gl-inet.com
Does something else is needed to correct the wrong translated menu item ?
Lets improve products for customers and shareholders. Especially, get the bugs fixed, which can be easily fixed.
The follow point are possible open:
  • Checking by gl router used chipper suites for unnecessary slow or broken
The status cant check, depend on deleted bugtracker. Depend on this, I open this one again, now on gl forum:
Today I have seen some good security improvement ideas for gl firmware from Rek:
One more:
  • I have seen its looks like the actual firmware still use non secured NTP. Its possible to fix this security issue by replace this by p.e. tlsdate or equal. Thats use the time stamp from p.e. TLS 1.2 for getting the time and the date.
  • For more information check the deleted gl bugtracer https://bugs.gl-inet.com
  • I think at minimum a valide date from a trusted source are importand for validation of certificates.
tlsdate is a one-shot, so it’s not really a replacement for ntp…
ntpsec would be the right approach perhaps…
Additional see the from modumb reported bug:
Addet from GL-AR-750 Creta, broken after update firmware from 3.104 to 3.105
It can be it will help for constantly improve the firmware:
  • not to use one firmware version number for more than one version (for deleted and current newer versions)
  • restore and use the deleted bug tracker
  • inform transparently for every future firmware version, which bugs was fixed on new firmware version and which features were added
Thats my two cents on this
Look forward.
