SFT1200 Repeater Mode is OFF randomly after reboots
Hi there, I'll describe my setup:
GL-SFT1200 in Repeater Mode, connected to the building's WiFi.
Several devices connected WIFI
One device connected through Ethernet
Often after the router reboots, it does not re-enter Repeater Mode. Navigating to 192.168.8.1 shows the Repeater is OFF.
Can this please be addressed? That setting is extremely important to be retained across reboots, as it can take an entire network down for a really silly reason.
Thank you!
It should reconnect if you don't disable manually.
Sometimes it just takes a little time. Sometimes it may failed to reconnect for some reason.
So pls get me the log when this happens.
What channel is the building WiFi broadcasting on?
Thanks, it doesn't reconnect. I went out of town, the router reset itself and never came back online for the entire week I was away. Upon return, Repeater Mode was disabled.
Happy to provide a log, but the default log length is tiny and only goes back an hour. How do I set the log length to be unrestricted?
Thank you!
When the router failed to connect to one wifi for many times, or if it get key error messages, it will disable the SSID.
If this is the issue, I'm open to scripting the Repeater to re-enable once per hour, or whatever fixes this situation.
It's really disruptive to lose access to my network when I'm working remotely, and have literally no way to reboot/re-enable the Repeater from afar. At least if I added a command to cron to simply "re-enable Repeater" every x minutes, the network would at least eventually come back online.
Any ideas how to do that?
Hi there, this is still an ongoing issue - and is particularly bad because I'm using remote devices in a different city, and have to get someone to visit the location in person to simply click "Enable Repeater".
Please can you offer a scripted solution? All that needs to happen is, maybe once every 5 minutes, if Repeater mode was selected, ensure Repeater is Enabled/Connected to default device.
Literally, I'm having someone go to the office to click "Enable/Connect" and then it starts working. Please can we automate this process, this is very disruptive and seems so simple to fix. I really appreciate it!
Really less important to me why this is happening, and more just need a solution. This is happening every few days - the SFT1200 disconnects (for whatever reason), then Repeater Mode suddenly is Disabled. Just need this to automatically re-enable and re-connect on a regular interval.
OK. Let me feedback to the developer about this.
Thanks so much ! Happy to help debug if this useful.
A short answer is that the repeater is optimized to reconnect better on firmware 4.7.0 and later. Unfortunately SFT1200 still does not have 4.7.0 yet.
I also have the same issue, this has happened since day 1 of using the product. Will this ever be solved?
yup still happening.
I'm sure i'm oversimplifying here ---- but isn't this a very simple check?
"If Repeater Mode WAS on, ensure it's ALWAYS ON unless specifically disabled".
Or another way to put it --- in no circumstance should Repeater Mode ever turn off, unless you literally manually turn it off. It seems like this can be easily done in a cron script?
Anyone tried 4.7 GL.iNet download center
