Hi there, this may be a really basic network question that isn’t specific to GL.iNet routers, just networking in general, but how do I setup the name of the local network on my GL-MT300N-V2? When I go to my network connection on Windows 10, it just says ‘Network 7’ or on my Windows 7 machine it shows ‘Network 3’. On my main Asus router, the LAN connection name is the same as whatever I set the WiFi SSID to. Is there anyway to do this on the Mango router?
Well, I don’t have a mt1300 but I know if you have the wireless on you can change it’s name by logging into it, select wireless, and where it shows the WIFI NAme (SSD) you can change it by selecting modify and change that name to what you want. Then click on apply. That is what I have on my AR150 units for the wifi side. I hope I am not speaking out wrong as it is a different router but some have some same software. Good luck.
