Simpoyo physical esim
Can i use simpoyo data plans with simpoyo physical esim on mudi 7? Asking cause its not listed under
Carriers supported by GL.iNet physical eSIM
Using the Mudi 7 with simpoyo physical eSIM and simpoyo data plans should be fine.
However, please note that since Mudi 7 already has a built-in eSIM, you may not be able to manage the simpoyo physical eSIM using the eSIM Manager on Mudi 7 directly.
You will need to activate the simpoyo data plans on the simpoyo physical eSIM using another device first, and then move it back to the Mudi 7 for use.
Thank you!
