I applied for Beta, it will be interesting to try Slate 7 in place of about 15-18 other GL.inet products I already have deployed for various things and test how much of an improvment we get.
Hello @alzhao, can we have a little tease about the Slate 7? Will it be available in January for beta testers?
OpenWrt 24-based firmware would be huge
Blue USB port, so 3.0?
Looks like the ports aren't independent
why in 2025 still usb-A port ?????
USB Sticks are still pretty USB-A-like
USB-A ports are still widely used. You can use an USB-A to USB-C dongles that work really well, I use them and they are dirt cheap.Yes I know dongles are a hassle and why do we need to use dongles when we can just use USB-C ports?? Cost and it's not just for port it self. PCB needs to be designed from ground up. Or just use USB-A cable since there are so many variations are available now days. I know I know, I also wish that everything was USB-C now days and all USB-C ports were 120Gbps and 240Watts, but transition takes a lot of time.
So it doesn't confuse people which port is for data and which one is for power if both ports are sub-c.
So people won't ask: why can't both USB-C ports be used for power and for data? Which would add more cost and require adding clear signage.
In 2025, it should be the other way around... use a USB-C adapter if you still use USB-A whatever..
Has the beta test program for the Slate 7 already started, or not yet? I signed up for it but have not been contacted yet.
The angle is not quite the same, but I used the USB 3 in the three photos as a reference for size, and I think the Slate 7 is slightly bulkier than the Slate AXT 1800, or possibly about the same size.
You can always start your own company and make wifi routers with usb-c ports. Its not that difficult in 2025, right?
New routers "Slate 7 and Flint 3" will be unveiled today! Check your e-mails if you haven't already.
Yes, I received it, but it's just the invitation to the booth for now; hope we will know more later today.
I just saw this little photo in the mail, confirming that the front of the Slate 7 is indeed a small OLED screen. That's a really cool improvement! ![]()
For traveling that little screen will be really useful, I hope you can customize the information that it will display.
Off topic but a Flint router with a screen like this at home would be awesome, even if it only shows the bandwidth usage, like some products from other brands, of course that would increase the price
i think something like how Ubiquiti does it would be nice i believe they used to have these small screens with wave like patterns on their switches when there is activity, or maybe that it change status info in a interval.
Slightly bigger than Beryl AX. Dual 2.5Gb ethernet ports. It has a touchscreen. Supports MLO
