[SOLVED] GL-MT3000 (Beryl AX) packet loss to router every 30-40 seconds
I've noticed that my Beryl AX is losing packets during equal periods of time (every 30-40 seconds) over the 5ghz network (I've turned off 2.4ghz).
This is a graph of me pinging 192.168.8.1 (the router's IP).
(i'm using gping to visualize, the spikes are lost packets)
I've tried everything - changing channels numbers, widths (40, 80, 160). Nothing helps. It happens even if I'm 1 meter away from the router.
Firmware is latest - 4.6.4
I believe this is a bug in the firmware. Has anyone experienced this?
Solved: the problem was having the STA Repeater mode turned on while using ethernet WAN. Turning off the repeater mode made the problem go away.
Long story:
I use GL.iNet Beryl AX during travels. Most of the time I use it in hotels, where I extend the wifi from the hall into the room (by using the STA repeater mode). The problem with packet losses started in a rented appartment when I decided to hook up the Beryl through a LAN cable to a router instead.
The logs (dmesg) showed that every 30-40 seconds my GL.iNet Beryl AX was trying to look for a previous hotel's wifi network to connect to. This resulted in me losing my wifi connectivity on the client side for a couple seconds every time.
Turning off STA Repeater mode when Beryl is connected via a lan cable made this problem go away.
Note to developers:
If ethernet is connected, maybe have STA Repeater mode turn off automatically?
I'd agree i wish this could be improved on, because we also have this failover system, ethernet should be prioritized as per default setting if it has link connection, somehow it doesn't seem to happen.
Some uers/customer probably require listening to the repeater SSID online, and use the repeater priority if the repeater connected, so they do not want to disable the automatically repeater.
But if you want to disable the repeater when the WAN interface connected, can try to custom a script, example for you:
create a script in the /etc/rc.d/S99wan_check.sh:
#!/bin/sh
/etc/init.d/repeater start
# Check whether the eth0 interface can ping 8.8.8.8
if ping -I eth0 -c 30 8.8.8.8 &> /dev/null; then
    echo "eth0 interface ping 8.8.8.8 ok, Repeater will be disabled"
    # disable Repeater mode/script
    /etc/init.d/repeater stop
else
    echo "eth0 interface cannot ping 8.8.8.8, Repeater keep working"
fi
Note: only when the device boot-up affective one time.
Thank you, this saved me. I was also having the same issue! :wink:
I hit this too. With WAN only on Ethernet and no WAN Wifi configured there is terrible packet loss on the router. Interactive sessions like VNC are unusable and video streaming is unreliable. Stopping the repeater solves the problem.
This ought to be considered a bug and not something we have discover here and fix with a boot script on every release.
To clarify, is this regarding the router (Beryl AX) running as the VPN server and also as repeater?
What's the setup here for the Beryl AX to have packet loss?
Also, make sure you turn the repeater off before you power it down. For some reason, when I go to a new place, my Slate has trouble transmitting the wifi SSID if repeater was left on from previous connection. Best to leave it off, and turn on repeater when you get to new location.
@eth Try this, it might work:
uci set network.wan.metric='10'
uci set network.wwan.metric='20'
uci commit
/etc/init.d/network restart
With this, default(0.0.0.0/0) will be routed to the WWAN only when the WAN link is down.
In simple terms, the WAN has priority over the WWAN.
You can adjust the numbers, or set some for other interfaces as well.
There's another recommendable one - mwan3
It provides much detailed options, and precisely detects the actual "online" status, based on the fine-tunable criteria.
Below is my actual use cases:
But it's temporarily unavailable now:
Try mwan3 when it back!
opkg update
opkg install luci-app-mwan3
