Even PCIE mode works and the speed is x3 ! Check out my guide for installing vanilla openwrt on x3000.
@ywp it seems to be working fine in stock openwrt. You seem to have a recent pattern of this happening with the GLInet firmware only.
Sounds for me like the factory partition is corrupt which hold some important stuff for the GL config (like hostname and encryption key)
Do you have any recommendations for getting some 5G connection status like the stock firmware? Like if it’s 5G NSA, SA, LTE, strength, etc? I use my Spitz as a modem only behind an OpenMPTCPRouter. Don’t need anything else GLI.Net has bundled in, really, but I’m not familiar with stock OpenWrts modem management.
Would be great if there was a way to wipe this partition from stock OpenWRT. I'd rather not go through the RMA process and be without of my modem.
There is, but I would not recommend nor support it.
So maybe you need to talk to @bruce or support about it.
I am looking for the same capabilities, better modem management and monitoring with vanilla OpenWrt, I also use the Spitz as a modem, with an MT6000 as a router running vanilla OpenWrt 23.05.4
4.3.0 and 4.4.10 Fail to Start Properly?
Can I see your partition?
cat /proc/mtd
4.4.10 isn't listed for downloads from what I can tell.
root@OpenWrt:~# cat /proc/mtd
dev: size erasesize name
root@OpenWrt:~#
/prod/mtd is empty
4.3.0 Are you sure can't get up?
Have you changed the mode of the module?
Did you do anything else?
ls /dev/ ---press tab
root@OpenWrt:~# ls /dev/
bus/ full log loop2 loop6 mmcblk0boot1 mmcblk0p4 mmcblk0rpmb ppp sda stdout ttyS10 ttyS14 ttyS4 ttyS8 ttyUSB2 watchdog
cdc-wdm0 gpiochip0 loop-control loop3 loop7 mmcblk0p1 mmcblk0p5 net/ ptmx shm/ tty ttyS11 ttyS15 ttyS5 ttyS9 ttyUSB3 watchdog0
console hwrng loop0 loop4 mmcblk0 mmcblk0p2 mmcblk0p6 null pts/ stderr ttyS0 ttyS12 ttyS2 ttyS6 ttyUSB0 ubi_ctrl zero
fd/ kmsg loop1 loop5 mmcblk0boot0 mmcblk0p3 mmcblk0p7 port random stdin ttyS1 ttyS13 ttyS3 ttyS7 ttyUSB1 urandom
I made zero modifications outside of the basic steps @SpitzAX3000 posted to get OpenWRT working.
The steps I took yesterday:
- Router stopped working
- I tried to reboot it
- I tried to reset it to factory defaults. I guess that didn't work
- I got it into UBoot mode, I tried to flash 4.4.9, didn't work. Tried probably 3-4 times.
- I flashed OpenWRT, same upload process, it worked immediately.
- I tried to flash 4.4.9 again, it didn't work. I tried 4.3.0 three times, it didn't work.
- I flashed OpenWRT again, and now I'm trying to use it.
opkg update
opkg install minicom
minicom -D /dev/ttyUSB2
Ctrl + a --press E
AT+QCFG="data_interface"
AT+QCFG="pcie/mode"
Take a look AT the results of these two AT instructions
To be clear, "didn't work", when referencing 4.3 and 4.4.9, meant it would not boot. I was unable to get a DHCP IP, use a static IP, see any activity, etc.
Welcome to minicom 2.9
OPTIONS:
Port /dev/ttyUSB2
Press CTRL-A Z for help on special keys
+QCFG: "data_interface",0,0
OK
AT+QCFG="pcie/mode"
AT+QCFG="pcie/mode"
+QCFG: "pcie/mode",0
OK
AT+QCFG="data_interface",1,0
Try 4.4.9 or 4.3.0 again?
I ran that command and then tried 4.3.0 again, twice. No dice. I do have a USB-UART adapter if there's anything to gain from looking at the serial console doing this. Otherwise I was suggested by email support to perform my own "forward return" by buying a new unit on AliExpress, and returning this one in its box, since its under warranty, but I don't want to be without it for what I would assume to be months.
Do you know which AT instructions you have executed?
thank you
Before it crashed? I hadn't run any AT instructions in probably 6-12 months since getting it set up initially. After it crashed? The only commands I ran were the ones listed in How-To: Installing Vanilla OpenWRT on GL X3000
echo -e "AT+QCFG=\"usbnet\",0\r\n" > /dev/ttyUSB2
echo -e "AT+QCFG=\"data_interface\",0,0\r\n" > /dev/ttyUSB2
After that, the only commands I've run were your commands to try and debug it, and then I reran those commands once I re-flashed OpenWRT this morning, to keep my system usable.
Can you get the logs of the serial port?
Mines doing the same thing now after going to newest firmware. Any fix for this?
What kind of problem?
Keep rebooting?
