5Ghz Wi-Fi drops randomly every few days, 2.4Ghz drops at the same time but comes back up with 5Ghz down. I’ve reset the configuration, and it still happened; I can’t login or SSH to grab the logs.
I remember similar issues with beta versions that used the newer kernel, but this is just my guess.
Using official power supply, rolled back in the meantime.
To better understand the issue, we’d like to confirm a few points:
Which firmware version did you upgrade from, and which version did you upgrade to?
When the problem occurs, does it affect the wired connection as well, or only wireless?
You mentioned being unable to log in or SSH to retrieve logs — was this because the router rebooted automatically, which may have cleared some logs?
4.6.11 to 4.8.2
I haven't tested, will test when I have the backup router/AP setup.
The router does not reboot. Existing connected clients on 2.4Ghz remain connected with unresponsive gateway, disconnecting and re-establishing the connection from the clients does not work in this state by Wi-Fi authentication failure.
I should add that an AP is connected to the Slate via WDS.
LuCI wasn't used and no custom modification on the second attempt.
Split wireguard VPN tunnels don’t work anymore.
With ‘split’ I mean that the AllowedIPs section contains a list of IP ranges which should go through the VPN (instead of 0.0.0.0/0). The other IPs go straight to the internet. And that latter does not work, only the AllowedIPs do connect via the tunnel.
I have switched off VPN kill switch and DNS masquerading but to no avail.
Given that you are using an Access Point (AP) connected via WDS, we have a couple of questions want to further check with you:
Could you please provide the model of your AP? If it is a GL.iNet device, please also include the firmware version.
Does the issue only affect devices connected to the AP, or are devices connected directly to the Slate AX also experiencing the problem?
More feedback.
Something wrong with the available package list.
I do not see many needed packages, like
fdisk
dawn (and luci app for it)
etc.
(reproduced after full reset)
I assume you want only IP addresses within the Allowed-IPs list to pass through the VPN tunnel.
This can be achieved using VPN policy mode on 4.8.x.
Please refer to the following documentation for more details.
VPN Dashboard - GL.iNet Router Docs 4
Could you provide us with a specific list so we can ask the R&D team to see if these packages can be added?
Sorry, forgot to answer.
At least
luci-app-upnp
luci-app-dawn
luci-app-statistics
kmod-fs-f2fs
collectd-mod-sensors
dawn
tcpdump
fdisk
That’s what I use now, and not all was available in 4.8
We have requested the R&D team to investigate their availability, and if all goes well, they will be added to the repository.
I also have a couple of packages I depend on missing,
Thanks
We have informed the R&D team and will attempt to add them.
Just wanted to let you know these plugins have been added.
glinoob
November 28, 2025, 11:30pm
18
I have a question related to missing packages on GL-AXT1800, maybe you can answer?
Question: is GL.iNet keeping a list of packages to compile for every release of firmware for the wlan-ap devices (AXT-1800 and I guess AX-1800)?
I ask for a couple reasons.
I will submit these two plug-ins to R&D, if they can be adapted and compiled normally.
The first reason is, patch and diffutils are very basic Unix-y utilities, and I was quite surprised to find I couldn’t install them via OpenWrt.
The second reason is, I found some other old threads complaining about lack of packages f…
Hi!
I think we've already added these plugins for the AXT1800.
GL-AXT1800 4.8.x missing packages - #11 by bruce .
Double check:
Have you encountered any issues with this?
glinoob
January 25, 2026, 12:29am
20
Hi, I was indeed able to install patch and diffutils on the Slate AX.
Is there documentation anywhere about how I could build OpenWrt packages for Slate AX myself in the future?
You could try the following:
Alternatively, you could build packages directly using the native OpenWRT SDK.
Applicable model: AX1800 (Flint 1), AXT1800 (Slate AX)
GL Firmware: v4.8.x, op 23.05, aarch_cortex-a53-vfpv4
Needs, Application, Scenario:
The AX1800/AXT1800 feed is GL repo by default in GL firmware. Some plugins can't be found or installed from the GL repo?
How do we switch to OpenWRT feed to get more plugins?
Probably have questions about the software architecture of AX1800/AXT1800. Why cannot we find the corresponding architecture aarch_cortex-a53-vfpv4 to match in the OpenWRT repo? …
system
Closed
April 26, 2026, 6:05am
22
